arizonabuckeye Samba Member
Posted: Mon May 16, 2016 8:15 am Post subject: Spark plug stop |
I was watching an RC maintenance vid for a nitro powered car over the weekend. They had a fancy tool that screwed in place of the spark plug to stop the piston. It let them wrench on the flywheel etc. without having some other way to hold the crank from turning.
Have any of you thought of using something like that on a VW motor? It would have to be strong as balls so it didn't strip things out. |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2290 Location: Jacksonville, FL
Posted: Mon May 16, 2016 8:30 am Post subject: Re: Spark plug stop |
Flywheel lock works fine on a VW motor. _________________ www.LoCashRacing.org
Lo' Cash Racing Team on Facebook
More brains than bucks...Believe it or not!!
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
jason Samba Member
Posted: Mon May 16, 2016 8:46 am Post subject: Re: Spark plug stop |
| The hole in the piston might pose a problem. Only thing it would be good for would be to find true TDC. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20909 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon May 16, 2016 8:59 am Post subject: Re: Spark plug stop |
The torque applied to small engine used in RC racing is way different then large scale internal combustion engines...
My Stihl chainsaw and weed whacker motors have a plastic (nylon?) piece to insert through spark plug hole to act as positive stop..... And I have heard of threading a length of nylon rope through spark plug hole to "fill" combustion chamber for positive stop.... But if you are going to put a bolt through spark plug hole and gronk 200-300 ft pounds of torque to tighten (or looses) flywheel , you might consider the time and effort to tear motor down again and replace bent rod and punctured piston.... Use of positive stop and degree wheel can be useful for finding TDC but with no torture applied the is little danger...
Flywheel stop or mechanics helper or nothing in my shop...
Dale _________________ “Fear The Government That Wants To Take Your Guns"
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1245 Location: San Angelo, Texas
Posted: Mon May 16, 2016 8:34 pm Post subject: Re: Spark plug stop |
The rope thing works.......specifically ski rope. We changed a broken valve spring at the lake in a jet boat with a piece of ski rope to hold the valve up. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
