IRS Bolt on Like BusBoys (Are They Out of Biz?)
Page: Previous  1, 2, 3
cdennisg
cdennisg is offline
PostPosted: Fri Aug 26, 2016 4:44 pm    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
sambaphil wrote:
I am good at wonky. i will be marking things up to get back to where i was. I bought a "white" sharpie which is pretty cool.
Can't be too bad though, its just angles. Crap...just jinxed myself. Smile
I don't even bother with calculating angles. Just make measurements to the floor from the same point every time. When you reach your desired change in height, bolt that stuff back together.
sambaphil
sambaphil is offline
PostPosted: Sun Aug 28, 2016 9:48 am    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
Hey All,
Just as a sanity check here. Does +3 mean "clockwise?" And -3 mean counter clockwise?
UPDATE: Found This Useful Chart
Link to 1966 Samba Build
http://www.thesamba.com/vw/forum/viewtopic.php?t=607420
Link to 1971 Bay Bus - Clipper - L
https://www.thesamba.com/vw/forum/viewtopic.php?t=671945&highlight=
Single Port Samba Phil
[email protected]
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger Gallery Classifieds Feedback
cdennisg
cdennisg is offline
PostPosted: Sun Aug 28, 2016 10:02 am    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
sambaphil wrote:
Hey All,
In the middle of it now....
That depends on which side of the bus you are working.
Just make sure you do one in each direction to gain the change you want. When you have your hands on it, and think about what is happening, the light bulb will go on in your head again and it all becomes really, really simple.
sambaphil
PostPosted: Sun Aug 28, 2016 10:15 am    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
cdennisg wrote:
sambaphil wrote:
Hey All,
That depends on which side of the bus which you are working.
Got it...now just eyeballing and using level and tape measure after rolling it around. Looking good, needs a few 1/4 inches lower on one side. Thanks for all your help.
[email protected]
CapnMark
CapnMark is offline
PostPosted: Fri Nov 04, 2016 9:31 pm    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
I have a '57 11 window and am seriously considering either a Wagenswest or Wolfgang IRS. They seem fairly similar and prices are the same - what are other people's experiences?
I like the idea of being close to stock height and Wolfgang advertise that running a Type 181 IRS transmission with 181 CV joints will allow you to do this, but have read numerous comments about CV boots failing, presumably due to the large angles. How realistic is stock height with IRS and if not reliable, what is the minimum sensible drop in height I would need to get this working right? I am looking for reliability and driveability. Could I fit 181 CV joints into a T1 transmission?
Yes, a lot of questions, but I want to get it right! Thank you!
joe56vw
joe56vw is offline
PostPosted: Sat Nov 05, 2016 6:43 pm    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
Wagenswest kit comes with spacers that push the CVs out farther from the tranny which would make clearance not an issue
I bought the wagenswest kit and it looks awesome but i haven't installed it yet so can't comment on that but personally i have had several bad experiences with wolfgang and would never buy anything from them again
'60 15 window walkthrough
why is there no sarcasism button on here?
truckersmike
Elder Sambanite
truckersmike is offline
PostPosted: Sun Nov 06, 2016 10:29 am    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
Phil, I hope to see your IRS conversion at some point. I have some interest in doing this for my camper but it seems like it's a pretty involved (and expensive) set up.
What is the gearing in your transaxle? My big nut has a 3:88 R&P with stock size tires. I'm curious how much taller the gearing is in comparison.
59 DD panel. Former Romano's TV delivery bus
67 Westy SO-42 pop-t
pyrOman
Fire Master
pyrOman is offline
PostPosted: Mon Nov 07, 2016 7:32 am    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
I did my own "conversion" using late phatchick parts. It ended higher than stock by about an inch. Yes, at the extreme angle for both inner Bug and outer bus CVs but run fair enough at least for me. I could go a bit lower but then I have to lower the front beam too. And yes on the need to replace boots a bit more often than could be, but it is way easier than than of straight axles. The best thing is the ease to install/remove the center section transaxle! Razz
Did this way back in the fall of '09 and it's still running great! No regrets! Cool
To "IRS" or "not to IRS", that is the Q
CapnMark
CapnMark is offline
PostPosted: Tue Nov 08, 2016 10:22 am    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
Thanks for the responses. It looks like the way forward.
Harleyelf
Harleyelf is offline
PostPosted: Tue Nov 08, 2016 11:18 am    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
Yes, you can use a type 1 transmission with 181 CV joints. You just have to change out the drive stubs on the transmission. They use the same snap rings as the CV joints. The joints will clear your transmission mount horns by a few mm.
sambaphil
PostPosted: Fri Nov 11, 2016 10:40 pm    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
Hey Mark,
So I was one of the first stock height buses using this kit from Wagonswest. In the end, it turned out that I used large angle CVs on both outer and inners. Nate shipped me bus cups for the inner so the large angle CVs fit. Nate makes quality stuff, rear brakes, rebuilt IRS trans with 3.88RP, new bus axles. Nate helped me get it all dialed in.
For me, it was more than worth it. My bus looks totally stock, but it cruises at 65 and is stable even in wind. If you can cut and weld, its a do it your self situation.
[img]https://www.thesamba.com/vw/gallery/pix/1574886.jpg[/img
[email protected]
CapnMark
CapnMark is offline
PostPosted: Sat Nov 12, 2016 4:20 pm    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
Thanks Phil. I think I am leaning towards the bolt in kit, purely because I don't want to cut my bus, although the weld in kit probably works better if I can get past that. I spoke about this at length with Joel from Rusties at a couple of shows this summer, after he did your conversion. I think I'll give Nate a call this week and try to establish exactly what I am going to do.
What brakes are you running on the back of yours? I have been considering 944 discs, partly because I already own a set complete with trailing arms, but I'm concerned that they may widen my rear track too much by the time I add wide 5 adaptors.
Nice looking bus, by the way!
Busstom
Busstom is offline
PostPosted: Sat Nov 12, 2016 11:02 pm    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
CruisinMark wrote:
What brakes are you running on the back of yours? I have been considering 944 discs, partly because I already own a set complete with trailing arms, but I'm concerned that they may widen my rear track too much by the time I add wide 5 adaptors...
Mark, if you go this route, let me know if you still need the wide-5 adapters. I believe I have the config you would need (5-130 hub to 5-205 wheel), and I'd cut you a great deal, they are new, from Wolfgangs, and I'm not running them. I only need one to use for my tire changer, so that oddly leaves me 3 extra. I'm guessing you'd only need two.
I can't comment on how wide your wheel track would get, but I did narrow mine a half inch per side by sliding the bolt-on IRS brackets in toward the horns and mounting my trailing arms INSIDE the spring plates. I have custom off-road trailing arms in Type-1 config.
cory464 wrote:
sambaphil
PostPosted: Sun Nov 13, 2016 9:28 am    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
CruisinMark wrote:
Thanks Phil.
Hey Mark,
As a part of Nate's kit, he shipped spring plates, backing plates, brake cables, trailing arms, and rear drums from a 70 bus. They were totally assembled and ready to bolt on.
As far as a bolt on IRS kits, that is what I wanted and tried to go with the busboys bolt on kit but they are out of biz. The Wolfgang ones could work. I even tried to buy a kit from Australia without luck. Talk to Nate. He will give you his perspective and input. Let us know what you do!
[email protected]
CapnMark
CapnMark is offline
PostPosted: Sun Nov 13, 2016 9:30 pm    Post subject: Re: IRS Bolt on Like BusBoys (Are They Out of Biz?) Reply with quote
Thanks Gent's.
I'll give Nate a call this week and see what he suggests. He also does a Type 1 bolt in kit, which if I use T2 or 944 CV joints with, I should be able to stay up in the nosebleeds.
The reason that I was asking about track width, is that I was running a straight axle conversion last year and could not get the wheels off if I got a puncture. I had around 3mm of clearance on the wheelarch lip each side. That said, it was at least 3 1/2 inches lower than stock.
Busstom, thank you for the offer. If I decide to go with the 944 setup, I will get in contact with you.
Page 3 of 3
