Sofia74 Samba Member
Posted: Sun Aug 28, 2016 3:25 pm Post subject: Angle grinder and stripping paint |
I am starting to strip paint and realized my single speed angle grinder is not going to cut it. Almost dangerous using stripping disks - too fast, too powerful. I think the answer is a variable speed angle grinder so i can slow the speed down. But before I go buy and try I wanted to ask what others use to mechanically remove paint. Variable speed angle grinder?
Additional info: (Having never done this) my plan is to do this in phases starting with doors. Phase 1 is a gentler more environmentally friendly stripper to get the most off. Phase 2 would be the grinder. Lastly I'll use a nastier chemical to get the remaining paint in the hard to reach places. Thats the plan.
Thanks,
Matt |
anthracitedub Samba Member
Posted: Sun Aug 28, 2016 3:33 pm Post subject: Re: Angle grinder and stripping paint |
I would ditch the idea of using such harsh methods to remove paint... You'll likely gouge the metal and create low/thin areas.
Use the brush on aircraft chemical paint stripper and a putty knife... Brush the panel and let it react, then watch the paint peel off...
It can take a few cycles of recoat/scrape... But the results are better.
Once you have it mostly stripped, break out a little DA sander to finish/clean the surface.
I just did a hood and it turned out really nice. You'll save some time and use of body filler with chem strip method. |
Posted: Sun Aug 28, 2016 3:39 pm Post subject: Re: Angle grinder and stripping paint |
| I have aircraft paint remover. Thats my phase 3 to get the last of it off. I was trying to minimize the use of the harshest chemicals mostly just to minimize the mess. Think I should start with the aircraft paint remover? |
SoCalJes Samba Member
Joined: November 02, 2011 Posts: 1093 Location: Broward, FL
Posted: Sun Aug 28, 2016 5:23 pm Post subject: Re: Angle grinder and stripping paint |
I started with the aircraft paint remover and finished the bondo areas with a brass wire wheel. After I got it all down to bare metal I used spray on rust inhibitor while I waited to get it down to the paint booth. The seams are sealed with what looks like lead and no matter how slow you go with an angle grinder it will eat through it like butter... _________________ Jesse
71 Ghia
______________________________________
Just because it didn't come that way, doesn't mean it shouldn't have. |
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Sun Aug 28, 2016 7:13 pm Post subject: Re: Angle grinder and stripping paint |
I used this harbor freight wheel on a grinder to remove 3 layers of paint and 1/4 inch of Bondo worked fantastic.
http://www.harborfreight.com/4-12-in-polycarbide-abrasive-wheel-60571.html
I did try aircraft paint remover, no thanks
A heat gun and a scrapper worked well in smaller areas. _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
swhitcomb Samba Member
Joined: November 05, 2003 Posts: 5786 Location: Inwood WV
EPETREA Samba Member
Joined: September 07, 2007 Posts: 392 Location: DFW TX
Posted: Mon Aug 29, 2016 7:50 am Post subject: Re: Angle grinder and stripping paint |
| Consider having it blasted. You will wish you had later if you don't. It's the only part that I regret not doing. But if you insist , angle grinder works great but don't use grinding wheel or flapper. Instead use a cupped wire brush. It eats through paint pretty easy. Cupped, not the flat wire wheel. |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4942 Location: Raleigh, North Carolina
Posted: Mon Aug 29, 2016 8:29 am Post subject: Re: Angle grinder and stripping paint |
I use DA air sander & 80-100 grit paper. Light touch - let the sander do the work. Another option is to have body soda blasted.
I'd choose chemical stripping as a last resort, as it's hard to guarantee that all of the chemicals get neutralized or removed - then it resurfaces under your new paint & bodywork down the road.
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Posted: Mon Aug 29, 2016 9:11 am Post subject: Re: Angle grinder and stripping paint |
I looked into this and could not find anyone near me ( and I'm very close to Philadelphia) also sand/soda blasting my ghia convertible was in the $1100 range with doing the inside of the car "extra". _________________ ----------------------
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
Posted: Mon Aug 29, 2016 10:51 am Post subject: Re: Angle grinder and stripping paint |
| You should look into getting a heavy duty air compressor. Like 5hp, 35+ gallon size.. It will be the most valuable piece of equipment doing a restoration. Especially if you are going to try painting it yourself. Then you can add a pressurized sand blaster to the regime , which makes getting into all the nooks and crannies a breeze. Also using an D/A sander is the best for smooth and easy work. |
Posted: Mon Aug 29, 2016 11:07 am Post subject: Re: Angle grinder and stripping paint |
| EPETREA wrote: |
I use this as well, In intervals while the air compressor is building up. I have a nice 3 inch scar on my left thigh where it got caught up in the wheel well and bounced down on my leg. Very effective tool, but use caution . I'll never use the trigger lock again !!!! |
bluedot Samba Member
Posted: Mon Aug 29, 2016 11:15 am Post subject: Re: Angle grinder and stripping paint |
I've seen a lot of cars damaged with overly aggressive paint removal. Warped panels from sandblasting, etc.
I have had great luck with citri-strip - orange based paint remover. Non-toxic and doesn't strip the OG paint, which there is no need to remove.
Good luck! |
Posted: Mon Aug 29, 2016 11:18 am Post subject: Re: Angle grinder and stripping paint |
| Almost forgot, I also used 6 in da with 80 grit disk. Messy as hell but it chews through the paint. I started out trying to use my good electric 5 in but the air sander worked 5 times better. I picked up one from HF for$36 and it lasted nearly to the end. However this method is extremely dusty. You will have paint dust everywhere. |
lonotch Samba Padrino
Joined: August 28, 2004 Posts: 3307 Location: So. Cal. Oceanside GFK!
Posted: Mon Aug 29, 2016 11:34 am Post subject: Re: Angle grinder and stripping paint |
If you go the sandblasting route you will need to remove all the plastic filler first, most sandblasters will not remove that off. _________________ It's not about the window, it's about the people.
German Folks |
Posted: Mon Aug 29, 2016 11:41 am Post subject: Re: Angle grinder and stripping paint |
| lonotch wrote: |
| If you go the sandblasting route you will need to remove all the plastic filler first, most sandblasters will not remove that off. |
Also there is no worry about 'warped panels' with home shop blasting. Just ain't powerful enough. Industrial blasting is another matter |
Posted: Mon Aug 29, 2016 12:05 pm Post subject: Re: Angle grinder and stripping paint |
| lonotch wrote: |
My question is: how would you know where the plastic filler was until you remove the paint ? A magnet is never a sure thing. _________________ ----------------------
Posted: Mon Aug 29, 2016 1:19 pm Post subject: Re: Angle grinder and stripping paint |
Gel paint stripper, brass wire wheel and patience...
71 Ghia
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8246 Location: San Dimas
Posted: Mon Aug 29, 2016 3:16 pm Post subject: Re: Angle grinder and stripping paint |
Jesse,
Brass wire wheel? Are you using a wire cup wheel? What is it attached to? Angle grinder?
As I continue to experiment, i used a wire wheel attached to my drill. Might be good for small hard to reach places, but worthless for large areas.
Your car looks great. I spent a couple hours on a door and I barely have any actual metal shining through so far.
Matt |
Posted: Mon Aug 29, 2016 3:57 pm Post subject: Re: Angle grinder and stripping paint |
| Sofia74 wrote: |
Jesse,
Matt |
I used a combination of cup and flat depending on the contour of where I was working on the bondo areas, the rest I went through about three coats of gel paint remover and a plastic putty knife. The wire wheel cuts through the bondo (use a respirator) pretty easy but since its softer than the steel body it is pretty harmless. I used the wire wheels on a standard variable speed drill. When I was finished I used a spray on rust inhibitor and the body sat for a couple of months in 60%/80% humidity without a spec of rust until I got it to the booth and it got a coat of primer. _________________ Jesse
71 Ghia
