wythac Samba Member
Posted: Sat Jun 09, 2012 8:43 pm Post subject: |
| Another reason to swap them out....they are stiff and can help make a short wheelbase buggy feel a little more twitchy. I noticed a difference when I got the WCM rag joint, the steering feedback was smoother. |
EVfun  Samba Member
Posted: Sat Jun 09, 2012 9:03 pm Post subject: |
| didget69 wrote: |
| Urethane in the steering linkage? No thanks.... VW didn't use them from the factory. |
I just wanted to point out that "VW didn't" is a bit ironic in the buggy forum.
I mean, VW didn't cut 14 inches out of any frames or hang the floorboards off a light weight fiberglass body either! That said, there is a good reason not to use a urethane steering coupler. The factory rag joint is naturally redundant. It would require complete degradation of the rubber and a significant number of broken cloth strands before the steering could get free. The urethane can fail with no built in back-up keeping the steering connected. |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4942 Location: Raleigh, North Carolina
Posted: Sun Jun 10, 2012 10:54 am Post subject: |
| EVfun wrote: |
| didget69 wrote: |
My point was that a new factory rag joint coupling works well, for many years, as intended. Why change to a lesser quality urethane part? So you can run a pretty colored rag joint to match your 'fancy red wiring loom' that is guaranteed to give you 10 more horsepower?  _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Sun Jun 10, 2012 6:05 pm Post subject: |
| airdreams1 wrote: |
| dirtbugger wrote: |
I managed to find that Pic of the coupler on my mates buggy.
It was only months old and as you can see from the condition of all the surrounding hardware, the buggy had never rolled a tyre in the dirt.
I know this is an old post......... But this thing was not even installed correctly! Its no wonder why It failed. Cant blame the product for this one... it should have a washer on both sides of all 4 holes just like the instructions should have said.
It should look something like this:
bit longer.
& if it isnt flat like it should be, adjust things till it is. Dont leave it like this:
Leaving it warped like in the pic above will ruin the OEM rubber ones too. it just takes a bit longer. (I know I lost a nylock & will be replacing it in the morning)
That said Ive never had a problem running them on my Baja. no problems with the motor mounts or trans mounts either. But I ran them with a center trans mount & bell housing strap as well (just to be sure I didnt get any motor hop & brake anything. & never a problem with the shifting coupler or trailing arm bushings.
All was on by baja since Y2K.... & Yes they saw lots of off road use..
Just for the record, I didnt buy the cheep empi crap made in China!
OH, & should mention that the same urethane steering coupler is now on my Samurai.......... Soon to be a Volksuki Bugurai (Samurai chassis with my 66 Baja body) |
If you mount a stock (OEM) ragnut the same way, it will still last years longer than a urathane ragnut. _________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
Posted: Mon Jun 11, 2012 7:46 am Post subject: |
These are stronger than the urethane couplers...
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20896 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon Jun 11, 2012 7:57 am Post subject: |
| didget69 wrote: |
Besure to use nylock nuts and washers though...
Dale _________________ “Fear The Government That Wants To Take Your Guns"
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6768 Location: Northern California
Posted: Mon Jun 11, 2012 9:39 am Post subject: |
| And the genuine American ones, not those crappy Belgian or Chinese ones |
EVfun  Samba Member
Posted: Mon Jun 11, 2012 7:10 pm Post subject: |
| didget69 wrote: |
| EVfun wrote: |
| didget69 wrote: |
My point was that a new factory rag joint coupling works well, for many years, as intended. Why change to a lesser quality urethane part? So you can run a pretty colored rag joint to match your 'fancy red wiring loom' that is guaranteed to give you 10 more horsepower?  |
I agree with the conclusion and do run a factory rag joint. I just thought the reason you gave was rather funny in the Buggy forum. A urethane coupler may suffer a rapid complete failure. That is quite undesirable in a car steering system!  |
TDB Samba Member
Joined: April 11, 2016 Posts: 2 Location: Wetumpka, AL
Posted: Thu Oct 20, 2016 12:20 pm Post subject: Re: Broken Steering Shaft Coupler |
On the picture on this page. Does that coupling that goes onto the steering box have any groves on the steering column or do you use the clamp to make it tight. I am still trying to get this Maxi Taxi back together. Thanks Dean
I am sure Dale will let me know. Thanks again. |
Posted: Thu Oct 20, 2016 4:16 pm Post subject: Re: Broken Steering Shaft Coupler |
| TDB wrote: |
Steering box shaft on my buggy is splined and yoke(?) for coupler is splined, don't remember though if bolt sits high in clamp and not in groove in steering box shaft like steering wheel shaft side..
EVfun  Samba Member
Posted: Thu Oct 20, 2016 7:33 pm Post subject: Re: Broken Steering Shaft Coupler |
Good picture, it shows a proper rag joint too. My steering shaft has an extension because the Berry Mini-T (and some other kit cars) have the seating position moved back. My coupler is made of of 2 female halves (steering box side) with the rag joint between them and a smooth solid shaft used as an extension. That shaft has the notch shown, at each end, for the bolt to pass through so even if it starts to come loose the steering input will still be transferred to the box. It does not have the fine spline like grooves the stock part has, but there are no matching splines inside the stock steering column shaft. The split female side tightens around the male side when the bolt in the clamp is tightened.
Good point on using locking hardware in this critical location. _________________
| Wildthings wrote: |
| As a general rule, cheap parts are the most expensive parts you can buy. |
elginbuggy Samba Member
Joined: April 24, 2011 Posts: 4 Location: Elgin Illinois
Posted: Mon Nov 07, 2016 12:26 pm Post subject: Re: Broken Steering Shaft Coupler |
Has anyone ever replaced the cage on a late beetle steering shaft with a super beetle u joint shaft? I also have an older column but the end of that has been cut off. If I could get a stub for that to weld on i still need to connect to the steering box. Havent cutthe hole in the body yet and just starting the roll bar so open to suggestions
Mike. _________________ Member of NIVA |
