1990 Westfalia: No reverse
gti72
gti72 is offline
PostPosted: Fri Feb 03, 2017 3:18 pm    Post subject: 1990 Westfalia: No reverse Reply with quote
hi my reverse stop working on my vanagon,,,,could that be internal or somethings else...thanks
candyman
Samba Trout Slayer
candyman is offline
PostPosted: Fri Feb 03, 2017 3:23 pm    Post subject: Re: no more reverse westfalia 1990 Reply with quote
If it came on suddenly, likely something in the linkage. Either where the shifter meets the floor (common) or under the van in the shifter box or center shifter connection. First step is t see if you can manually put it in reverse at the trans selector shaft to make sure its nothing internal to the trans. If that checks out, then you will need to work your way back to the shifter. Without many details or history on this, i put my money on linkage needing adjusting
kamzcab86
kamzcab86 is offline
PostPosted: Fri Feb 03, 2017 4:22 pm    Post subject: Re: 1990 Westfalia: No reverse Reply with quote
Does this van have a manual or automatic transmission?
2016 Golf GTI S
candyman
Samba Trout Slayer
candyman is offline
PostPosted: Fri Feb 03, 2017 4:32 pm    Post subject: Re: 1990 Westfalia: No reverse Reply with quote
Good point.
gti72
gti72 is offline
PostPosted: Fri Feb 03, 2017 6:05 pm    Post subject: Re: 1990 Westfalia: No reverse Reply with quote
sorry guys auto trans
cmayna
cmayna is offline
PostPosted: Fri Feb 03, 2017 7:06 pm    Post subject: Re: 1990 Westfalia: No reverse Reply with quote
Maybe the switch down below the shifter needs adjustment?
'90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig
