25hp engine number 440556
Terry Gaudet
Terry Gaudet is offline
PostPosted: Wed Jan 04, 2017 9:50 am    Post subject: 25hp engine number 440556 Reply with quote
Hi there,
If anyone can help me with this engine number, it would be very much appreciated. The engine numbers in the Technical chart above only start in late 48. I presume this engine would be early 48? Please help.
Terry Gaudet
1950 Beetle Standard
1955 Canadian Custom
1956 Kombi w/SO23 kit
1965 Kombi walkthrough
1965 Double Cab
Bengt H
Bengt H is offline
PostPosted: Wed Jan 04, 2017 12:41 pm    Post subject: Re: 25hp engine number 440556 Reply with quote
Its from june -52 Very Happy
h~moto
h~moto is offline
PostPosted: Wed Jan 04, 2017 2:41 pm    Post subject: Re: 25hp engine number 440556 Reply with quote
Why does the engine number not start with 1-0?
nlorntson
Crazy VW Lady
nlorntson is offline
PostPosted: Thu Jan 05, 2017 5:18 am    Post subject: Re: 25hp engine number 440556 Reply with quote
The square stamp says it's a replacement engine so could be anything.
sotos
sotos is offline
PostPosted: Thu Jan 05, 2017 10:48 am    Post subject: Re: 25hp engine number 440556 Reply with quote
You can check the engine case for casting dates, here is a link with more info :http://www.thesamba.com/vw/forum/viewtopic.php?t=430442
and another one...
http://www.thesamba.com/vw/forum/viewtopic.php?t=380362&postdays=0&postorder=asc&start=0
http://www.komenda-porsche-designer.at/
Oval53 (June)
Beetle 1.3 1966
New beetle 1.6 2003
nlorntson
Crazy VW Lady
PostPosted: Thu Jan 05, 2017 3:32 pm    Post subject: Re: 25hp engine number 440556 Reply with quote
and another one...
This only tells you when it was cast. I had a replacement engine in my 49 when I bought it that was 25hp but cast in 1956. Documentation indicates that in fact it was replaced in 1956.
sotos
sotos is offline
PostPosted: Thu Jan 05, 2017 4:57 pm    Post subject: Re: 25hp engine number 440556 Reply with quote
nlorntson wrote:
and another one...
That's interesting, I wonder if this one too was cast beyond the 25 hp era.
Certainly casting date will give strictly manufacturing date of the engine case on a serial or replacement engine not when assembled or when fitted.
Oval53 (June)
Beetle 1.3 1966
New beetle 1.6 2003
Terry Gaudet
PostPosted: Thu Jan 05, 2017 5:33 pm    Post subject: Re: 25hp engine number 440556 Reply with quote
Thanks for the info everyone. I will check the casting dates and advise.
Terry Gaudet
1965 Double Cab
2003nbc
2003nbc is offline
PostPosted: Thu Jan 05, 2017 6:52 pm    Post subject: Re: 25hp engine number 440556 Reply with quote
If the number stamp shown is a KD engine number sequencing (VW exchange engine serial number) then based upon the list found in the June 2001 VVWCA newsletter it was rebuilt in August 1960.
nlorntson
Crazy VW Lady
PostPosted: Thu Jan 05, 2017 9:57 pm    Post subject: Re: 25hp engine number 440556 Reply with quote
That would be a great resource to add to this site if you're willing.
PostPosted: Thu Jan 05, 2017 10:29 pm    Post subject: Re: 25hp engine number 440556 Reply with quote
Yes, I was just thinking that too - can you send me some photos or the data and I'll add it to the site?
Terry Gaudet
PostPosted: Sat Jan 07, 2017 9:22 pm    Post subject: Re: 25hp engine number 440556 Reply with quote
So how did the factory remove the original stamped numbers to put in new ones? Machine the surface down?
Terry Gaudet
1965 Double Cab
2003nbc
2003nbc is offline
PostPosted: Sun Jan 08, 2017 10:25 am    Post subject: Re: 25hp engine number 440556 Reply with quote
It seems your engine rebuild was based upon a new replacement case, its life started in the Kassel rebuilding works rather than in a new car. As seen in your photos the stamp pad has never been machined. If it had been a used case it would have retained the original S/N with the KD rebuild number stamped on the side of the generator stand or possibly another place. Example from the photo gallery.
The case casting marks described by Sotos above will tell the date of casting.
Some Background:
In the June 1960 edition of FOREIGN CAR GUIDE has an article about VW’s Kassel rebuilding works. It tells the history and details the engine rebuilding process with text and photos. The facility is described as a special factory for rebuilding everything from windshield wiper motors to engines and transmissions. The article states that VW's from the early 50' s are now in need of rebuilt engines. It states that the plant opened in June of 1958 and produced 88,000 engines in the first 13 months along with 26,300 transaxles. (the 88,000 is a close match to the 13 month sequence of serial numbers found in the VWCA article). It goes on to state that the daily average for engines was 430 along with 130 transaxles. The cost was $247 for rebuilt engines as compared to a new engine cost of $440; rebuilt transaxles were $219 and new were $299. It includes 9 photos of factory workers performing various tasks and one interesting photo of the ultra-rare 36 HP with the generator pedestal on the left (photo image reversed!).
The article says approximately the same number of used engines enter the plant each day as are produced each day, it goes on to say “ Rebuilts for export are packed in full crates with weatherproof wrappings. A block which started life in Wolfsburg and traveled to Australia may find itself starting life again in Africa, Sweden, or anywhere else.”
It details why purchasing an exchange can be more economical and timely as compared to a local rebuild.
pastellgreen
pastellgreen is offline
PostPosted: Sun Jan 08, 2017 2:32 pm    Post subject: Re: 25hp engine number 440556 Reply with quote
The number area from op does not look machined to me? If it was a exchange part it would have two numbers, the old one remains at the old place, the second new number from rebuild would be stamped on the rihght side in vertical position as shown on the picture. Is that the case with the op engine the question was about?
Terry Gaudet
PostPosted: Mon Jan 09, 2017 3:59 am    Post subject: Re: 25hp engine number 440556 Reply with quote
Hi Pastel,
The case I'm inquiring about is the photo in the top of my post. #440556.
Terry Gaudet
1965 Double Cab
2003nbc
2003nbc is offline
PostPosted: Mon Jan 09, 2017 8:36 pm    Post subject: Re: 25hp engine number 440556 Reply with quote
Some KD rebuilt engines had a new case rather than a used one. Thus as it appears to be the situation for 440556 only one number stamp is found, positioned on the front. See excerpt below from 1960 article previous mentioned.
Terry, check and see where the oil drain plug located?
nlorntson
Crazy VW Lady
PostPosted: Mon Jan 09, 2017 9:39 pm    Post subject: Re: 25hp engine number 440556 Reply with quote
Please share your document with the site!
2003nbc
2003nbc is offline
PostPosted: Sat Jan 23, 2021 10:21 am    Post subject: Re: 25hp engine number 440556 Reply with quote
KD engine rebuilding article:
