davidyat Samba Member
Posted: Mon Jan 02, 2017 7:43 am Post subject: Don't do what I did during an engine rebuild |
So I'm rebuilding my 1967 Beetle engine. I get to the installation of the thermostat that controls the opening and closing of the vanes inside the fan shroud. To check if the thermostat is working, I put it near a heater in my garage. I get distracted with the engine. Time goes by. I look back at the thermostat and it has expanded from about 1 inch to almost 12 inches. YIKES!!! It stretched so far out of shape that it never went back to its' original size. It was like when you stretch a spring too far. Take the advice of most mechanics, boil some water and place the thermostat near or in it. When you see it move, TAKE IT OUT!!!! IT IS WORKING!!
Good luck on your rebuild |
diablosandwich Samba Member
Joined: January 15, 2012 Posts: 508 Location: Illinois
Posted: Mon Jan 02, 2017 7:46 am Post subject: Re: Don't do what I did during an engine rebuild |
Happy new year. It is best to test it in the thermostat bracket so this does not happen. Casey _________________ 1966 Java Greens |
Posted: Mon Jan 02, 2017 8:27 am Post subject: Re: Don't do what I did during an engine rebuild |
Even better advice. Keep it in the bracket. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11038 Location: Oregon
Posted: Mon Jan 02, 2017 8:34 am Post subject: Re: Don't do what I did during an engine rebuild |
Welcome to the samba.
We all get distracted from time to time. Hell I got distracted a few weeks ago and damn near burned down my car and house when I left a fuel line off a carb and started my engine
The up side is that you can still find thermo-stats in the classifieds and at swap meets. Just be careful with the next one.
Please post some pics of what you are working on.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13947 Location: White Mountains Arizona
Posted: Mon Jan 02, 2017 4:23 pm Post subject: Re: Don't do what I did during an engine rebuild |
Yep you trashed that thermostat. Boiling water is for water cooled engines. Keep it in the thermostat bracket, use a blow drier on it carefully only to test it. Do not buy one that is expanded. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11787 Location: Redding, CA
Posted: Mon Jan 02, 2017 6:07 pm Post subject: Re: Don't do what I did during an engine rebuild |
Gt's method is the best. A good thermostat will open very quickly, using a blow dryer set on high.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Joined: April 27, 2002 Posts: 6738 Location: Pentwater, Michigan
Posted: Mon Jan 02, 2017 6:44 pm Post subject: Re: Don't do what I did during an engine rebuild |
It'd be kinda fun to see a pic of that thermostat, actually:
I've seen them over extended by an inch or two but never that far. _________________ Roads Scholar
Member# 2059 |
