Go Westy skid plate with flood LED's on Syncro
tjet
tjet is offline
PostPosted: Wed Jul 20, 2016 6:57 pm    Post subject: Go Westy skid plate with flood LED's on Syncro Reply with quote
Finally installed my GW front skid plate. I came up with an idea to install a pair of flood LED's to mount on the skid plate. I bought a pair of Rigid Ignite flush mount flood beams. Link below:
http://www.rigidindustries.com/led-lighting?f[0]=field_product_family%3a5485
I originally planned to cut a pair of 1" holes on the skidplate & put the floods on either side, but I discovered that the the angle wasn't correct. I ended up making some brackets from a piece of u channel I had. I bolted them up to the most aft holes on the sides of the plate.
Here's the skid plate. It's a nice piece & heavy duty
http://www.gowesty.com/product-details.php?v=&id=4153
Here are some pics. I only got one side LED mounted. I'll finish it up tomorrow & get some nighttime pics...
newfisher
newfisher is offline
PostPosted: Wed Jul 20, 2016 7:45 pm    Post subject: Re: Go Westy skid plate with flood LED's on Syncro Reply with quote
Awesome. The added light will be great off road.
tjet
tjet is offline
PostPosted: Wed Jul 20, 2016 8:01 pm    Post subject: Re: Go Westy skid plate with flood LED's on Syncro Reply with quote
Yeah I hope. I've always wanted to get some lights mounted low for slow wheelin & hill climbing.
BTW, I think I should add a disclaimer on those "Ignite" lights. Just in case someone is thinking about using these lights as fog lights, they are way too intense (almost arc like). You will blind oncoming traffic for sure. They should only be used for off roading
If you want fogs, use these below
http://www.rigidindustries.com/products/sae
Skidub
Skidub is offline
PostPosted: Thu Jul 21, 2016 7:55 am    Post subject: Re: Go Westy skid plate with flood LED's on Syncro Reply with quote
Love that idea and how you accessorized the skid plate. I have the GW skid plate too.
Can you share what size channel you used and your wiring schematic, switch, etc...?
86 Syncro GL Tin Top
Subaru 2.5L Swap
Rblt Transaxle w/ R Locker + Decoupler
tjet
tjet is offline
PostPosted: Thu Jul 21, 2016 8:19 am    Post subject: Re: Go Westy skid plate with flood LED's on Syncro Reply with quote
Thanks. BTW, I'm not done accessorizing it yet. I'm going to see if a RotoPax water container will fit above it...
http://rotopax.com/1.75-Gallon-Water.html
I bought the aluminum section from McMaster-Carr. Rigid also makes a that light with a pedestal (surface) mount. It may be a better option. The nice thing about the aluminum is that it should move a lot of heat away from the light.
You can just get a section of 90 deg 3/16" 2"x2" L channel & save yourself a couple of cuts & a few bucks. $11 for a 1 foot piece.
http://www.mcmaster.com/#aluminum/=13dodjg
This is what I have (for another project)
Highly Corrosion-Resistant 6063 Aluminum, U-Channel, 1/8" Thick, 2-1/2" Base, 2" Legs, 4'
http://www.mcmaster.com/#catalog/122/3706/=13do25u
Wiring is not done yet. It will be relay controlled.
WLD*WSTY
WLD*WSTY is offline
PostPosted: Thu Jul 21, 2016 3:45 pm    Post subject: Re: Go Westy skid plate with flood LED's on Syncro Reply with quote
Maybe you can rig up some headlight washers to keep the mud off.
'82 SyncroWesty, the first ever conversion.'06 Subaru 2.5L
0cean
0cean is offline
PostPosted: Thu Jul 21, 2016 5:04 pm    Post subject: Re: Go Westy skid plate with flood LED's on Syncro Reply with quote
tjet wrote:
Really, Your van is the Anti-Christ? Evil or Very Mad d'oh!
I'm not a mechanic, I just play one on the internet
Cluster Rebuild:
http://www.thesamba.com/vw/forum/viewtopic.php?t=569920&highlight=
Left for Dead the Resurrection Story Build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=613669
(Number of Different Donor VW Vans Body Parts Used: 12)
(Number of completely different vehicles parts used: 3)
tjet
tjet is offline
PostPosted: Fri Jul 29, 2016 9:50 pm    Post subject: Re: Go Westy skid plate with flood LED's on Syncro Reply with quote
I got the other side installed. For the small size, they really throw out a nice flood pattern.
Using these alone, you probably wont be able to go more than 15-20 mph. I plan on getting a Rigid Dually spot lamp to mount onto the driver mirror (I have LT mirrors)
Steve M.
Steve M. is offline
PostPosted: Sat Jul 30, 2016 5:48 am    Post subject: Re: Go Westy skid plate with flood LED's on Syncro Reply with quote
Do you happen to have a picture taken from the drivers seat?
It's a good project.
btw. has anybody told you it looks like you ran over Kermit? Laughing
tjet
tjet is offline
PostPosted: Sat Jul 30, 2016 8:20 am    Post subject: Re: Go Westy skid plate with flood LED's on Syncro Reply with quote
I tried, but the camera I have dosent like night photos without a flash. I'll try to adjust that setting & get a pic.
Kermit - All the green primer? It will be Waxoyl Hardbody Black soon. Cool
