Bought a 77 Westy from my in laws... random updates
Page: Previous  1, 2, 3, 4, 5, 6, 7, 8
SGKent Premium Member
SGKent is offline
PostPosted: Sat Jun 11, 2016 10:50 am    Post subject: Re: Bought a 77 Westy from my in laws... random updates Reply with quote
if the floats are black hard shell foam replace them and the flooding will stop. If they are brass they rarely go bad.
Tcash
Tcash is offline
PostPosted: Sat Jun 11, 2016 11:23 am    Post subject: Re: Bought a 77 Westy from my in laws... random updates Reply with quote
Fuel Shutoff Valve
74superTN
74superTN is offline
PostPosted: Fri Sep 23, 2016 3:30 pm    Post subject: Re: Bought a 77 Westy from my in laws... random updates Reply with quote
So the bus had a great Summer! Few car shows under the belt and ran solid!
That being sad, I'm running hot (400 degrees) at 55mph or faster! Any ideas? Cooling tins installed, timing correct, flaps opened in safe mode. I don't know!! Making a huge trip to Florida for Florida Bug Jam in November so this is my next issue to tackle!
73 Thing
80 Vanagon Westy
74superTN
PostPosted: Sat Sep 24, 2016 7:45 am    Post subject: Re: Bought a 77 Westy from my in laws... random updates Reply with quote
Could it possibly a carb issue? Maybe running lean at faster speeds? Weber 40IDF dual carbs
73 Thing
80 Vanagon Westy
74superTN
PostPosted: Sun Sep 25, 2016 9:01 am    Post subject: Re: Bought a 77 Westy from my in laws... random updates Reply with quote
Adjusted the valves. Seems to be better but still running hot (375-400) at 55 or 60mph
73 Thing
80 Vanagon Westy
Tcash
Tcash is offline
PostPosted: Sun Sep 25, 2016 9:57 am    Post subject: Re: Bought a 77 Westy from my in laws... random updates Reply with quote
Timing
74superTN
PostPosted: Sat Oct 01, 2016 5:37 pm    Post subject: Re: Bought a 77 Westy from my in laws... random updates Reply with quote
When adjusting my valves for zero lash, should I my push rods spin freely or not? I've read where you adjust till the valves are at zero lash and the push rods spin freely and then I've also read where you adjust to zero lash and then give it up to another 1 1/2 turns in. Which is correct?
73 Thing
80 Vanagon Westy
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sat Oct 01, 2016 11:20 pm    Post subject: Re: Bought a 77 Westy from my in laws... random updates Reply with quote
What kind of lifters are you running? Solid or hydraulic?
The Samba member since 2004.
74superTN
PostPosted: Sun Oct 02, 2016 5:57 am    Post subject: Re: Bought a 77 Westy from my in laws... random updates Reply with quote
Not sure but I have chromoly push rods
73 Thing
80 Vanagon Westy
Tcash
Tcash is offline
PostPosted: Sun Oct 02, 2016 8:39 am    Post subject: Re: Bought a 77 Westy from my in laws... random updates Reply with quote
Zero lash, think of it as zero tension Zero clearance.
Back off the adjuster until there is noticeable shake between the pushrod and rocker.
Spin the pushrod with two fingers while tightening the adjuster until you feel a slight drag.
Now back the adjuster out until the drag just goes away.
This is zero lash.
Turn the adjuster in 1 1/2 turns and lock it down.
Warning do not rotate the engine. The valves at this point are held slightly open. Due to the hydraulic lifter pressure needing to bleed down. Rotating the engine at this time can cause the pistons to contact the open valves and bend the valves.
Wait until you can spin the pushrods with your fingers.
Note:if the lifters do not bleed down. Let them sit overnight. If they are still tight in the morning. You have Solid lifter. Adjust accordingly.
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sun Oct 02, 2016 9:38 am    Post subject: Re: Bought a 77 Westy from my in laws... random updates Reply with quote
You need to figure that out before adjusting the valves. Plenty of previous threads discuss how to check. Smile
74superTN
PostPosted: Sun Oct 02, 2016 2:42 pm    Post subject: Re: Bought a 77 Westy from my in laws... random updates Reply with quote
Cylinder head temp update.....I might be an idiot
So I read about 30 minutes ago that when installing the VDO cylinder head temp sending unit onto your #3 spark plug, you remove the spark plug crush seal first.....
I did not do this...So I went and removed it really quick and now my temps are running about 50 degrees less, give or take.....Does this make sense or did I just mess something else up? Lmao
73 Thing
80 Vanagon Westy
74superTN
PostPosted: Mon Oct 10, 2016 5:41 am    Post subject: Re: Bought a 77 Westy from my in laws... random updates Reply with quote
Anyone know the answer to my last question?
On a side note, made it through Hurricane Matthew!
73 Thing
80 Vanagon Westy
THall
THall is offline
PostPosted: Mon Oct 10, 2016 6:51 am    Post subject: Re: Bought a 77 Westy from my in laws... random updates Reply with quote
I run a Dakota Digital unit and it has always performed just fine with the crush washer on the plug.
'78 Westy - 2.0 FI
74superTN
PostPosted: Wed Oct 12, 2016 7:45 am    Post subject: Re: Bought a 77 Westy from my in laws... random updates Reply with quote
Local show a few weeks ago...People love these things!
73 Thing
80 Vanagon Westy
williamM
williamM is offline
PostPosted: Wed Oct 12, 2016 7:56 am    Post subject: Re: Bought a 77 Westy from my in laws... random updates Reply with quote
Laughing Those retro surfer babes will follow you home- caution--- can be as expensive as vw parts---
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
74superTN
PostPosted: Sat Oct 22, 2016 10:21 am    Post subject: Re: Bought a 77 Westy from my in laws... random updates Reply with quote
Few brake issues going on right now. Elongated bearing holes, worn brake pads, worn rotors
73 Thing
80 Vanagon Westy
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sat Oct 22, 2016 1:06 pm    Post subject: Re: Bought a 77 Westy from my in laws... random updates Reply with quote
Shocked China made wheel bearing...EEk!
74superTN
PostPosted: Sun Oct 23, 2016 7:18 am    Post subject: Re: Bought a 77 Westy from my in laws... random updates Reply with quote
Latest issue... trying to figure out where I can order an exhaust exactly like the one installed. All I can find are them exiting the passenger side. My exhaust exits the drivers side. Can the system be reversed?
73 Thing
80 Vanagon Westy
Page 8 of 8
