glideking Samba Member
Joined: February 02, 2013 Posts: 990 Location: California
Posted: Fri Apr 07, 2017 10:05 pm Post subject: repair frame rust |
I now know more about how VW made this than I ever wanted to know.
The wheeled painting cart was a handy hight as I had to do endless trimming to get things lined up.
Got the replacement frame section bolted up at the front beam mount by one bolt each side. This helps with alignment. Got the last remnant of old floor removed. Made a headlight support panel patch.
I have not done any welding. All I have ever done on this entire project so far is removing cutting and grinding. It is nice to see something look like it is coming together for a change.
Kurt _________________ "The more I get done the less it looks like I did anything"
1959 Single Cab Restoration"Funky Truck"
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...highlight=
1965 21 Window Restoration Thread (From old photos)
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1963 Panelvan build "Tyvanosaurus Wrecks"
http://www.thesamba.com/vw/forum/viewtopic.php?p=8351639#8351639 |
wcfvw69 Samba Purist
Posted: Fri Apr 07, 2017 10:15 pm Post subject: Re: 1963 Panelvan build "Tyvanosaurus Wrecks" |
Nice work Kurt.
As an ex auto/truck frame straightener, I'm wondering how you're insuring you have the frame height correct at the front frame horns? It would be easy to weld it in twisted a bit. Did you make templates of each frame rail before cutting the old ones out?
It would be nice if you could hang some frame gauges on the entire bus before the welding started. It would really help insure thing are level and not twisted. Of course, there's also the frame dimensions on this site as well for lengths and side to side measurements for squareness. _________________ Contact me at [email protected]
The Samba member since 2004.
sgellis Samba Member
Joined: July 06, 2016 Posts: 2206 Location: SW Nova Scotia, Canada
mandraks Samba Member
Joined: November 28, 2004 Posts: 7122 Location: Lawrenceville, Ga
Posted: Sat Apr 08, 2017 7:13 am Post subject: Re: 1963 Panelvan build "Tyvanosaurus Wrecks" |
glideking wrote: |
I will be checking the frame for twist throughout all welding with a laser. VW's own frame tolerances was only 2mm. I can do better than that.
Kurt |
at the same time, this is your opportunity to put your own twist on things. I like your methodical way of working through things, one step at a time, on surprise at a time... _________________ regards
Uli
ryans65 Samba Member
Joined: February 16, 2016 Posts: 1358 Location: Yulee FL
Posted: Sat Apr 08, 2017 9:54 am Post subject: Re: 1963 Panelvan build "Tyvanosaurus Wrecks" |
I'm two months in to my nose dissection and here you are grafting entire sections of busses together. Slow down you are making us look bad! Ha! |
Burlyhammer Samba Member
Joined: March 07, 2002 Posts: 1715 Location: Great north woods Maine
Posted: Sat Apr 08, 2017 10:11 am Post subject: Re: 1963 Panelvan build "Tyvanosaurus Wrecks" |
I'm with Ryan. I have been a month on one part of my frame and have been on it steady. I better get back to work. Kurt, your progress is impressive. |
Fifty-Eight Rag Samba Member
Joined: September 07, 2011 Posts: 936 Location: St. Louis, MO
far rider  Samba Member
Joined: August 30, 2005 Posts: 1008 Location: Rutland, VT
Posted: Sat Apr 08, 2017 12:46 pm Post subject: Re: 1963 Panelvan build "Tyvanosaurus Wrecks" |
That bus was lucky to find you. Good luck Kurt ! _________________ 67 zenith blue sunroof
Contentment; when what you have is what you want. |
Manfred58sc Samba Member
Posted: Sat Apr 08, 2017 6:19 pm Post subject: Re: 1963 Panelvan build "Tyvanosaurus Wrecks" |
Looks very good, well done! _________________ Fat chick owner/operator |
Posted: Sat Apr 08, 2017 8:12 pm Post subject: Frame rust repair door gap alignment |
Did somebody remind me to check my door gap alignment before I do any welding? I cleaned up the threads for the hinges with a tap and dug out some doors from the attic. Never throw anything away. The original doors are a pile of oxide now.
I am beginning to feel better about Wrecks' prognosis. I got these doors 15 years ago for Funky Truck replacements but turned out to be the wrong year for that project. They are ice picks alright but of the recessed variety. I was unaware of such subtleties back then. All is well though because they are the correct year doors for T Wrecks and I still have them. They are in great condition too. I finally get a break from finding new rust.
I welded the first two pieces together today. A milestone for this project. Headlight support patch. I will mess with fitting the other door tonight.Then I will CHECK DOOR GAP ALIGNMENT!
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15367 Location: Casa de Oro, California
Posted: Sun Apr 09, 2017 9:26 am Post subject: Re: repair frame rust |
This blows my mind that the front hoop and those two frame sticks are holding everything just fine. |
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2172 Location: Florida
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3543 Location: Wyoming,USA
Posted: Mon Apr 10, 2017 12:46 pm Post subject: Re: 1963 Panelvan build "Tyvanosaurus Wrecks" |
I think we all already know he is....... _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
