Temp gauge quit working
pushkick
pushkick is offline
PostPosted: Sun Apr 30, 2017 6:04 pm    Post subject: Temp gauge quit working Reply with quote
havent found much data on the coolant temp sensor for the gsuge display and blinking light. what is the test procedure for the gauge if you dont have a vw tool what voltage or resistance ? i have searched threads but have no found no conclusive info. how to test temp sensor for failure? how to test gauge and wires from sensor? is there a circuit diagram in bently i have not found it.
any help is appreciated.
i see said the blind man to his deaf dog
i am going to quit smoking and drinking and die a healthy man. gotta laugh
there is no deed to the planet earth
1990 vw automatic camper
Ahwahnee
Ahwahnee is offline
PostPosted: Sun Apr 30, 2017 6:11 pm    Post subject: Re: temp guage quit working Reply with quote
Here is the thread you need:
https://www.thesamba.com/vw/forum/viewtopic.php?t=464113
pushkick
pushkick is offline
PostPosted: Sun Apr 30, 2017 8:10 pm    Post subject: Re: temp guage quit working Reply with quote
Ahwahnee your post is greatly appreciated thanks , that is a great thread with a lot of good info, it looks like the temp gauge sensor is a rtd temperature device and not a thermocouple, so the resistance goes down or varies inversely as temp goes up. this means there is a constant current and the voltage varies as the resistance changes with temp. rtd's have a very linear relationship between resistance and temperature so only two measurements at different temps should be needed to check calibration.
