69sunroof Samba Member
Joined: May 24, 2013 Posts: 7 Location: Springfield Oregon
Posted: Sun Nov 08, 2015 4:02 pm Post subject: Weber IDF fuel enrichment parts |
I bought a pair of Weber IDF 40 carbs used and the PO put on the fuel enrichment block off plates but removed the Pistons and springs and keepers so the carbs run way too rich. I can't find these parts anywhere, does anyone have any information on where to get them? Thank you |
Derek Cobb Annoying
Posted: Sun Nov 08, 2015 4:09 pm Post subject: |
They don't get used in most VW applications. They are damned near impossible to get replacements for, but all you need to do is tap and plug the hole in the base of the carburetor. A couple of small set-screws and the right sized tap and you'll be all set. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20816 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Nov 08, 2015 4:32 pm Post subject: |
Derek Cobb wrote: |
Easiest fix... Yeah...
If you want the actual pistons you might get them here..
http://piercemanifolds.com
Dale _________________ “Fear The Government That Wants To Take Your Guns"
Posted: Sun Nov 08, 2015 5:34 pm Post subject: |
Not sure what I'm not understanding here, but when I have carb apart and spray carb cleaner in that bottom hole it doesn't seem to go anywhere |
Posted: Sun Nov 08, 2015 8:49 pm Post subject: |
The ports on bottom should direct connect to enrichment plunger bores... If you can not get carb cleaner through then its possible ports/passages are already plugged....
You should be able to follow the passage becasue of the obvious casting bulges that define passages and find either they are plugged or not even drilled...
Posted: Sun Nov 08, 2015 9:20 pm Post subject: |
Thanks for your input. I thought that the cleaner should spray through, it looks like it should. Maybe they are not drilled and carbs never had plungers in there to begin with. I guess that's why all of the exploded views of IDF carbs don't show those parts. Perhaps the rich condition I experienced was due to too large of jets or maybe someone drilled them out. I will have to investigate that |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Sun Nov 08, 2015 9:23 pm Post subject: |
69sunroof wrote: |
let us know - it would be good Weber general tuning knowledge  |
Posted: Mon Nov 09, 2015 9:20 am Post subject: |
69sunroof wrote: |
New EMPI HPMX (generation 3) has completely done away with everything to do with enrichment circuits, they have new casting that don't even have openings for cover plate...
dwebb8490 Samba Member
Joined: June 04, 2013 Posts: 1 Location: Danville, IL
Posted: Fri Nov 27, 2015 7:15 am Post subject: Re: Weber IDF fuel enrichment parts |
My older 44 IDF's were never drilled for the enrichers, not all carbs had them. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3843 Location: The Woodlands, TX
Posted: Tue Jan 17, 2017 8:25 am Post subject: Re: Weber IDF fuel enrichment parts |
If the springs/plungers are installed, and the choke attachment is blocked off (block off plate installed), is there any reason to tap and plug the ports? |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3804 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Tue Jan 17, 2017 1:06 pm Post subject: Re: Weber IDF fuel enrichment parts |
txoval wrote: |
No. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23950 Location: SHALIMAR ,FLORIDA
Posted: Thu Jan 19, 2017 1:13 pm Post subject: Re: Weber IDF fuel enrichment parts |
probably not. but I havent for my self traced the entire circut. I have however got brain fade and shot that shit across the shop........ but withen a hour or so(2) I had it back togeather. I was thinken about trying to use that system for a AC kick up.....but I doubt I will need it...I hope. |
txoval Samba Member
Posted: Thu Jan 19, 2017 2:57 pm Post subject: Re: Weber IDF fuel enrichment parts |
Yeah, first time I messed with the damn things, the spring shot the washer across my damn garage. I looked all over the place and was about to give up.
Somehow it landed in the carb throat of the carb that was sitting next to it...damn near straight up and down. I was crawling all over the floor like an idiot |
Posted: Thu Jan 19, 2017 4:47 pm Post subject: Re: Weber IDF fuel enrichment parts |
[quote="txoval"]Yeah, first time I messed with the damn things, the spring shot the washer across my damn garage. I looked all over the place and was about to give up.
Somehow it landed in the carb throat of the carb that was sitting next to it...damn near straight up and down. I was crawling all over the floor like an MARK.
there I fixed itr for ya.... I was so stupid i did it 2 times. once about 13 years ago when I got the carbs new and was blowing them out , and again....last week funny think I knew to put my fin gers over them on the first carb I did last week but the next day.....on the floor I went. I dont have shit fer brains....not sure I have any brains up there at all. |
Posted: Thu Jan 19, 2017 8:07 pm Post subject: Re: Weber IDF fuel enrichment parts |
mark tucker wrote: |
We have known that for quite some time....
Posted: Sat Jan 21, 2017 12:53 pm Post subject: Re: Weber IDF fuel enrichment parts |
but it's the ones with shit for brains you have to watch out fer.....I think there brains are peddle operated.. ..they seen to always be peddling some shit.. ..usually over priced&hyped up shit...  |
