IRS Bolt on Like BusBoys (Are They Out of Biz?)
Page: Previous  1, 2, 3  Next
sambaphil
sambaphil is offline
PostPosted: Fri Aug 19, 2016 11:41 am    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
Just to follow up on this thread, Joel did a fantastic job of installing the kit. No problems there at all.
The issue I am faced with is the new bay bus rear end sits even taller than stock height by about 1.5 inches. The stock bay bus CV joints don't like the large angle and are making clicking noises. I am replacing the cv joints with these dune buggy / larger angle CV joints.
https://www.amazon.com/gp/product/B003KKDANQ/ref=oh_aui_detailpage_o00_?ie=UTF8&psc=1
Hopefully this solves the clicking noise. BTW..as an experiment I loaded friends in the bus and no clicking noise since the angle was reduced. The other option I thought about is to go with an adjustable spring plate to get the angle I need but ??
Thanks again Joel...
Link to 1966 Samba Build
http://www.thesamba.com/vw/forum/viewtopic.php?t=607420
Link to 1971 Bay Bus - Clipper - L
https://www.thesamba.com/vw/forum/viewtopic.php?t=671945&highlight=
Single Port Samba Phil
[email protected]
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger Gallery Classifieds Feedback
sambaphil
PostPosted: Fri Aug 19, 2016 11:57 am    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
karl h wrote:
just found this:
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...p;start=20
scroll to the middle of the page for the CV info
Karl...this is good info. My bus may need to go this route to be right. Or I just load 300 pounds of sandbags in the rear Smile.
[email protected]
Bulli Klinik
Bulli Klinik is offline
PostPosted: Sat Aug 20, 2016 9:01 am    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
Can't you simply adjust the spring plates?
Mike K
Bulli Klinik
Colorado Springs
Harleyelf
Harleyelf is offline
PostPosted: Sat Aug 20, 2016 1:47 pm    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
I use a couple of old crankcase studs mounted in the rear fender bracket bolt holes, with a steel bar joining them and supporting the engine. It draws the ride height down about an inch.
cdennisg
cdennisg is offline
PostPosted: Sat Aug 20, 2016 5:32 pm    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
This.
sambaphil
PostPosted: Sun Aug 21, 2016 8:14 am    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
Yeah..gonna put on dune buggy large angle bus cv joints and mess with spring plates to bring the height down about an inch or so. I will get there, just takes time. Once I get it all sorted with the right recipe, I will report back. Thanks all
[email protected]
tisius
tisius is offline
PostPosted: Sun Aug 21, 2016 11:07 am    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
?Huh?
Can you post a picture of what that looks like? I totally don't get your solution.... a split bus does not have fenders, are you talking about a VW bug?
drive it like you just robbed the bank
.... if it ain't dutch, it ain't much!
Harleyelf
PostPosted: Sun Aug 21, 2016 12:59 pm    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
Bumper mounts. Fender wells. Like a mustache bar for splits.
cru62
cru62 is offline
PostPosted: Sun Aug 21, 2016 1:48 pm    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
Unfortunately, that will have absolutely no effect on the ride height of a vehicle. It is commonly known as a "traction bar" and merely keeps the engine from moving under acceleration.
"My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
sambaphil
PostPosted: Mon Aug 22, 2016 5:45 pm    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
cdennisg wrote:
This.
Hey Guys,
So monkeying around with ride height, I have static spring plates. If I replace the spring plate just one spline north, it looks like it will drop the ride height a lot more than an inch. When you guys made the comment about simply adjusting the spring plate, were you assuming I had adjustable spring plates?
Thanks guys, I appreciate the input on this..
[email protected]
cdennisg
cdennisg is offline
PostPosted: Mon Aug 22, 2016 7:01 pm    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
sambaphil wrote:
cdennisg wrote:
This.
Hey Guys,
No. There are splines on the inside end of that torsion bar, too. With one combo of up/down between the two, you can gain (or lose) about 3/16" ride height.
sambaphil
PostPosted: Mon Aug 22, 2016 7:32 pm    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
Huge bulb just went on!! Idea Idea now I get it!
I can do the math on moving in inner one direction and the spring plate the other direction.
Learning as I go. Cool. Thanks.
[email protected]
cdennisg
cdennisg is offline
PostPosted: Mon Aug 22, 2016 9:31 pm    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
Bingo! There are a different number of inner and out splines to allow for small increments of change. I believe it comes out to just between 1/8" and 3/16" of overall height change per inner/outer spline combination.
sambaphil
PostPosted: Tue Aug 23, 2016 11:03 am    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
Here is a video on YouTube. It looks to be a bay bus adjusting torsion bars and angles but same concept. The key ingredient I was missing is 5 minutes and 11 seconds into the video. I hope this helps others.
https://www.youtube.com/watch?v=xfcqkC4RkYI
Cheers!
SP
[email protected]
cdennisg
cdennisg is offline
PostPosted: Tue Aug 23, 2016 10:19 pm    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
Bay bus, early/late beetle, type 3 are all the same setup in regards to torsion bar indexing to adjust ride height. I did not watch the entire video, but it seems like he has the right idea.
Fredrok
Fredrok is offline
PostPosted: Wed Aug 24, 2016 7:35 am    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
From the gallery:
sambaphil
PostPosted: Thu Aug 25, 2016 8:30 am    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
OK...looks like I have the math. My approach, do math, measure from floor, eyeball, make fine adjustments, and get as close as I can to stock height. Roll the bus around the block a few times, see if all is good.
Thanks again for all the input from the community. Super helpful. I love videos so I will make a video of the highlights and post it. Work slated with my friends for Sunday. Need to research the best way to get the spring plates off safely.
Cheers,
SP
[email protected]
cru62
cru62 is offline
PostPosted: Thu Aug 25, 2016 10:58 am    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
Spring plates on a bus are a breeze. They aren't preloaded against the bottom stops like a bug. Just pry them off making sure not to pull out the torsion bar from the housing. Of course, this after marking the original orientation of the bar to plate and plate to housing.
cdennisg
cdennisg is offline
PostPosted: Thu Aug 25, 2016 7:24 pm    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
Yes. I usually make a vertical line top to bottom over the whole thing. That way, If things get wonky, you can always go back to your starting point.
sambaphil
PostPosted: Fri Aug 26, 2016 3:48 pm    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
I am good at wonky. i will be marking things up to get back to where i was. I bought a "white" sharpie which is pretty cool.
Can't be too bad though, its just angles. Crap...just jinxed myself. Smile
[email protected]
Page 2 of 3
