Deck lid spring / Decklid mounting tab thread
Page: 1, 2, 3, 4, 5  Next
tasb
The Distributor Distributor
tasb is offline
PostPosted: Sat Jan 10, 2004 10:25 pm    Post subject: Deck lid spring / Decklid mounting tab thread Reply with quote
Well I found one of those elusive springs that helps close the engine lid on early buses. As I look at the engine prop elbow area it looks like there are 4-5 places where a spring might go. Does anyone have a picture of the spring installed or is realy good at explainations? Your help will be greatly appreciated. Oh, I have already checed the archives section and did not come up with anything.
Moderator note:
Here is a summary of the information in this thread:
Spring:
Operation:
When you lift up the engine lid, the prop tab (see photo) slides up the side of the engine compartment wall along the tab on the body. Once it gets to the top of the body tab, the spring pulls it towards you (or you pull it if you don't have a spring) and the tab ends up sitting on top of the body tab (bottom photo)
Tab on decklid:
(Note different positions of welded-on bracket)
1955-1959 style (reproduction tab but same as stock):
1960-1963 style, still for use with prop rod:
1964-up style with spring decklid:
Original bolt with shank and wavy washer:
Additional 1955-59 photos
Wade wrote:
From my Dec '55-built deluxe.
Mounting tab locations from Kommerical
Kommercial wrote:
The measurement I had on my website is; From the bottom edge of the bracket to the bottom edge of the decklid is 11 3/4" on passenger side of decklid. This is referring to the early style tab, 55-59. The 60-63 one is 10 11/16 from the bottom edge of the lid to the bottom lip of the mid style bracket. The 64 and later one is 12 7/8 to the sharp point of the bottom of the bracket but that bracket is a little less symmetrical then the two earlier ones so results may vary. These are all stock mounting points using correct brackets.
Scotts 63 23
Location: Somewhere in my mind... The Real er Laguna Beach :)
Scotts 63 23 is offline
PostPosted: Sun Jan 11, 2004 8:06 am    Post subject: Reply with quote
Hey [email protected],
I have a great photo of an installed spring on my bus that I will put in this thread when I find it. I'll be right back.
Scott
Scotts 63 23
PostPosted: Sun Jan 11, 2004 8:13 am    Post subject: Reply with quote
Here it is:
Hope that helps,
Scott
tasb
tasb is offline
PostPosted: Sun Jan 11, 2004 10:10 pm    Post subject: Reply with quote
Dag Scott that photo is dead on. How in the world did you get that pic? Either you are a circus act performer or you are smallish and could fit inside the engine bay. Anyway you are THE MAN thanks !!!!!
Scotts 63 23
PostPosted: Sun Jan 11, 2004 10:16 pm    Post subject: Reply with quote
Call me "Tom Thumb"...
PostPosted: Mon Jan 12, 2004 8:32 am    Post subject: Reply with quote
Wow, perfect photo.
That spring should be painted green though. Get on that!
jeremyrockjock
Samba Towbar Builder
jeremyrockjock is offline
PostPosted: Mon Jan 12, 2004 8:50 am    Post subject: Reply with quote
Scott, you didn't have to cut a hole in the corner of your bus just to get a picture for folks. Thats dedication. Smile
Why buy what you can build.
Scotts 63 23
PostPosted: Mon Jan 12, 2004 1:52 pm    Post subject: Reply with quote
I've got that spring down in my studio right now, sitting on my easel and I'm trying to match the green just for you Everett...
Scott
PostPosted: Mon Jan 12, 2004 1:55 pm    Post subject: Reply with quote
Scott
Actually, I wonder if the exposed areas would be green and most of it would be primer because the gun didn't hit it?
NorCalWeekender
NorCalWeekender is offline
PostPosted: Mon Jan 12, 2004 1:58 pm    Post subject: Reply with quote
Wow, perfect photo.
And whatever you do, never paint it a hideous shade of yellow that your wife would hate. Wink (see other thread for details)
-Taylor
9th Owner of a 1971 Tintop Westy
"Eventually, we sold to a guy for $500 who towed it away to live in it in his parents' driveway. We didn't think it would ever avoid the junk heap on that day." -The 3rd Owner, 1995
Scotts 63 23
PostPosted: Mon Jan 12, 2004 2:42 pm    Post subject: Reply with quote
You mean they didn't farm out the springs to local artists in Germany who color matched them to the various buses? Where's that personal touch we have grown to expect out of the German assembly line?
Scott
tasb
tasb is offline
PostPosted: Mon Jan 12, 2004 4:53 pm    Post subject: Reply with quote
Installed the spring this afternoon. I have never seen another bus that had one installed though I'm sure they are out there. Most do not know they have one missing.
for those who have know ideas what this is all about the spring adds tension to the elbow prop so all you have to do is push lightly on the tab of the lever to disengage the stay and down comes your lid. Previously I had to push and tug and finagle it loose.
Thanks Again Scott!
YellowSplittie
YellowSplittie is offline
PostPosted: Mon Jan 12, 2004 5:05 pm    Post subject: Reply with quote
My '64 has the spring, but the prop is missing. Sad
Anyone have one to sell?
Lind
Lind is offline
PostPosted: Mon Jan 12, 2004 5:43 pm    Post subject: Reply with quote
I don't have any spare props, but I have about a dozen of those springs. if anyone needs one, email me.
jeremyrockjock
PostPosted: Tue Jan 13, 2004 7:32 am    Post subject: Reply with quote
My 59 had the spring but I had to buy a prop for $50. Of course the prop swivel point was missing from the deck lid (Im sure where ever it is the prop is attached to it) so i canned (cannibulized) one from a later bus deck lid. I used that picture last year to figure out how the prop worked. I was use to the later style with the rollers and had never seen the early style before.
cyberdyne systems 101
Sambanator
cyberdyne systems 101 is offline
PostPosted: Thu May 05, 2005 8:07 am    Post subject: Reply with quote
can someone post a pic of the front side of this bracket that the stay and spring go on as it looks to me as though some of that is missing from my bus
Cheers
Arnie
When I think of something to say - I'll be the first to know
56' Oval
71' Westy
Scotts 63 23
PostPosted: Thu May 05, 2005 8:26 am    Post subject: Reply with quote
Does this help?
'63 23 Daily Driver
www.scottmooreart.com
BryanM
BryanM is offline
PostPosted: Thu May 05, 2005 8:29 am    Post subject: Reply with quote
Scott you rock so hard. great pics.
wasnt someone cranking out some repro springs?
-Bryan
Motorwagen LLC
Concord NC
View user's profile Send private message Visit poster's website AIM Address Instagram Gallery Classifieds Feedback
Scotts 63 23
PostPosted: Thu May 05, 2005 8:37 am    Post subject: Reply with quote
Thanks Bryan.
Yeh, everyone has the repro springs and the props now. Here's WW's links:
Spring:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211827375
Prop:
http://www.wolfsburgwest.com/cart/DetailsList_test.cfm?ID=261827361
'63 23 Daily Driver
Sambanator
PostPosted: Thu May 05, 2005 8:44 am    Post subject: Reply with quote
Great pic! yes it does help, need to get out and compare it now. My stay will connect to the bracket on the bus but comes off just as easily, will the spring hold it? In other words I've not been able to get the lid to stay up with the stay and no spring, still I feel i'm getting ever closer to the answer!
Thx so much!
Arnie
56' Oval
71' Westy
Page 1 of 5
