sen2two Samba Member
Posted: Sat Jun 25, 2016 4:49 pm Post subject: Weber issue |
When shutting my fuel pump off to kill the car. The car continues to run until it drains the entire fuel bowl. I have an exrernal fuel bowl sight glass from JayCee and I can watch it drain from there while it's idling with all the power shut down.
It's a single 51mm IDA Weber with a Mallory 140 pump. Mallory 4309 return regulator. Has 4psi while fuel pump is on with car off and 3.5psi with car idling. -6 fuel feed and return.
This is a 12a Rotary engine, but I don't think that makes a difference. |
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Sat Jun 25, 2016 5:38 pm Post subject: Re: Weber issue |
I can understand turning the fuel pump off but there is still pressure after the pump to the Carb and the float will still allow the fuel to enter the bowl.
If your Ignition is still on to the coil the engine will continue to run until the fuel in the bowl is Kaput (gone) like going Dry.
I have a Turbo 1776 engine with a glass filter between the pressure regulator and the Weber DCOE Carb to verify the pump is working.
The pump is a Facet and my pressure to the Carb is at 2.5 lbs....Webers like that. |
modok Samba Member
Joined: October 30, 2009 Posts: 27660 Location: Colorado Springs
Posted: Sat Jun 25, 2016 6:11 pm Post subject: Re: Weber issue |
I think you forgot to mention what the problem is. |
Posted: Sat Jun 25, 2016 8:15 pm Post subject: Re: Weber issue |
I did. Maybe I wasn't clear.
When I shut the car down. It continues to idle for about 20-30 seconds as is draws the fuel from the bowl until it is empty. |
Posted: Sat Jun 25, 2016 8:16 pm Post subject: Re: Weber issue |
your spark plugs are likely too hot. Try a couple steps colder. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
modok Samba Member
Posted: Sat Jun 25, 2016 8:33 pm Post subject: Re: Weber issue |
sen2two wrote: |
Idling with ignition off.
That's called dieseling. Dieseling might be a problem or it might not. sometimes they will diesel when there is no actual problem. This is why the majority of carbs have anti-diesel solenoids.
IDA is a racing carb and does not have idle cutoff solenoid, because you don't need one. How do you stop it from dieseling?
Put it in high gear and release the clutch.
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2522 Location: Meridian,ID
Posted: Sat Jun 25, 2016 8:34 pm Post subject: Re: Weber issue |
Turning off the fuel pump won't stop the carb from working, it works until there is no more fuel in it, then it stops working. |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3997 Location: SANDY VALLEY, NEVADA
Posted: Sun Jun 26, 2016 12:33 pm Post subject: Re: Weber issue |
Does it have a MSD 6 box on it by chance? If it does it might need the diode in line to kill the power from the alternator.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
