64-67 only e brake cable clips??
Page: 1, 2, 3  Next
mr white
mr white is offline
PostPosted: Sun Jun 12, 2016 4:05 pm    Post subject: 64-67 only e brake cable clips?? Reply with quote
I am putting together a 67 bus . I am replacing the park brake cables and noticed one side had a clip that retained the ebrake cable to the backing plate up top on the inside behind the cables spring. This turned to powder once I touched it. I cannot find any for sale or a part number. They are mentioned in the Bentley in step number 9 under ebrake. I need two of these. Any help is appreciated.
Eric&Barb
Eric&Barb is offline
PostPosted: Sun Jun 12, 2016 4:37 pm    Post subject: Re: 64-67 only e brake cable clips?? Reply with quote
http://oacdp.org/aboutdoc.html
At the bottom of that web page are links to many VW dealer manuals including parts manuals. Lots of exploded diagrams, listings of part number, name and even from what chassi to what chassi most parts were used. Take the time to look thru at least the type 2 parts manual for plenty of "I did not know VW had that part there!".
Use the "Full Index", it is a lot easier to find stuff. Group 6 should be were it is.
Having name and part number helps a lot with WWW search. When searching just for part number put VW in front of it and try both with the stock spaces in the part number and without the spaces.
In Stereo, Where Available!
mr white
mr white is offline
PostPosted: Sun Jun 12, 2016 4:53 pm    Post subject: Re: 64-67 only e brake cable clips?? Reply with quote
Thank you for posting that. I have gone through all of group 6 and no luck. I have also searched my oldest etka micros with no luck. Kinda frustrating! For sure an original part.
Eric&Barb
PostPosted: Sun Jun 12, 2016 5:22 pm    Post subject: Re: 64-67 only e brake cable clips?? Reply with quote
Pretty sure the #9 clip is for small axle nut and was dropped with introduction of the big axle nut.
#14 in this diagram:
http://www.wolfsburgwest.com/img/wwimg/brakes/bus_brakes.svg
Eric&Barb
PostPosted: Sun Jun 12, 2016 5:24 pm    Post subject: Re: 64-67 only e brake cable clips?? Reply with quote
mr white
mr white is offline
PostPosted: Sun Jun 12, 2016 5:31 pm    Post subject: Re: 64-67 only e brake cable clips?? Reply with quote
Nope not it. No provision at all for those on a 67.
BarryL Premium Member
BarryL is offline
PostPosted: Sun Jun 12, 2016 6:56 pm    Post subject: Re: 64-67 only e brake cable clips?? Reply with quote
Yes you have to have the part to make the spring operate. Its a flat wafer the size of a trimmed nickel. You can fashion one with tin snips and a piece of banding strap but pretty sure Wolfsburg West has them. Call them?
mr white
mr white is offline
PostPosted: Sun Jun 12, 2016 7:15 pm    Post subject: Re: 64-67 only e brake cable clips?? Reply with quote
Thank you Sir! Sounds about right. I thought about making one out of the brake shoe retainer cup top. I will call WW tomorrow for sure.
campingbox Premium Member
campingbox is offline
PostPosted: Sun Jun 12, 2016 10:13 pm    Post subject: Re: 64-67 only e brake cable clips?? Reply with quote
I always make them from sheet steel. If you find a source for new ones post it up.
GLHTurbo
GLHTurbo is offline
PostPosted: Mon Jun 13, 2016 4:51 am    Post subject: Re: 64-67 only e brake cable clips?? Reply with quote
Are we talking about this?
1957 Beetle
1966 Bus
mr white
mr white is offline
PostPosted: Mon Jun 13, 2016 7:55 am    Post subject: Re: 64-67 only e brake cable clips?? Reply with quote
That is exactly what I am talking about. Thanks for the post.
licketysplit
licketysplit is offline
PostPosted: Tue Aug 08, 2017 8:46 am    Post subject: Re: 64-67 only e brake cable clips?? Reply with quote
Hi GLFTurbo,
where do you buy that black U shaped clip?
Thanks
Toby
tnc19
tnc19 is offline
PostPosted: Wed Jun 03, 2020 2:42 pm    Post subject: Re: 64-67 only e brake cable clips?? Reply with quote
I’m trying to figure out how to install these (The parts in my pics) e brake parts...clip, washer, and the slotted u clip.
Please help me with pics, where in the blue manual I can find, or where I can find a schematic. I cannot find it in the blue manual.
I have a 63 DC, that apparently has a set of 64 drums on it (from factory) not sure if that matters, but the bearings and brake shoes were for a 64.
Thanks
Eric&Barb
PostPosted: Wed Jun 03, 2020 3:01 pm    Post subject: Re: 64-67 only e brake cable clips?? Reply with quote
The "U" shaped clip is the one being replaced with the modified stainless steel finishing washer earlier in this same thread, in between the parking brake cable spring and the backing plate.
tnc19
tnc19 is offline
PostPosted: Wed Jun 03, 2020 3:30 pm    Post subject: Re: 64-67 only e brake cable clips?? Reply with quote
Thanks, ok. I’m good on the u shape clip. Where does the washer and bracket go?
tnc19
tnc19 is offline
PostPosted: Wed Jun 03, 2020 4:01 pm    Post subject: Re: 64-67 only e brake cable clips?? Reply with quote
Thanks
Here is backing plate and emergency brake cable through the back plate.
Is that just a metal brake line clip?
Metal brake line clip is #55 in this diagram from WW:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211698000
ozinbc
ozinbc is offline
PostPosted: Wed Jun 03, 2020 4:17 pm    Post subject: Re: 64-67 only e brake cable clips?? Reply with quote
The OP was about the need for a washer on a 67 rear brake set up.I must be missing something as I cannot see the part on any of the diagrams I have, and the backing plate for the later bus allows the spring to abut the ferruled cable end.Is this not the way VW intended? What purpose does a washer serve?
the invisible and the non existent look very much alike
Eric&Barb
PostPosted: Wed Jun 03, 2020 4:18 pm    Post subject: Re: 64-67 only e brake cable clips?? Reply with quote
Exactly. Pull the forward end of the parking brake cable spring to the rear and put the clip on the cable so spring is now pushing on the brake backing plate via the clip.
Eric&Barb
PostPosted: Wed Jun 03, 2020 4:25 pm    Post subject: Re: 64-67 only e brake cable clips?? Reply with quote
From the gallery:
Page: 1, 2, 3  Next
