sixfootdan Samba Smartass
Joined: February 13, 2002 Posts: 4848 Location: \Lo*ca"tion\, n. 1. The act or process of locating.
Posted: Sun Aug 28, 2016 7:11 am Post subject: '67 Java Green Bug |
Saw this on the local Craigslist and couldn't pass it up. A military member was needing to unload it so I took it for a scary test drive and struck a deal.
It has a simple cut and turn in the front, 1600dp and the body looks very dry. I'm going to fix some basic things to be more road worthy and then just drive while I fix. I prefer that over something that will be immobile for a year or more. It's got great patina and I will post progress as I go.
Got it home next to her taller fatter sister.
I wish someone hadn't sanded the decklid. I'll be on the lookout for another og paint one or perhaps a holy grail vert one.
Needs interior very badly, But the dash is nice and uncut.
All four corners are nice and dry.
So during the scary test drive I noticed the brakes were way out of adjustment and so was the clutch. I got it home and put a jack under it, The fronts were so far out of adjustment it was on stopping on the rears. This was the guys daily driver! The front shoes were really thin so I ordered new ones. Next was the clutch issue, It is really hard to depress and the cable had two washers on it and all the adjustment was taken used up so I ordered a new cable and a spare as well. You can also see a spacer on the top engine bolt.
The infamous 34pict with a 009 and a fuel filter in the engine compartment to boot. I'll fix all of that.
_________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
Posted: Sun Aug 28, 2016 3:06 pm Post subject: Re: '67 Java Green Bug |
Well the original plan was to adjust the brakes and clutch cable and drive it with full intention of replacing the battery and seat section of the pan soon after. Now I'm changing the pan first and I pulled the seats and insulation for a through cleaning and brush on rust converter where needed and a coat of paint.
After a wire wheel, wire brush, shopvac, and a wipe down, I applied a coat of rust converter. The metal looks to be in good shape.
I have had a green dot Talbot mirror since 2003 and I may use it on this Bug, I have always loved Talbot mirrors.
GO SEAHAWKS!!! |
Posted: Sun Aug 28, 2016 3:18 pm Post subject: Re: '67 Java Green Bug |
Most mid life crisis guys buy a Corvette, I saw the '67 on Craigslist and it made me miss my old '67 Bug that was very incorrect for a 1967 Bug. The Java Green '67 will be similar but more correct.
GO SEAHAWKS!!! |
Posted: Mon Aug 29, 2016 8:27 pm Post subject: Re: '67 Java Green Bug |
During the test drive I noticed the shifter was a little sloppy. I popped the shift coupler inspection cover off and found this, Someone had stuffed the rear section with foam and the forward bushing had traveled all the way to the back.
GO SEAHAWKS!!! |
Posted: Sun Sep 04, 2016 7:21 am Post subject: Re: '67 Java Green Bug |
Got a few parts in yesterday, Pan half, Rear window gasket, Shift rod bushing, Front brakes, And the proper length clutch cable.
Last night I started with the rear window gasket because it's leaking into the car. I crawled in the back and pushed with my shoulder and got it to move, But I thought I would push a little more before going to the outside to finish and it popped out onto the ground KABLOOIE!
I already located a window for free about an hour away that I'm getting this afternoon. I eventually want to find the right one without the defrost grid but this will work for now. _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
Posted: Mon Sep 05, 2016 6:55 am Post subject: Re: '67 Java Green Bug |
Picked up the new window yesterday and popped it in. I cleaned the frame and waxed the paint around it before installing. Just making it easier on myself later.
Next I pulled the shift rod out to change the fwd bushing. I'm also going to replace the hanger bracket for it too. Note all the sunflower seed shells.
I pulled all the dreaded foam out of the rear section of the pan. I'm guessing the shifter rattled a speed and that was someone's fix. The second pic shows the bottom of the foam and the moisture it held working on returning the steel back to mother natures original version.
Another shot of the tunnel, I'm going to clean it out and use this paint product to coat it.
http://www.eastwood.com/internal-frame-coating-w-spray-nozzle-qt.html
GO SEAHAWKS!!! |
babysnakes Samba Member
Posted: Mon Sep 05, 2016 7:45 am Post subject: Re: '67 Java Green Bug |
I bought 5 or six cans of that stuff for my single cab. I'm using in all the pillars and frame members I can access. The spray tube is only 24" long. Sprays on nice. |
Posted: Fri Sep 16, 2016 9:30 pm Post subject: Re: '67 Java Green Bug |
Still cleaning the tunnel out with a combination of air and a shop vac.
Had a few beers when I got home and then went out in the Laboratory and had a few more and almost made a HUGE mistake installing the shifter bracket, The camera is pointing forward.
I flipped it around and welded it in.
I actually get a 2 day weekend so I am going to work on the pan half replacement in the morning.
GO SEAHAWKS!!! |
Posted: Sun Sep 18, 2016 6:54 am Post subject: Re: '67 Java Green Bug |
Pan replacement is in and about 65% welded out which I'll finish up today.
GO SEAHAWKS!!! |
Posted: Sun Sep 18, 2016 5:26 pm Post subject: Re: '67 Java Green Bug |
Finished welding the pan up and rust treated the tunnel with the first coat.
Sanded and treated the pedal area so I can paint it and reinstall the pedals.
GO SEAHAWKS!!! |
BrianR Samba Member
Joined: September 01, 2016 Posts: 9 Location: S. Florida
Posted: Sun Sep 18, 2016 7:14 pm Post subject: Re: '67 Java Green Bug |
Keep posting it's an inspiration for me replacing my pans. Where did you buy your's from and how is the quality? |
Posted: Mon Sep 19, 2016 3:36 am Post subject: Re: '67 Java Green Bug |
BrianR wrote: |
The pan is empi and I got it from amazon, I trimmed it to fit with no problems. _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1227 Location: Eerie PA
Posted: Mon Sep 19, 2016 8:30 am Post subject: Re: '67 Java Green Bug |
I am watching this one with interest, Awesome looking car! I have a 67 I want to do in java green, mine needs a bit of missing / rusted metal replaced though.
Java green cars rock! _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 11 Window (Zelda)
1965 13 Window (Lucas)
1957 Oval ragtop
1988 Cabriolet VR6 conversion
Plus a lot of other rusty junk |
Posted: Mon Oct 03, 2016 6:00 am Post subject: Re: '67 Java Green Bug |
I went to install the clutch cable and noticed the weld broke at the forward ned of the tube. I cut an access hole to fix it I also noticed a small area where my shop vac did not get all the crud in the tunnel so I got it from the new hole.
I welded up the hole and stuck the tar board patch back on.
I had used up all of the green tunnel paint so I shot some black spray paint over the patch.
I cleaned and greased the shift rod and reinstalled it. I also fed the new clutch cable in as well. _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
Posted: Wed Oct 05, 2016 9:21 pm Post subject: Re: '67 Java Green Bug |
Tonight I installed the freshly painted pedals with painted and antiseized bolts and hooked up the clutch cable. I ordered all new rear brakes and spring kit. Getting a little closer to driving the daily driver I originally bought. _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
Posted: Sun Oct 09, 2016 6:25 am Post subject: Re: '67 Java Green Bug |
Adjusting my clutch I noticed this brake line, Looks like only one wrench was used.
GO SEAHAWKS!!! |
Posted: Sun Oct 23, 2016 7:58 am Post subject: Re: '67 Java Green Bug |
The bug had no wiper motor when I bought it but the linkage was installed wipers and all. I thought that was weird but whatever. I pulled the linkage and it was frozen solid so I broke it down and got the shafts sitting in oil. I'm in the process of cleaning and painting all of the linkage pieces. I bought a used motor and ordered new bushings, clips, and grommets. While doing all this I saw lumps under a fairly new windshield rubber.
Sorry about the shitty cell phone pic, It's pieces of the old rubber gasket. I'm half tempted to just buy a new gasket and razor the other one out vs. trying to save it and end up braking the windshield which looks to be fairly new also. I'm all too familiar with Murphy's Law seeing as how I have already broken the rear window dropping it and my Girlfriend's last name is Murphy lol.
On a side note, I also may use this funky steering wheel I've been sitting on.
My plan for today is to get all of the lights working as about half of the functions dont. I am also going to install my new quarter window gaskets, Have a great day. _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
Posted: Sun Oct 23, 2016 5:08 pm Post subject: Re: '67 Java Green Bug |
Well I never made it to the quarter window gaskets. I spent time cleaning electrical connections. Ground strap, Starter, and Bulb sockets. I got everything working exterior except for the license plate light. I'm one step closer to driving it. _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
67jason Samba Member
Joined: August 28, 2005 Posts: 4741 Location: behind my back feet - Pittsburg CA
Posted: Fri Oct 28, 2016 6:27 am Post subject: Re: '67 Java Green Bug |
cool project _________________ 67 bug x3
67 ghia
64 bug |
c21darrel Samba Member
