Curtains Behind Front Seats
Page: Previous  1, 2
minsk
minsk is offline
PostPosted: Fri May 18, 2012 6:21 pm    Post subject: Reply with quote
nice work green machine
im thinking more or a rail sytem that goes behind driver section..and loops around to the back window..i dont like having the windshield covered...not good for urban camping.
tells the po po someone is sleeping in their hood.
Smile
1987 Sunroof Syncro
1988 Vanagon GL
1990 Carat
2009 audi a3
www.sunroofsyncro.com
vanagonmechanic.com
http://facebook.com/pittsburghvanagonclub
https://www.youtube.com/minskmade
my super slow 1987 sunroof syncro rebuild
https://goo.gl/photos/7e9MZhHJxGvvv1Tm7
VANAGON STICKERS
https://www.etsy.com/shop/pigeonink
View user's profile Send private message Send e-mail Visit poster's website AIM Address Facebook Instagram Gallery Classifieds Feedback
GreenMachineVW
GreenMachineVW is offline
PostPosted: Fri May 18, 2012 6:25 pm    Post subject: Reply with quote
That was exactly what I was thinking when I made it fit the behind the front seats: pretty stealth, especially in a darker shade.
Timwhy
Timwhy is offline
PostPosted: Mon Nov 25, 2013 3:16 am    Post subject: Reply with quote
Made a new curtain from a Harbor Freight movers blanket. The blanket looks to add some insulation
from the cold cabin. I cut the blanket down to size, added female snaps and then bound the edges.
Have to pick up another snap kit and add a few more to complete the job.
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
Clarey
Clarey is offline
PostPosted: Mon May 09, 2016 11:33 pm    Post subject: how to unsnap Curtains Behind Front Seats? Reply with quote
Silly question here but... How do you unsnap the front curtain? Mine snapped in easily, but I can't get it undone. Embarassed The curtain behind the front seats has a different type of snap than the other curtains. Is there a trick for undoing these super tight snaps?
Timwhy
Timwhy is offline
PostPosted: Tue May 10, 2016 3:22 am    Post subject: Re: how to unsnap Curtains Behind Front Seats? Reply with quote
Not sure what you have for snaps? I bought this snap tool from a canvas shop that repaired my GW Wasser Stopper
when one of the snaps pulled through the fabric on removal.
'15 Audi A3 Quattro
'87 VW Westy
'91 Tin Top
'90 Cabby
Westified
Westified is offline
PostPosted: Tue May 10, 2016 7:25 am    Post subject: Re: Curtains Behind Front Seats Reply with quote
Consider using Starbrite snap and zipper lube. It works great.
Overtons sells the snap removal tool.
http://www.overtons.com/modperl/product/details.cg...hgodj28AbA
1984 Westy Wolfsburg, owned since 1987. FAS 2.0 NA engine conversion in 2022.
tam_shops
tam_shops is offline
PostPosted: Tue May 10, 2016 8:03 am    Post subject: Re: how to unsnap Curtains Behind Front Seats? Reply with quote
That is cool! I want one!
As for the curtain, I hang mine like Tim, but with the original snaps (one on each side). In the middle, I use a magnetic hanger hook to snap the fabric onto the poptop metal. That way, when the child that sleeps up there wants out/down, it just falls off/down when he pulls on it and nothing tears.
http://www.amazon.com/Master-Magnetics-Magnet-Fast...0560DPYA93
Timwhy wrote:
1987 Vanagon Westfalia GL Automatic
Making it special:
http://www.thesamba.com/vw/forum/viewtopic.php?t=545885
pinetreeporsche
pinetreeporsche is offline
PostPosted: Tue May 10, 2016 8:31 pm    Post subject: Re: Curtains Behind Front Seats Reply with quote
SIMPLEST EVER: At a bicycle store or Target, get a bike flag on one of those flexy fiberglass poles. Measure twice, and cut the pole (once) to go between the outer edges of the shelf-ledges on either side of the mid-section of the van-- over the front of the slider door and above the front edge of the sink-- arched to push up against the underside of the headliner. Held in place by press-fit against the top, no screws or hooks. Use a decorated bed sheet (cut vertically up the middle and hemmed), or light weight full-length curtains-- and never mind the fact that the top is ached. Open up the ends of the top seam, and slide the two halves onto the fiberglass rod. When not in use, have the one behind the driver secured close to the pillar wall behind the drivers seat, esp. up high behind the driver, to minimize blinding the his view when swinging his head around for rear views-- gather in and retain the curtains w/ a few velcro loops, or even with twist ties. If the pole is the right fit, you can slide the curtains up to meet at the middle without too much of a fight, and they'll stay in place. This solution assumes that you also have the basic Westy window curtains, side and rear. Yes, it's tried and proven in Philadelphia in an urban residential district with plenty of pedestrian traffic.
Timwhy
Timwhy is offline
PostPosted: Tue Dec 21, 2021 3:56 pm    Post subject: Re: Curtains Behind Front Seats Reply with quote
Just finished putting up a curtain rail on the cab ceiling. My HF movers blanket that was in place with snaps had seen better days.
So, I wanted a more permanent curtain that I will be able to use without searching for it.
Here are the pics. Curtain slide rail.
https://www.amazon.com/dp/B007MD3MYO?psc=1&ref=ppx_yo2_dt_b_product_details
The curtain with wrinkle band tape.
https://www.amazon.com/dp/B07RYX2Z79?psc=1&ref=ppx_yo2_dt_b_product_details
I used the male snaps that I had put on the sides to keep it in place.
Also bought a 50 piece bag of slides but still had plenty of hooks.
https://www.amazon.com/dp/B007L8PJVE?psc=1&ref=ppx_yo2_dt_b_product_details
The curtains are held together with Velcro. Still need to make a couple of ties for them when not in use.
'15 Audi A3 Quattro
'87 VW Westy
'91 Tin Top
'90 Cabby
Red Ryder
Red Ryder is offline
PostPosted: Tue Dec 21, 2021 6:45 pm    Post subject: Re: how to unsnap Curtains Behind Front Seats? Reply with quote
Yes, it is a different snap with a safety catch. There is a center pin on the female side that pulls out to release the snap.
“Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition (Tornado Red)
“Nigel” — 1999 Jaguar XK8 convertible (Alpine Green Metallic)
mreuter
mreuter is offline
PostPosted: Mon Aug 14, 2023 10:01 am    Post subject: Re: Curtains Behind Front Seats Reply with quote
I have an original Westfalia divider for sale. This one is impossible to get because of the size. The material hast to be larger and it was never remanufactured in this size. In 12 years I only saw it ones for sale in Germany and I got it. I want $350 what was what I payed for in Germany (280 roro’s then $350) hit me up when interested. I post a picture of it.
https://www.thesamba.com/vw/classifieds/detail.php?id=2634704
TrashPanda
TrashPanda is offline
PostPosted: Thu Aug 17, 2023 5:30 pm    Post subject: Re: Curtains Behind Front Seats Reply with quote
This!
Been looking for this, exactly! Thanks for the run-down and the links!
1991 2.1L 4spd Tintop
Page: Previous  1, 2
Page 2 of 2
