beetle683 Samba Member
Joined: July 19, 2015 Posts: 34 Location: United kingdom
Posted: Sun Apr 16, 2017 4:16 am Post subject: choke cable |
i have a 57 oval that i am returning to stock , i am taking out the later engine with auto choke and replacing it with the original 1200cc 30hp unit , this is in need of a manual choke , my question is , where is the original position of the choke knob on the dash (mine is RHD) and where does the cable run .. any info on this would be very much appreciated as i have searched only to find nothing specific for my year , thanks in advance 👍👍👍
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Sun Apr 16, 2017 4:37 am Post subject: Re: choke cable |
The choke cable is on the right side of the ignition switch it passes into the cab in the upper footwell then through the front firewall and then into the tunnel, it exits the tunnel with the acc cable and clutch cable to the left front of the transmission mount
If you need pics let me know _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
| modok wrote: |
| I am an expert at fitting things in holes, been doing it a long time |
Posted: Sun Apr 16, 2017 4:51 am Post subject: Re: choke cable |
| any pictures would be great , thanks for your quick response .... 👍👍👍👍 |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26194 Location: Olympia Wash Rinse & Repeat
66brm Samba Member
Posted: Sun Apr 16, 2017 9:28 pm Post subject: Re: choke cable |
You're correct left of the ign switch pics to follow
| modok wrote: |
66brm Samba Member
Posted: Sun Apr 16, 2017 9:39 pm Post subject: Re: choke cable |
I have blocked off the two passes through the body with grommets and you can see the ends of the conduit in the tunnel both near the master cylinder and trans front mount _________________ Aust. RHD 66 Type 1
| modok wrote: |
Posted: Mon Apr 17, 2017 1:25 am Post subject: Re: choke cable |
| thanks for all the info ... appreciated 👍 |
