Posted: Tue Sep 03, 2002 6:38 am Post subject: 71 super |
| I have a 71 SB that some one took the ignition switch out of and just left the wires there also the fuse box is a mess. I was just wondering if there was a easy way to get the engine running without rewiring the entire thing I just want to here it run so I will know if the engine is any good. Thanks |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Tue Sep 03, 2002 9:07 am Post subject: 71 super |
Hook up a wire from the positive side of the battery to the positive on the coil...(says 15 on a bosch coil)
the one with the wires that go over to the carb soleniod and choke.... not the side that has the condeser wire plugged on it...
Then with the car blocked and sure it's IN NEUTRAL slide under and jump the starter motor with and old screwdriver( or a clip on mechanics testing starter button if you know someone with one) while someone works the throttle lever.... maybe pour a shot of gas down the carb ect....
I don't know what your skill level is so I'm sorry if I am throwing out some obvious stuff.... good luck.... |
Posted: Tue Sep 03, 2002 9:10 am Post subject: 71 super |
| Thanks for the info I will give it a try |
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Tue Sep 03, 2002 6:13 pm Post subject: 71 super |
| Keith: I am not that familiar with superbeatles ,but don't the supers have the connector under the back seat for the starter switch wire like the regular beatles so you can disconnect it and jumper it to the battery to engage the starter without getting under the car? |
Posted: Tue Sep 03, 2002 6:54 pm Post subject: 71 super |
Well yeah they do Tim, But I just thought that might make things ....to easy?
I dunno, I guess I was saving that info for.... I dunno.... Tim why are you harassing me so???? why the hell diddn't you just jump in and say...( Tim should have said something like this...
"It's also possible to use the red wire in the grey sheath with the clearish plastic connector that goes through the back of the pan near the metal brake line.... separate the conection there and jump it to the battery and the starter will engage...")
Thanks Tim.... good point.....  |
TimGud Samba Member
Posted: Wed Sep 04, 2002 6:26 am Post subject: 71 super |
Well... I wasn't sure and that would not have been nearly as much fun as giving you a hard time at the same time.  |
Posted: Wed Sep 04, 2002 7:10 am Post subject: 71 super |
| What a pal! |
Posted: Wed Sep 04, 2002 4:24 pm Post subject: 71 super |
| Thanks guys I am very new to this I have a 7 year old daughter that has a facination with these bugs and all of a sudden I have 6 of them some run some don`t so any help I can get is welcome. |
Posted: Wed Sep 04, 2002 6:13 pm Post subject: 71 super |
No problem, Tim and I kid around alot anyway... anytime you need help there are lots of folks who are here to help....
Only 6???? your just getting started!
What years and models? which ones have the most potential.... ? later.... K |
Posted: Fri Sep 06, 2002 3:09 pm Post subject: 71 super |
| I have 2 71`s a 69 standard beetle with an autostick, a 73, and a 74 I also have a meyers manx dune buggy that is built on a 64 chassis but it has been converted to 12 volt and a 73 engine out of a super beetle I also have an early 70`s convertible that is completly junk other than a few odds and ends My 2 71`s are in the best shape the rest are for parts I guess The dune buggy I have owned for about 18 years and is a great toy. |
Posted: Fri Sep 06, 2002 6:48 pm Post subject: 71 super |
| Sounds like home.... there's no place like home..... Well... good luck with the projects.... get a digicam and put up some pics of the parts in the want ads.... your sure to sell some stuff... Say area the 73 and 74 supers? e- mail me I need some stuff..... |
Posted: Sat Sep 07, 2002 2:09 pm Post subject: 71 super |
| The 73 and 74 are super beetles what do you need? |
Posted: Mon Sep 09, 2002 8:27 am Post subject: 71 super |
| I'll e mail you... K |
