Auxiliary battery wiring
Whiskey Tango 801
Whiskey Tango 801 is offline
PostPosted: Sun Aug 28, 2016 6:47 am    Post subject: Auxiliary battery wiring Reply with quote
Ok new poster here go easy on me.
I have a 84 westy with a solar panel that is hooked up to charge a second battery. The second battery is tied to the main battery through a Sun Force 150amp micro processor controlled battery isolator.
So my questions are
1 I don't really know how the Sun Force works cant find any paperwork on it. Does it tend both batteries? I am assuming that the water pump and the other hard wired electric stuff (interior lights, stereo) are still running off the main battery. I can disconnect the main battery and test this but I'm 99% sure they run of the main. SO does the main stay topped up with the solar panel through the Sun Force?
2 Can i easily switch it so that the auxiliary battery runs all the electric not the main?
Gnarlodious
Gnarlodious is offline
PostPosted: Sun Aug 28, 2016 7:07 am    Post subject: Re: Auxiliary battery wiring Reply with quote
I found some minimal instructions here:
http://sunforceproducts.com/prodinfo/manuals/60113_150AmpBatIsoManual.pdf
Not to worry, the device is modern and does everything automagically. The only thing I am unclear about is wether it will charge the cranking battery while the aux battery is being charged. One of the points in the instructions says:
“You can charge the auxiliary battery with a battery charger without affecting the battery isolator…”
This suggests that it is unable to connect the batteries while the auxiliary side is being charged. However it may be the result of poor instructions or me misreading them. You may need to determine that empirically. If needed, it does have a manual connect so you can charge your cranking battery.
To be honest, you are probably better off getting a more mainstream isolator like the Yandina or Blue Seas.
Its not too hard to rewire your lights, radio etc to run off the auxiliary battery. Interior lights probably run off of fuse #8, which also powers dashboard lighter and brake lights (smart wiring was not the Vanagon’s forte). Radio runs off of fuse #9, along with emergency flashers. You are going to have to find the relevant wires and separate them from their fuses.
Whiskey Tango 801
PostPosted: Sun Aug 28, 2016 7:26 am    Post subject: Re: Auxiliary battery wiring Reply with quote
Thanks for those instructions, Had a hard time digging anything up. We just got the westy a few weeks ago so i am still getting up to speed on it all.
Looks like it should work out fine even if i don't re wire, since it should charge up the starting battery as needed off the aux and solar. I have noticed when camping that the battery indicator under the stove goes down to the yellow even red once then back up to green without ever starting the engine so it must be doing something. lol
I have installed a digital volt meeter on the aux along with usb ports and 12 volt plugs so i can see very actually what the aux battery is reading.
Also seems that it will charge up the Aux battery when the car is running off the alternator. Was unsure if it did this or if only the solar was charging the aux battery.
crazyvwvanman
crazyvwvanman is offline
PostPosted: Sun Aug 28, 2016 8:46 am    Post subject: Re: Auxiliary battery wiring Reply with quote
That is a uni-directional isolator device. It lets whatever charging source is wired to the starting battery also be shared with the aux battery, under certain common conditions. It isn't meant to share charging in the other direction.
So if the solar is wired to the aux battery it WON'T also charge the starting battery. Under certain conditions it sometimes might but don't count on it.
The whole point of the aux battery is to let you use battery power while stopped with no worry about draining the starting battery. If you set it up properly there is no need for the solar to charge the already full starting battery and your model of isolator will dedicate the solar to the aux battery most of the time.
Mark
Whiskey Tango 801
PostPosted: Sun Aug 28, 2016 9:26 am    Post subject: Re: Auxiliary battery wiring Reply with quote
Thanks Mark,
Its making more sense now. Still a couple questions
1- Any explanation (other than its just not very accurate) for the battery indicator under the stove (main battery I assume) to show all the way down to red then later the same day back to green. Van was not started at all so no alternator charging.
2- I totally agree on having the auxiliary battery power all the electronics (lights, water pump, stereo) and only having the main battery used to start the van. Is there a simple wiring diagram that will show me how to make it work like this?
crazyvwvanman
PostPosted: Sun Aug 28, 2016 9:31 am    Post subject: Re: Auxiliary battery wiring Reply with quote
One explanation would be that the kitchen led panel is hooked to the aux battery. You need to find out.
Mark
fxr
fxr is offline
PostPosted: Sun Aug 28, 2016 9:52 am    Post subject: Re: Auxiliary battery wiring Reply with quote
I assume that's down to the solar panel. While there's no drain on the battery (lights out, no radio etc) then only a small amount of charging current is needed to make the battery volts rise above 12.6V, even if it is quite well discharged.
Jim Crowther
Vespa GTS 300
Whiskey Tango 801
PostPosted: Sun Aug 28, 2016 10:23 am    Post subject: Re: Auxiliary battery wiring Reply with quote
Mark
Ok Just went out and disconnected the main battery and everything went dead. Battery indicator light, cabin light, water pump. All dead.
Paulbeard
Paulbeard is offline
PostPosted: Sun Aug 28, 2016 11:16 am    Post subject: Re: Auxiliary battery wiring Reply with quote
So what is your aux battery doing? Where do the camper equipment wires (connected to the relay under the seat in stock configuration) go?
Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
Git 'r DONE!
— dhaavers
DLJ
DLJ is offline
PostPosted: Sun Aug 28, 2016 11:25 am    Post subject: Re: Auxiliary battery wiring Reply with quote
Many of the Kitchen LED panel switches are prone to short out a little.
Try and wiggle the small switch on the panel, if led battery light flucuates you have a minor
short. Take panel out and re-solder.
Whiskey Tango 801
PostPosted: Sun Aug 28, 2016 11:37 am    Post subject: Re: Auxiliary battery wiring Reply with quote
We have a 1500 watt inverter as well as usb and 12v power ports running off the auxiliary.
Paulbeard
PostPosted: Sun Aug 28, 2016 11:43 am    Post subject: Re: Auxiliary battery wiring Reply with quote
so those work but the camper stuff that usually gets wired to the auxiliary doesn't?
Seems to me you would want all of that wired to run from the aux so you don't run down the starter battery. Is there a fuse panel somewhere with all of that that can moved to the aux?
Git 'r DONE!
— dhaavers
Whiskey Tango 801
PostPosted: Sun Aug 28, 2016 11:52 am    Post subject: Re: Auxiliary battery wiring Reply with quote
This is exactly what i want, just don't know how to do it.
Paulbeard
PostPosted: Sun Aug 28, 2016 12:03 pm    Post subject: Re: Auxiliary battery wiring Reply with quote
Well, share a picture/diagram of what you have in place so that we can see where you are.
I have a fuse panel behind my seat that connects all the camper stuff and my TruckFridge to the aux battery.
You should have a relay like this (the silver gray object top left) under your drivers seat with the sink pump and lighting wires going to it.
My battery lives under the bench with a BlueSeas ACR connecting them.
There are many ways to do this. Some put their battery under the sink or in the cubby next to the water tank. No battery of any useful size will go under the driver's pedestal though you might get away with if you have solar charging always on. Those are usually 44aH or so where most recommendations are for 150 aH or more.
A fuse panel and a well-known ACR are a must, I think. And I don't know what kind of solar charge controller you have. Is that part of what the SunForce things does?
Git 'r DONE!
— dhaavers
Whiskey Tango 801
PostPosted: Sun Aug 28, 2016 12:20 pm    Post subject: Re: Auxiliary battery wiring Reply with quote
Its pretty simple set up so far.
Solar panel runs to a "solar controller"
http://e-bluelight.com/goods-57-WELLSEE+WS-MPPT15+15A+1224V+battery+charger+controller.html
Then to the auxiliary battery, A 1500 watt inverter is taped strait to the battery.
The auxiliary battery is linked to the main battery with the "sun force 150 amp battery isolator"
fxr
fxr is offline
PostPosted: Sun Aug 28, 2016 12:34 pm    Post subject: Re: Auxiliary battery wiring Reply with quote
It's possible the PO added the aux battery just to provide power to the inverter. However, I suspect most here would agree with me that an inverter is unnecessary as just about everything portable that could be powered by an inverter can much more efficiently be powered by 12V to (whatever volts) DC to DC converters. So 12V-USB or 12V-19V laptop converters.
In which case, I'd suggest removing the inverter, and after study of the Bentley wiring diagram, decide which house circuits would be better served by the aux battery, and move them over. This would normally be all those things you'd like to use while the engine isn't running. Lights, radio, 12V outlets, USB outlets etc.
Jim Crowther
Vespa GTS 300
Paulbeard
PostPosted: Sun Aug 28, 2016 1:30 pm    Post subject: Re: Auxiliary battery wiring Reply with quote
What Jim Crowther said. It's not really an aux/house battery as most of us know the term. It's a power source for an inverter (and other tech power draws) that may not be necessary.
Git 'r DONE!
— dhaavers
Whiskey Tango 801
PostPosted: Tue Aug 30, 2016 2:39 pm    Post subject: Re: Auxiliary battery wiring Reply with quote
Yes I understand this, thats why on my OP i asked if there was a simple way to fix this and make the camper stuff run off the extra battery
fxr
fxr is offline
PostPosted: Tue Aug 30, 2016 3:43 pm    Post subject: Re: Auxiliary battery wiring Reply with quote
Yes, as I stated above, "after study of the Bentley wiring diagram, decide which house circuits would be better served by the aux battery, and move them over. This would normally be all those things you'd like to use while the engine isn't running. Lights, radio, 12V outlets, USB outlets etc."
Disconnect the battery grounds (both of them). Run a fused wire (14ga is OK, fuse it to 20A) from the aux battery, under the seat (I assume the battery is under the driver's seat) and under the carpet and up to behind the fuse panel. Remove wires (that feed the things you want powered with engine off) from the fuse-panel, and connect them to this wire you've just run in. A selection of insulated spade terminals and a decent crimp tool can help here.
Jim Crowther
Vespa GTS 300
Whiskey Tango 801
PostPosted: Mon Oct 17, 2016 2:00 pm    Post subject: Re: Auxiliary battery wiring Reply with quote
Ok I have finally started this project, I have installed the sub fuse panel under the sink that is where i will wire the sink pump and whatever else i need to off of. I have wired the sink pump to it easy enough. But when i started looking around for a 8 amp fuse to put into it it seems that none exist. So should i do a 7.5 or a 10? Or is there some secrets source for the 8 amp blade fuse.
