rennie Samba Member
Joined: October 06, 2016 Posts: 246 Location: Orange County, CA
Posted: Mon Apr 24, 2017 6:25 pm Post subject: How to remove spray on sound deadener or undercoating |
I've combed the forums and couldn't find anything specifically addressing removal of old, dried, and crusty SPRAY ON sound deadening (not adhesive mat)... the black, rough surfaced stuff, similar to this pic: I saw the thread on cleaning an engine: https://www.thesamba.com/vw/forum/viewtopic.php?t=475553, but it doesn't mention removing the nightmare spray on material.
What started as a carb leak fix has lead to re-doing the fuel tank and possibly a freeway flyer... and while in there, why not try to scrape out the engine bay, which currently looks like below (spray on deadener on top of OG paint):In the forums, these items were mentioned for paint removal: Citrus Strip, Easy Off, purple degreaser, gas on a rag, Simple Green, Lifter-1 Bug/Tar Remover, lacquer thinner, kerosene, etc.
Has anyone used any of these to successfully remove hardened, decades-old, crusty, black spray on sound deadener? …or know of any other affective method?
jason Samba Member
Posted: Mon Apr 24, 2017 9:24 pm Post subject: Re: How to remove spray on sound deadener / deadening? |
| I have used undercoater remover from FLAPS with ok success. The spray on paint remover works good also. Get it wet and let it sit, when it dries reapply. Comes right off. |
rennie Samba Member
Posted: Mon Apr 24, 2017 9:59 pm Post subject: Re: How to remove spray on sound deadener / deadening? |
Flap discs are a good thought but two things I should have mentioned are that the entire engine bay needs doing, and I'd like to preserve the OG paint if possible, though I may be dreaming. I think flap discs would destroy the OG paint right away.
Hokie87 Samba Member
Joined: May 27, 2010 Posts: 281 Location: Richmond, VA
VWLady Crazy VW Lady
Joined: March 13, 2004 Posts: 3868 Location: Twin Cities, MN
Posted: Tue Apr 25, 2017 3:56 pm Post subject: Re: How to remove spray on sound deadener / deadening? |
| Warm an area up with a heat gun and use a plastic putty knife to get the big stuff off then one of the chemical products mentioned. |
rennie Samba Member
Posted: Tue Apr 25, 2017 5:55 pm Post subject: Re: How to remove spray on sound deadener / deadening? |
Thanks, will check out Eastwood, and heat is a good idea, too.
Rang two decent body shops today. They said they just use paint remover, but they aren't trying to preserve OG paint underneath.
I'll let you know results when/if I find something that works well.
hitest Samba Member
Joined: September 30, 2008 Posts: 10332 Location: Prime Meridian, ID
Posted: Tue Apr 25, 2017 8:52 pm Post subject: Re: How to remove spray on sound deadener / deadening? |
| nlorntson wrote: |
I could overload the server with pictures of my removal of tar from my '66. ^^^ This method is painstaking- but it was the only way I could do it. _________________
| EverettB wrote: |
FU#5 |
rennie Samba Member
Posted: Fri Apr 28, 2017 4:54 pm Post subject: Re: How to remove spray on sound deadener or undercoating? |
About 3 hrs work (thick in places!). Support pillar is how clean it eventually comes and now serves as motivation to keep going. I'm committed to the long haul...
Bought/using a heat gun and plastic scrapers, which tend to heat up but need to stay cool for efficient scraping (no flexing).
2 sq ft done, 20 to go... I'll be the tortoise on this one, not the hare...
oldbusboy Samba Member
Joined: June 25, 2006 Posts: 628 Location: Bowen Island, BC Canada
Posted: Sat Apr 29, 2017 9:39 am Post subject: Re: How to remove spray on sound deadener or undercoating |
I know some guys who have used cans of compressed air, the kind you use for blowing dust off electronic parts. This is for stock VW undercoating. I believe they inverse the can while spraying, or shake the can and by doing so the air that comes out is extremely cold. Once the area you spray becomes brittle you can use a very stiff plastic putty knife to start chipping away.
Worth a shot. The cans of air aren't expensive and there are no fumes unlike heating the tar with a heat gun.
https://www.amazon.ca/Emzone-Air-Duster-284g-10Oz-...ressed+air
Trevor _________________ 1958 kombi
1968 porsche |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13592 Location: Tejas!
Posted: Sat Apr 29, 2017 1:44 pm Post subject: Re: How to remove spray on sound deadener / deadening? |
| rennie wrote: |
| Flap discs are a good thought but two things I should have mentioned are that the entire engine bay needs doing, and I'd like to preserve the OG paint if possible, though I may be dreaming. I think flap discs would destroy the OG paint right away. |
LOL, he didn't say flap discs
no he said FLAPS. Friendly Local Auto Parts Store _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
rennie Samba Member
Posted: Sat Apr 29, 2017 4:30 pm Post subject: Re: How to remove spray on sound deadener or undercoating |
| HerrLowlight wrote: |
Trevor |
Thanks - ya I've read about doing it cold. I have so much to do that you're right, it's certainly worth a try.
Interestingly, heating the tar-like stuff hasn't been bad - can't even smell it. It just becomes pliable - doesn't melt much at all. But, I'll give cold a try.
| Erik G wrote: |
no he said FLAPS. Friendly Local Auto Parts Store |
Ah, thanks, another acronym under the belt now. Thought he meant the drill flap sanding method... |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15510 Location: Casa de Oro, California
Posted: Sat Apr 29, 2017 6:56 pm Post subject: Re: How to remove spray on sound deadener or undercoating? |
| rennie wrote: |
| ...plastic scrapers, which tend to heat up but need to stay cool for efficient scraping (no flexing). |
What about something like a laminated bamboo small kitchen spatula or teflon kitchen tool? Or even a wooden stir stick from the hardware paint department that you could sharpen and form yourself? |
rennie Samba Member
Posted: Mon May 01, 2017 9:23 am Post subject: Re: How to remove spray on sound deadener or undercoating? |
| BarryL wrote: |
I've been cutting down the plastic scrapers and re-sharpening them but wood ones could work better and last longer! Brilliant. Will let you know.
Last night I managed to get the first step of gook off the fuel tray underside and that back corner in general. It's the hardest area to access, so I figured it wise to do first whilst motivated! Now it just needs the "Eastwood PRE" cleaning attack. More pics soon! |
rennie Samba Member
Posted: Sat May 27, 2017 11:24 am Post subject: Re: How to remove spray on sound deadener or undercoating |
Progress pics after about 19 hrs.
Using heat gun with firm plastic scrapers to get the bulk off, then reheating and wiping off excess residue with rags, then using clean rags with off-the-shelf acetone for the final clean up (decided not to by Eastwood PRE after I rang them and they said the California version has a very high acetone content... and I've learned straight acetone is working just fine). No luck with paint remover, and didn't want to risk using oven cleaner with OG paint preservation in mind.
Anything other than plastic or teflon scrapers (ie: bamboo/wood) scratches the nice OG paint hiding underneath. Some areas, like by the battery, have very hardened black deadener that heat doesn't affect. Using a metal 'wood chisel' there at a very careful/light pressure/consistent angle to slowly scrape it off without scratching the OG paint.
Cleaning the calked seams is tricky as the paint wants to come off more easily than paint on metal, but fine and focused light scraping and light rag wipes is working out okay. Sometimes I feel like I'm going at an archaeologist's pace!
I've come across no rusty areas, and still have fingers crossed on that front. My chosen method is slow going but it's coming along, and the hours of later enjoyment will far exceed the hours of work to remove this dreadful stuff.
I've almost got the other side done, too, and this weekend hope to move to the 'roof'...
ronjonlasvegas Samba Member
Joined: October 08, 2004 Posts: 970 Location: Las Vegas, NV
Posted: Sat May 27, 2017 11:51 am Post subject: Re: How to remove spray on sound deadener or undercoating |
Nice job. Keep at it. The area you have finished looks fantastic.
I am in the process of removing four layers of old paint off my DC so I know it is not easy. I also need to remove the spay bomb paint off my interior for all areas that will not be covered with panels. The prior owner used trunk splatter black paint on mine and it is not too bad to remove. I am really glad they did not use sound deadner.
I commend you on your patience and persistence. _________________ September 1964 Standard Sunroof walk through SWR/BG original paint. |
rennie Samba Member
Posted: Sat May 27, 2017 8:35 pm Post subject: Re: How to remove spray on sound deadener or undercoating |
Thanks ronjon. I've seen your thread, which along with others helped inspire me to dive in and do it. Impressive how much you're doing to save your postal yellow!
Left side progress pic below, after about 23 hrs on that side.
Am having to scrape gently yet firmly with the chisel on the flat tray area... while using light heat so as not to soften the paint too much. The tar there has hardened to a crust and nothing penetrates the bulk well enough to scrape it off. Left side is taking more hours than the right.
Pic also shows the aft side wall and how clean it gets when reheating it after the bulk is removed and just using a rag without acetone. Lower on the sidewall, and tray, you can see where the acetone rag was used for final clean up... matching the forward sections. I'll detail out the seam calk and vents more later. |
BarryL  Samba Member
Posted: Sun May 28, 2017 8:47 am Post subject: Re: How to remove spray on sound deadener or undercoating |
Epic task you are tackling.
In retrospect it seems so ridiculous to have that stuff applied in there. Plus, imagine what the applier person looked like after that job. One good thing is it sure protected the original paint. |
rennie Samba Member
Posted: Sun May 28, 2017 9:57 am Post subject: Re: How to remove spray on sound deadener or undercoating |
| BarryL wrote: |
I too can't fathom having a nice pearl white engine area and spraying black tar all over it.
But you're right, it has well preserved the paint - it shines up nicely after TR3'ing it. Reminds me of another old car I had from an OG owner that chain smoked - waxy/sticky nicotine(?) had covered all the interior chrome. After hours of polishing, it looked brand new - completely preserved. I suppose there is some thanks for historical madness! |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1468 Location: Eastern WA
Posted: Sun May 28, 2017 10:26 pm Post subject: Re: How to remove spray on sound deadener or undercoating |
| You're pretty far into this project, but I also had to deal with the same thing on my Single Cab behind the seat and dash. What works great and doesn't harm the original paint....bug and tar remover. It literally MELTS the undercoating! If it's thick in areas, you might need to spray it a few times, but it was melting off as I was spraying on the bug and tar remover. Good stuff! |
Malokin Martin Samba Member
Posted: Sun May 28, 2017 11:18 pm Post subject: Re: How to remove spray on sound deadener or undercoating |
People have had relatively good success with an air needle sander. Never done it myself though. I think it may pock mark the paint though. One idea.
