furgo Samba Member
Joined: September 06, 2016 Posts: 944 Location: Southern Germany
Posted: Tue Apr 25, 2017 6:24 am Post subject: Oil temperature, dipsticks and sensors |
Bear with me for the intro if you're interested in oil temp sensors and gauges, or skip to the dipstick part...
My bus came with a dipstick temp sensor, which by now I'm pretty certain has given up the ghost.
At some point while driving a few weeks ago I noticed the oil temp gauge was stuck on the far left, and it wouldn't move. After checking all electrical connections, I ended up removing the gauge and the sensor.
I connected the gauge to my 12V bench power supply, and replaced the sensor input with a 1K-Ohm potentiometer. I managed to move it through its whole scale (50 - 150 °C) roughly from 200 Ohm to 25 Ohm. The main issue here is that it's rather difficult to come across information or datasheets from VDO, but comparing these values with some resistance vs. temp tables I found online, they seem reasonable. At that point, I was not looking for accuracy, but just to see whether the gauge was working at all, which I concluded it did.
Regarding the dipstick sender, I've not come across any other one like that except for one single thread on the forums, but no other info whatsoever. It's a genuine VDO part, but with no part number I could find:
Not in the picture is the adjustable dipstick cover, which I incidentally just found next to cylinder #3. Sometimes one just wonders what POs were up to.
In any case, I did measured the sensor's resistance by heating up water (hence my measurements don't go beyond its boiling point). Comparing them with the datasheets I found, my recorded values are way off specs:
I thought thermistors were quite robust components, so I don't know what could have caused it to fail so spectacularly. I would have expected just some drift with age, or an open/short, but not this sudden change in the curve.
I cleaned up the contacts and double-checked the resistance at different points in the sensor, and I even took its case apart. Same result: at low temperatures the sensor goes in the K-Ohm range, where it should be in the Ohm band.
At this point, I'm just looking at replacing the dipstick. I know there is a better location to measure the oil temp by replacing or modding the inspection plate underneath the dipstick, but I might tackle that when I've got the time.
Being based in Europe, here are the options I found:
Type 1 oil dipstick sender (435 mm - 17 1/8" )
http://www.justkampers.de/5573-oil-temperature-dip...gines.html
Type 4 oil dipstick sender (615 mm - 24 7/32")
http://www.justkampers.de/000001-dipstick-oil-temp...gines.html
Notice that the sender seems to be dependent on the type of engine. Other than the different length, I do not know what makes a sender better for a particular type of engine. I phoned 3 different suppliers and none could tell me the reason why or the actual limiting difference.
My old sender did go about 330 mm (13") into the dipstick tube, so the Type 1 435 mm sender would do nicely. I can't imagine the recommended 24" Type 4 dipstick not getting in the way, so I'd rather not use it.
Doing some more research (did I say how difficult it is to come across some minimal technical info on VDO products?), it seems VDO produced these two dipstick senders at some point:
• X10-323-003-001 C - Dipstick-Type Oil Temperature sensors 435 mm
• X10-323-003-002 C - Dipstick-Type Oil Temperature sensors 615 mm
This (undated) VDO sender datasheet mentions them being removed from their product line. Neither did I find any info about them on the VDO site, so I assume that VDO does no longer makes them and the new ones available are just copies made from another company. The bit that mostly interested me though, was that they used the same sensor at the tip of the dipstick. So I conclude all these dipsticks are the same, simply with different lengths.
In summary, I think I'll just order the Type 1 short dipstick sender and I'll try it. But perhaps someone can enlighten me about what makes Type 1 vs Type 4 dipstick tubes so different? (I don't have a Type 1 engine to compare).
Thanks! _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Decode your M-Plate
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53239 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Apr 25, 2017 7:32 am Post subject: Re: Oil temperature, dipsticks and sensors |
The tube diameter is the same, the difference is the lengths, you'll also find a difference on type 4's depending on where the dipstick is located (through shroud or on the top of the case). Here's what the through the shroud stick should measure: https://www.thesamba.com/vw/forum/viewtopic.php?t=446925 _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
furgo Samba Member
Posted: Tue Apr 25, 2017 7:52 am Post subject: Re: Oil temperature, dipsticks and sensors |
| busdaddy wrote: |
| The tube diameter is the same, the difference is the lengths, you'll also find a difference on type 4's depending on where the dipstick is located (through shroud or on the top of the case). Here's what the through the shroud stick should measure: https://www.thesamba.com/vw/forum/viewtopic.php?t=446925 |
Thanks. As I was looking on the bus sections of the online part retailers, I was not considering other Type 4 motors than the bus.
In any case, in the meantime I found out an even older datasheet (2003) where the dipstick data had not been removed yet. It has a drawing with dimensions and an extract of the Resistance vs. Temp characteristic of the sensor, which is the essential info I was after. Here's an extract of the relevant page:
http://www.ljf-design.com/westfield/vdo_temp_sensors.pdf
| busdaddy wrote: |
| On my unmolested 1978 GE the length from the O ring (up inside the bell)to the tip is 11.5", the full mark is @ 9 5/8" and the add mark is @ 9 1/8". |
From your measurement (which is similar for my dipstick) and looking at the diagram, that seems to confirm that the short L1=330 mm (13") dipstick would have more than enough clearance for the measured 11.5" (300 mm).
I'm thinking that to keep things easy at some point a seller just said the short one is Type 1 only, and the long one is Type 4 only. All other online retailers then followed suit.
If I'm not mistaken, the correct description would have been:
- The short one (X10-323-003-001 C) is for all Type 1 engines and Type 4 engines with through-shroud dipstick.
- The long one (X10-323-003-002 C) is for Type 4 engines with top-of-the-case dipstick _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Decode your M-Plate |
Posted: Tue Apr 25, 2017 8:22 am Post subject: Re: Oil temperature, dipsticks and sensors |
I don't have a particular product to recommend, but a surface temperaturer sender attached to the top of the block would give you a very good representation of the oil temperature. No wires hanging off the bottom of the rig, nothing extra to deal with each time you check the oil, etc.
Would be a more than a bit hard to install with all the FI stuff in place though. |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 4153 Location: Seattle, WA
Posted: Tue Apr 25, 2017 10:55 am Post subject: Re: Oil temperature, dipsticks and sensors |
I have one of those VDO dipstick senders, and it's in good working order. The resistance curve goes from about 600 (or more) ohms at room
temp to about 35 ohms at 250*F. I don't think any of the senders discussed above is for a Type I VW engine, because the lengths are all
WAY too long. The one I have is a perfect replacement for the stock dispstick, and the L1 length (as shown in spec diagram above) is 6.275 in. = 162 mm.
I'm sure VDO made those dipstick sensors to fit a wide variety of engines, using a wide variety of gauges with differing response curves. I don't think
there's necessarily anything wrong with the one you have - it just wasn't made for VW engines or the gauges usually used in them.
On my 71 bus with stock motor, I've had a number of different sensors/gauges installed in various places, and I've never had a significant discrepancy on them
from the temp measured down the dipstick tube with a lab-grade glass thermometer. _________________ '67 bug: seized by the authorities
furgo Samba Member
Posted: Tue Apr 25, 2017 1:27 pm Post subject: Re: Oil temperature, dipsticks and sensors |
| Wildthings wrote: |
| I don't have a particular product to recommend, but a surface temperaturer sender attached to the top of the block would give you a very good representation of the oil temperature. |
That's fine, thanks. I'm aware of the caveats associated with the dipstick sender and temperature readings in general. A more optimal mounting location is something I might look into in the future with more time, but for now I just wanted to get the bus to its status quo as I got used to it.
| kreemoweet wrote: |
WAY too long. The one I have is a perfect replacement for the stock dispstick, and the L1 length (as shown in spec diagram above) is 6.275 in. = 162 mm. |
Thanks for the info, in particular about the resistance values. I had not realized the short sender from the datasheet was way too long for a Type 1 engine, but I noticed some resellers mentioning it should be installed with a gentle bend.
| kreemoweet wrote: |
| I'm sure VDO made those dipstick sensors to fit a wide variety of engines, using a wide variety of gauges with differing response curves. |
Indeed, you're right.
| kreemoweet wrote: |
| I don't think there's necessarily anything wrong with the one you have - it just wasn't made for VW engines or the gauges usually used in them. |
Unfortunately, I think there is, as unlike now, the sender/gauge combo was working before. That is, its curve was matched to the gauge, which displayed some sensible oil temp readings (at least comparing them with what other people had). As mentioned on the initial post, at some point the gauge stopped providing readings and "got stuck" at the minimum value. After the testing also described there, I concluded that the gauge was not at fault.
Also unfortunately, I don't have any before/after sensor measurements to compare curves (I had no particular reason to measure, as the thing "just worked"). The only thing that puzzles me is the major drift that appeared all of a sudden from the actual sensor curve to the expected one from the matching gauge. I would have thought the drift to be a bit more progressive, or the thermistor failing in open or short mode.
Now I could also be wrong and both components are fine, with something in between to do some impedance matching between the two, which I wouldn't have on my bench. But on the bus there wasn't such a thing as far as I could tell. Just the two wires from the dash to the engine compartment. As a side note, unless one is not to expect brown being ground and green being the "S" or "G" signal, the PO wired these two the other way round. As polarity is not important here, it worked nevertheless, at least for the last 10+ years. _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Posted: Tue Apr 25, 2017 4:01 pm Post subject: Re: Oil temperature, dipsticks and sensors |
Oops, I missed that the gauge/sender combo had been working OK before.
My sensor curve is probably what is described in the VDO spec sheet you posted, and it's evidently intended for use with a 120*C(250*F gauge). That wouldn't be
applicable (with any sort of accuracy) to your 150*C (300*F) gauge. VDO makes/made sensors with a lot of different curves, and a lot of them have been discontinued. A lot of
sensor types also seem to have only, or largely, been sold only in certain areas of the world.
The sensor doesn't even have to be from VDO, as long as the temp/ohm curve is correct for your gauge. You can also insert precision resistors in parallel or series to "adjust" the
curve to better suit your gauge.
I assume you undid those binding screws inside the sensor head and checked for corrosion/hi resistance there? Tried using new wire with the sensor, to rule out invisible
strand damage in the middle of one of the existing wires? Is that connector at the end of the sensor wires polarized? Correct polarity is mandatory with those things, I believe. _________________ '67 bug: seized by the authorities
furgo Samba Member
Posted: Tue Apr 25, 2017 4:26 pm Post subject: Re: Oil temperature, dipsticks and sensors |
| kreemoweet wrote: |
sensor types also seem to have only, or largely, been sold only in certain areas of the world. |
Indeed. I also guess that coupled with the fact that VDO as a company went through a few acquisitions through the years, that their site is noticeably bad at listing their own products or appearing on a Google search and that the last datasheet I could find dates back to 2005 (!) makes testing, troubleshooting or even understanding their parts quite challenging if you happen to land outside of the plug-and-play zone as in this case.
| kreemoweet wrote: |
| The sensor doesn't even have to be from VDO, as long as the temp/ohm curve is correct for your gauge. You can also insert precision resistors in parallel or series to "adjust" the curve to better suit your gauge. |
Indeed. In fact, even though all these new dipsticks are advertised online as "VDO" senders, I highly doubt they are made by VDO. It seems VDO stopped making them over 10 years ago. They are probably VDO-gauge-compatible, made from someone else as a replica from the discontinued VDO dipsticks.
Also good point about inserting fixed resistors to modify the curve. I actually just read about this technique to put one in parallel to linearize and scale down the curve. I'll give it a go as a last straw, but I think I've decided already I'll go for the dipstick. While I've learned a bit about oil temp measurement, I've spent enough time on it already!
| kreemoweet wrote: |
| I assume you undid those binding screws inside the sensor head and checked for corrosion/hi resistance there? Tried using new wire with the sensor, to rule out invisible strand damage in the middle of one of the existing wires? |
Yes, very slight surface rust on the screws, but no added resistance. The terminals are brass. I actually did a second set of measurements with the screws and wires taken off, with the probe resting directly on the sensor terminals inside the case.
| kreemoweet wrote: |
| Is that connector at the end of the sensor wires polarized? Correct polarity is mandatory with those things, I believe. |
Yes, it's polarized and installed by me (*), but it should not make a difference afaik. Thermistors are effectively regular resistors that happen to change their output resistance with temp. One end happens to be grounded on the setup here, but unless I'm mistaken, it does not matter which one.
(*) I don't have level markings on the dipstick sender. When I check the oil level, I replace the dipstick sender and use the stock sensorless dipstick. It used to be a bit of a pain to leave the sensor hanging on its wire coming from the top of the engine compartment, so I added the connector to get the sender out of the way while checking oil. Also, I crimped the terminals, so I ruled out component damage by overheating via soldering. _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
furgo Samba Member
Posted: Mon May 08, 2017 8:32 am Post subject: Re: Oil temperature, dipsticks and sensors |
The new dipstick oil temp sensor arrived and I've been doing some tests. First, the sensor itself:
• I cannot see any "VDO" inscription on it (the original had it stamped). Neither I can see it offered on the VDO site. Thus I conclude it's a reproduction of the original VDO X10-323-003-001, no longer available. Update: (*)
• Length L2 (bottom of the case to bottom of the rod) is 350 mm, length L3 (top of the case to bottom of the rod) is 435 mm.
• In any case, slightly longer than the stock dipstick, as expected
• The quality is acceptable. I might do a slight mod by replacing the felt bit by cork, as otherwise it will quickly become an oily mess.
These confirm what I guessed in the other posts, most importantly, that dimension-wise it is a direct replacement for my old sensor.
I did some measurements in the 120 F - 212 F range (50°C - 100°C) and the combo sensor dipstick and VDO gauge were quite accurate and responsive when comparing readings with my digital multimeter in temp mode. I had a go at measuring higher temperatures by heating oil, but it didn't work that well (too little oil, also it heated up too quickly for accurate measuring). In any case, the sensor seems to match my old gauge, which is good.
I'm going to add the min/max marks to the dipstick sensor and keep the stock dipstick as a backup only, as it's a bit of a pain to keep changing dipsticks any time you want to measure the oil level.
I did not manage to find any part number or specs for the (Type 4) dipstick, so I ended up measuring its dimensions. Here they are in case someone finds them useful. Update: I believe the part number is 021-115-611 E
Or in imperial:
| busdaddy wrote: |
(*) I've found out what's probably the reason why these oil temp dipsticks are more seen in Europe. They're made by a German company called Hoffmann-Speedster, and I guess they are not such a popular item to export to the US. _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
