tewfiks Samba Member
Joined: February 19, 2016 Posts: 100 Location: Tallahassee
Posted: Tue Jan 10, 2017 12:16 pm Post subject: camshaft bearing tight |
The Eagle racing cam that I purchased from CB performance for my type 4 rebuild is quite snug on the forward most bearing. Is this something that I should be concern with or shall I continue on with the reassembly with the thought it will seat itself with time.
The bearing itself sits in the car without issue, but with the cam installed it binds a bit to the cam. The original camshaft does not have this issue when placed in the case. _________________ 1968 VW Bus
1972 VW Westy |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17768 Location: San Diego, California
Posted: Tue Jan 10, 2017 12:31 pm Post subject: Re: camshaft bearing tight |
Is the cam bent? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Danwvw Samba Member
Joined: July 31, 2012 Posts: 8895 Location: Oregon Coast
Posted: Tue Jan 10, 2017 12:49 pm Post subject: Re: camshaft bearing tight |
For sure find out why it's doing that before putting the case together. If it were the thrust bearing I would say just tap the cam on the gear end with a hammer to set it. That's what I do on the type 1's not sure about a type 4. They behave a little different with the oil pump in also. One test I do is with the crank in 1/2 the case with the cam and turn the crank so it's lifting the cam up where the two gears meet. The cam should not ride up out of place doing that test. But again my experience doing this is with a Type 1 engine. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10804 Location: the past
Posted: Tue Jan 10, 2017 1:24 pm Post subject: Re: camshaft bearing tight |
i am reading this as though the flanges of the cam bearing are pinching in between the machined faces of the cam, a front-to-rear issue, and relatively common issue with aftermarket cams and some bearings.
if that is correct, you can *carefully* sand the face of the bearing for clearance.
gallery images by zac_atac44
Posted: Tue Jan 10, 2017 3:58 pm Post subject: Re: camshaft bearing tight |
YES that is the exact issue I am facing.
I will try and tap on it and see if that takes care of the issue.
The cam does ride up when turning as it sits currently.
Thanks _________________ 1968 VW Bus
1972 VW Westy |
Danwvw Samba Member
Posted: Tue Jan 10, 2017 5:27 pm Post subject: Re: camshaft bearing tight |
Yes, Tap it a little to see if the thrust bearing will seat better and yes I have had to sand them too. Sometimes it's a bad cam gear or the crank gear does not match the cam gear very well, Is this the original cam and gear or is it a bolted on gear? The Cam gear should not have noticeable runout. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
bigbore Samba Member
Joined: December 19, 2003 Posts: 3297 Location: Wasilla Alaska
Posted: Tue Jan 10, 2017 6:13 pm Post subject: Re: camshaft bearing tight |
I have also had the fit the thrust bearing before and heres some more fun facts.
I have been lineboring some type one case's the last few days and I always run my cam bore tool mine is old school it only cuts the center bore it just cleans it and make it round again mostly in the type ones the pounding the cast takes makes the cam bore oblong and when you put all new bearings in the cam gos tight so this is the fix.
now the new cam lingbores do all three bores but for the most part the center is the offender.
Also when putting a bolt on gear cam in a type 4 if you are using the oem style pump check to make sure the cam bolts don't hit the pump studs or nuts. _________________ where its cold and snowy |
Danwvw Samba Member
Posted: Tue Jan 10, 2017 7:40 pm Post subject: Re: camshaft bearing tight |
That is interesting, I did not know that center cam bearing could need so much attention, and I don't know any VW shops around me that can do that! But With the type 4 engine I bet that does not happen. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42970 Location: at the beach in Northern Wokistan
Posted: Tue Jan 10, 2017 7:52 pm Post subject: Re: camshaft bearing tight |
This is what I found on my T4
End clearance with reground cam and mahle bearings .006"
End clearance with new webcam and mahle bearings .003"
End clearance with reground cam and Kolbenschmidt bearings .0045"
End clearance with new webcam and Kolbenschmidt bearings .0015"
Guess which combination I went with. _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
Danwvw Samba Member
Posted: Tue Jan 10, 2017 8:22 pm Post subject: Re: camshaft bearing tight |
The thing I don't understand about cutting the cam bearing journals is wouldn't they become oversized? Are there oversize bearings?
Posted: Tue Jan 10, 2017 8:28 pm Post subject: Re: camshaft bearing tight |
Brilliant. A little sanding with 1200 grit sandpaper and I now have a happy spinning camshaft.
Thanks a ton. _________________ 1968 VW Bus
1972 VW Westy |
SGKent  Samba Member
Posted: Wed Jan 11, 2017 9:19 am Post subject: Re: camshaft bearing tight |
as to sanding Babbitt. Please don't.
Try this experiment - drop a stick of butter into gravel and sand, then rub it on something painted or on a piece of scrap glass. The softer butter picks up the abrasive and scratches things. Babbitt is softer than the sandpaper. It will pick up small particles of sand paper and forever grind on the cam thrust bearing surfaces. Instead use a Babbitt knife, even the flat blade of a barlow knife can be used to scrape the bearing to get clearance. It won't leave grit in the Babbitt like sanding will. _________________
George Carlin:
Danwvw Samba Member
Posted: Wed Jan 11, 2017 12:16 pm Post subject: Re: camshaft bearing tight |
You don't sand the bearing surface. Just the outside thrust flange. But usually they will seat with just the a tap on the end of the camshaft with a hammer one maybe 2 taps. Good tap not too weak but not a blow. But It's a good point about the Butter holding the sand. I would never put butter in sand.
The sand probably gets everywhere on all the bearings. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
Posted: Wed Jan 11, 2017 1:54 pm Post subject: Re: camshaft bearing tight |
[quote="Danwvw"]The thing I don't understand about cutting the cam bearing journals is wouldn't they become oversized? Are there oversize bearings?
The cutter is standard size it just makes the hole round again. the type 4 cases seam to not have this problem. _________________ where its cold and snowy |
SGKent  Samba Member
Posted: Wed Jan 11, 2017 2:05 pm Post subject: Re: camshaft bearing tight |
| Danwvw wrote: |
You don't sand the bearing surface. Just the outside thrust flange. But usually they will seat with just the a tap on the end of the camshaft with a hammer one maybe 2 taps. Good tap not too weak but not a blow. But It a good point about the Butter holding the sand. I would never put butter in sand.
The sand probably gets everywhere on all the bearings. |
since I've learned not to sand bearings of any kind including thrust surfaces by two totally different well skilled machinists for the same reason - the softer material will take the harder abrasives released in sanding I choose not to do it. All the cam bearing adjustments made are done with a special knife. It leaves no residue. One can use a little Prussian blue dye or a sharpe if they want to avoid high and low spots. _________________
George Carlin:
williamM Samba Member
Joined: August 07, 2008 Posts: 4343 Location: southwest Arizona
Posted: Wed Jan 11, 2017 2:21 pm Post subject: Re: camshaft bearing tight |
The center cam bearing goes oval a very small amount and the case hammers out a little- so when the case is put back together -empty-it compresses a small amount. Then forms a round stock sized hole when the cutter is used ---that "gap" is pulled up tight when the case is torqued with the cam and bearing in there to original spec.. If really bad it can effect the cylinder seats and require a flycut on the block where the cylinders fit.
X2 kent- that piece is called a bearing scraper. Its a triangle file like tool but hallow ground to a knife edge on each side for clearing the babit away from oversized bearing. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
SGKent  Samba Member
Posted: Wed Jan 11, 2017 2:43 pm Post subject: Re: camshaft bearing tight |
| Quote: |
| X2 kent- that piece is called a bearing scraper. Its a triangle file like tool but hollow ground to a knife edge on each side for clearing the babit away from oversized bearing. |
yes. This is like the ones we used.
George Carlin:
Posted: Wed Jan 11, 2017 2:55 pm Post subject: Re: camshaft bearing tight |
| SGKent wrote: |
| Quote: |
Thats it first used for babit bearing cast into the block using a form clamped to the iron block- then scraped by that tool to the right clearances. _________________ some days I get up and just sit and think. Some days I just sit.
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2238 Location: Bulli Klinik, Colorado Springs
Posted: Thu Jan 12, 2017 5:26 pm Post subject: Re: camshaft bearing tight |
Prior setting camshaft end-play, polish this surface. Many cams are very rough on the thrust surface. It's it's rough, it will continue to wear the thrust surface.
Once the thrust is polished, set the end play by surfacing the thrust bearing to .001. I use sandpaper, apparently others use babbit scrapers.
If you also de-burr the edge of the lobes, it's easier on the lifters.
Also a good idea to check your oil hole alignment while it's apart.
Good luck! _________________ PM me about quality metal-work on your vehicle.
Mike K
Bulli Klinik
Colorado Springs |
Hoody Samba Member
Posted: Sat Jan 14, 2017 1:48 am Post subject: Re: camshaft bearing tight |
| The last thing you want to do is introduce ANY type of "sanding" material to your aluminum bearings. As stated there are correct ways to clearance them. It's kid of like having sex on the beach.....if one single grain of sand is introduced excessive wear and painfull lessons are imminent. |
