teamasr Samba Member
Joined: August 04, 2009 Posts: 159 Location: SF Bay Area
Posted: Sun Jul 17, 2016 10:05 pm Post subject: Spark Plugs burning ok? |
What do you guys think of this burn on the plugs? 2017 on dual webers.
Two richer ones are from right side, two leaner ones are on left side. Thinking right side should be leaned out a bit.
Getting pops under acceleration after about 20 min of continuous drive.
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Sun Jul 17, 2016 10:10 pm Post subject: Re: Spark Plugs burning ok? |
Slightly warm. Id try a Colder plug. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Danwvw Samba Member
Posted: Mon Jul 18, 2016 9:01 am Post subject: Re: Spark Plugs burning ok? |
Jfats why do you think a colder plug? NGK B5ES are in there now.
Black carbon around base of plug look good? |
Posted: Mon Jul 18, 2016 9:53 am Post subject: Re: Spark Plugs burning ok? |
I agree, try a NGK "6". _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Mon Jul 18, 2016 9:55 am Post subject: Re: Spark Plugs burning ok? |
The prong strap itself shows how hot (or cold) your plug is by the heat transfer mark on the strap. From the firing end to abouts halfway is considered with in heat range. Too close to the tip is cold, too warm is close to the strap base.
I used to have a saved page on my phone with sites on reading plugs and t -mobile did some upgrade and I can't find it now. _________________ 2276 IDA's 86C 11-1 DD !
Posted: Mon Jul 18, 2016 11:02 am Post subject: Re: Spark Plugs burning ok? |
Gotcha both...thanks.
Should I do any leaning or fattening on either side giving the difference in color, or just put plugs in and try again before I touch anything else? |
Posted: Mon Jul 18, 2016 11:50 am Post subject: Re: Spark Plugs burning ok? |
do plugs first.
Trying to read plugs with unleaded fuel is mostly a waste of time. Plugs don't color well with unleaded. _________________ It's just advice, do whatever you want with it!
mark tucker Samba Member
Posted: Mon Jul 18, 2016 2:05 pm Post subject: Re: Spark Plugs burning ok? |
I agree wong plug range. pop's are usualy leen condition. check float level's and carb sync. |
Posted: Mon Jul 18, 2016 3:22 pm Post subject: Re: Spark Plugs burning ok? |
The owner of my local Napa suggested the B6HS as the old plug seem to be sticking several threads into the cylinder. Thoughts?
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13852 Location: White Mountains Arizona
Posted: Mon Jul 18, 2016 3:37 pm Post subject: Re: Spark Plugs burning ok? |
Oh my what an issue you are in now. do you know anything about the heads? You sure don't want to have the plug hitting the cylinder top.
My opinion on the plugs is they are really close to the correct range. With no lead in the fuel anymore the plugs stay clean. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Mon Jul 18, 2016 4:07 pm Post subject: Re: Spark Plugs burning ok? |
The old plugs is what came in the motor from Chico Performance. They seem to clear the piston, but you can see several of the threads appearing to be sticking out into the head with the darker build up.
I can either go back to the same long ones one step colder or use these shorter ones. |
Posted: Mon Jul 18, 2016 4:11 pm Post subject: Re: Spark Plugs burning ok? |
make sure the plugs match the heads.
Also, do not under ANY circumstances, use never-seize. I see some on your plug threads, that is not good in my experience. _________________ It's just advice, do whatever you want with it!
Posted: Mon Jul 18, 2016 5:35 pm Post subject: Re: Spark Plugs burning ok? |
[email protected] wrote: |
Also, do not under ANY circumstances, use never-seize. I see some on your plug threads, that is not good in my experience. |
ditto x4 |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4858 Location: sanger ca
Posted: Mon Jul 18, 2016 5:56 pm Post subject: Re: Spark Plugs burning ok? |
I have used "anti" seize on all alluminum heads since 1984 with zero problems, the only times I have seen problems is when plugs were installed dry. Just currious as why you say not to use it? _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Mon Jul 18, 2016 6:21 pm Post subject: Re: Spark Plugs burning ok? |
How can I check if they match the head? I am looking at the old plug and see that at least 3 of the threads have black carbon on them, so assuming they are protruding out. If installed put those plugs in, should I assume they are right, or go shorter? |
fes Samba Member
Joined: January 26, 2011 Posts: 999 Location: Prince Edward Island
Posted: Mon Jul 18, 2016 6:57 pm Post subject: Re: Spark Plugs burning ok? |
I think the easiest way to see if your heads are for long reach plugs is to take a piece of wire and bend it like a hook, mark with a marker at the top of the plug hole and compare it with the plug itself.
_________________ '68 Campmobile-Pedro
'15 Golf-Stella Blau
'56 Oval-The Turd (for now) |
Posted: Mon Jul 18, 2016 7:43 pm Post subject: Re: Spark Plugs burning ok? |
I can't even count how many times I've seen mysterious misfires cleared up when it was removed. At least over 100x.
mcmscott wrote: |
I have used "anti" seize on all alluminum heads since 1984 with zero problems, the only times I have seen problems is when plugs were installed dry. Just currious as why you say not to use it? |
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Mon Jul 18, 2016 8:45 pm Post subject: Re: Spark Plugs burning ok? |
NGK BP6HS or BP7HS (latter in my Turbo bug) |
Posted: Tue Jul 19, 2016 11:09 am Post subject: Re: Spark Plugs burning ok? |
I would put bosche platinums in it. |
