Pedro's bus - 67' sea blue standard
iamdonquixote
iamdonquixote is offline
PostPosted: Mon Feb 29, 2016 8:02 pm    Post subject: Pedro's bus - 67' sea blue standard Reply with quote
I've never done a thread on a bus so here it goes...
Heard about this one via the grapevine back in December and felt it worth my time.
A 67' sea blue standard. The PO had purchased it about a year or so ago as a running/driving original paint bus but stripped all the paint off it, took all the parts off it ( including running gear ) and put it inside the bus. He then proceeded to leave it outside and overdose and die Sad. His name was Pedro, so I call it Pedro's bus.
Built the same day (Jan 2 67' ) as my so42 ( 20 serial numbers apart ). This was the unseasonably warm December day I went to get it..
Installing the front end..
Fortunately, all the hardware was to be found inside the bus.. I think a VW bus is one of the only vehicles that you can take ALL the parts off of and put them inside the vehicle.
Rolls nice, comes with most parts which are (mostly) useable.
Took it home and mechanically removed the surface rust and put rust mort on it.
Installed some missing sheet metal:
Now its this :
Which some of you might recognize from Crukab's threads Smile
Next step is to sand blast some areas and epoxy prime it.
iamdonquixote
PostPosted: Mon Feb 29, 2016 8:05 pm    Post subject: Re: Pedro's bus - 67' sea blue standard Reply with quote
Passenger side rocker panels and close out pieces are done, floor is in, plug welds are next...
pyrOman
Fire Master
pyrOman is offline
PostPosted: Tue Mar 01, 2016 7:26 am    Post subject: Re: Pedro's bus - 67' sea blue standard Reply with quote
Great save Quixo! Razz
Pinetops
Pinetops is offline
PostPosted: Tue Mar 01, 2016 7:54 pm    Post subject: Re: Pedro's bus - 67' sea blue standard Reply with quote
Nice! Looks like you're making fast progress too.
"A rolling bus gathers no rust."
asesapie
asesapie is offline
PostPosted: Tue Mar 01, 2016 8:09 pm    Post subject: Re: Pedro's bus - 67' sea blue standard Reply with quote
Nice save on the bus and some solid progress so far. Keep it up
Clara Premium Member
Clara is offline
PostPosted: Wed Mar 02, 2016 10:08 am    Post subject: Re: Pedro's bus - 67' sea blue standard Reply with quote
iamdonquixote wrote:
The PO had purchased it about a year or so ago as a running/driving original paint bus but stripped all the paint off it, took all the parts off it...
Shocked
I thought (hoped) people had quit doing that sort of thing.
Props to you for taking on the project!
MicBergsma
MicBergsma is offline
PostPosted: Thu Mar 03, 2016 4:49 pm    Post subject: Re: Pedro's bus - 67' sea blue standard Reply with quote
Awesome! I can't wait to do mine!
1967 VW Bus walk-thru 21 window deluxe
Restoration series on YouTube right now!
YouTube videos > http://bit.ly/2g0E5b5
Instagram > http://bit.ly/2gHjIOV
Facebook > http://bit.ly/2Q9atMs
iamdonquixote
PostPosted: Sun Mar 13, 2016 8:16 pm    Post subject: Re: Pedro's bus - 67' sea blue standard Reply with quote
on the body everything but the nose is sand blasted and epoxy primed.
here is the roof
iamdonquixote
PostPosted: Sun Mar 13, 2016 8:19 pm    Post subject: Re: Pedro's bus - 67' sea blue standard Reply with quote
next up is to clean up and blast the underside
iamdonquixote
PostPosted: Sun Apr 10, 2016 7:42 pm    Post subject: Re: Pedro's bus - 67' sea blue standard Reply with quote
been busy on pedro's bus,
the body is epoxy primed now,
the underneath has also been cleaned up Smile
iamdonquixote
PostPosted: Sun Apr 24, 2016 10:26 pm    Post subject: Re: Pedro's bus - 67' sea blue standard Reply with quote
still plugging along,
the underside has been painted with masterseries .
the front cross member is almost done, I'm getting closer to finishing the 'bottom bus' stuff.
brettsvw
brettsvw is offline
PostPosted: Mon Apr 25, 2016 3:44 am    Post subject: Re: Pedro's bus - 67' sea blue standard Reply with quote
Nice!
My 59 kombi build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=635003&highlight=
My buggy build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=558601&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807
crukab
Samba Chef
crukab is offline
PostPosted: Tue Apr 26, 2016 3:44 am    Post subject: Re: Pedro's bus - 67' sea blue standard Reply with quote
Looking good Rob !! Very nice of J.P. to let you borrow the Rotiss., those things make the job way easier......
Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon
splitlp
splitlp is offline
PostPosted: Tue Apr 26, 2016 7:15 am    Post subject: Re: Pedro's bus - 67' sea blue standard Reply with quote
Glad to see the project moving along! Also happy to see the rotiss in use rather than sitting.
Very thankful to have it passed on to me and be able to help others out with it's use.
After all Tom and his Dad did all the work making it Bus friendly!
Abscate
Abscate is offline
PostPosted: Tue Apr 26, 2016 7:22 am    Post subject: Re: Pedro's bus - 67' sea blue standard Reply with quote
I hope Pedro is smiling from up above..
iamdonquixote
PostPosted: Tue Apr 26, 2016 12:49 pm    Post subject: Re: Pedro's bus - 67' sea blue standard Reply with quote
jp!
thank you!!
splitlp
splitlp is offline
PostPosted: Tue Apr 26, 2016 5:30 pm    Post subject: Re: Pedro's bus - 67' sea blue standard Reply with quote
Glad to help out! I love the progress, and the story behind the project. every time one is brought back it keeps other's inspired to hunt them down and keep them on the road! It is nice to connect with people with a similar vice.
Keep up the good work!
iamdonquixote
PostPosted: Sun Aug 21, 2016 7:02 pm    Post subject: Re: Pedro's bus - 67' sea blue standard Reply with quote
a little progress to report.
the underside is done the bus is now on a homemade dolly. lower nose area is next.
iamdonquixote
PostPosted: Mon Feb 20, 2017 5:40 pm    Post subject: Re: Pedro's bus - 67' sea blue standard Reply with quote
the last major rust repair is well underway, both sides lower doglegs and front floor as well as the bottom A pillar are in. Finishing up the nose is next. Then some general cleanup and touch up on all the welded areas and another coat of epoxy primer.
iamdonquixote
PostPosted: Mon Mar 27, 2017 5:24 pm    Post subject: Re: Pedro's bus - 67' sea blue standard Reply with quote
nose is almost done, ran out of welding gas.
All metal work is almost done!
Stay tuned for primer, the plan is to put another coat of epoxy, followed by build primer coat.
One downside to the epoxy is that once it dries, re coating it will be a pain as it doesn't sand well.
[/img]
Page 1 of 7
