static Samba Member
Joined: March 22, 2002 Posts: 1831 Location: The High Desert
Posted: Sun May 07, 2017 7:29 am Post subject: Re: What did you do for your Bay recently? |
Pretty simple and cheap improvement:
I replaced the bulbs in the front (amber) turn signals from clear bulbs to amber bulbs.
Now, my front amber turn signals are more amberish.
More amber = better (since, frequently, the lenses are faded)
I replaced my side marker clear, incandescent bulbs to red LED bulbs. Now, my red side markers look much more red. More red = better.
Total cost for all four bulbs? About $1.00
(Pro tip: buying Chinese stuff direct from China is much cheaper than buying your Chinese stuff through a USA middleman) |
cv66seabear Samba Member
Joined: February 18, 2017 Posts: 105 Location: Wisconsin
Posted: Sun May 07, 2017 9:09 pm Post subject: Re: What did you do for your Bay recently? |
Replaced the seat belts with retractable ones - don't work as smooth as I'd like.
Put up a couple of assist handles.
Tried to replace the visor holder, but how in the heck do you put a screw in, when you have to have the visor in there already? Do you have to take the visor off at the side, screw in the holder, then replace the visor on the side?
Did a little measuring in preparation for installing my auxilliary battery. Looks like I'll put in a holder, then go through the firewall to hook up to the main. Since I'm mounting under the rear seat, I'll also put the fuseblock and Bluesea ACR under there.
Rear brakes need love = the right has a bad master cylinder. Parts just arrived, not sure if my skill level is up to it... (heck I couldn't replace the visor holder!) _________________ "Not all who wander are lost." JRR Tolkien
1979 Campmobile - "Pancho Verde"
Old Friends - gone now:
1964 Beetle "Liebchen"
Mark 3 Jetta "Liebchen Zwei"
Passat Wagon "Wolf"
2015 Passat Sedan "Rudy" |
richardandtory Samba Member
Joined: November 01, 2014 Posts: 9 Location: Bath, UK
TurtsMcSlow Samba Member
Joined: August 07, 2015 Posts: 78 Location: Derby City, Cantuckee
Posted: Fri May 12, 2017 9:50 pm Post subject: Re: What did you do for your Bay recently? |
Made the switch to a pertronix ignitor. |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Sat May 13, 2017 8:51 am Post subject: Re: What did you do for your Bay recently? |
TurtsMcSlow wrote: |
I did too a couple weeks back with a SVDA. Bus runs like a top _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
wcfvw69 Samba Purist
Posted: Sat May 13, 2017 11:22 am Post subject: Re: What did you do for your Bay recently? |
notchboy wrote: |
I did too a couple weeks back with a SVDA. Bus runs like a top |
Yup, tow truck drivers love them there Petronix modules!
_________________ Contact me at [email protected]
The Samba member since 2004.
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12729 Location: on a bike ride somewhere
Posted: Sat May 13, 2017 11:31 am Post subject: Re: What did you do for your Bay recently? |
Ooooohhhhh buurrrnnn! You even found one with a vintage trailer for Jason! _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20282 Location: Sandpoint, ID
Posted: Sat May 13, 2017 2:51 pm Post subject: Re: What did you do for your Bay recently? |
I've had tow Pertronix modules fail on me while on the road. Both were quickly repaired by the set of points in the glove box, once the issue was diagnosed. That took some time..
Always keep spare parts and tools on board. _________________ nothing |
Posted: Sat May 13, 2017 2:58 pm Post subject: Re: What did you do for your Bay recently? |
cdennisg wrote: |
Always keep spare parts and tools on board. |
It's very rare that you see folks report breaking down due to points or condensers unless they were negligent with their servicing. In 3 decades of VW ownership, I've never had an issue w/points or condensers.
Now, I LOVE the idea of those electronic ignitions but I simply see too many people report them failing, causing a breakdown. Even if you do carry a spare distributor or points and condensers, with today's heavy traffic, you just know the module would burn up in the worst possible spot on the freeway, potentially causing an accident. _________________ Contact me at [email protected]
HelmutofBuffalo Samba Member
Joined: August 22, 2005 Posts: 554 Location: West Coast of New York
Posted: Sun May 14, 2017 5:43 am Post subject: Re: What did you do for your Bay recently? |
I think anything man made can fail. I have the Compufire electronic ignition on mine (see pic.) Works beautifully.... and yes the module did burn out at one time, luckily it was not while out on the road.
However (in a different Bus) I also experienced a set of points break at the spring. Leaving me stranded. Lesson learned, always carry spare points etc.
_________________ 1979 Type I Convertible |
Posted: Sun May 14, 2017 8:23 am Post subject: Re: What did you do for your Bay recently? |
wcfvw69 wrote: |
notchboy wrote: |
Haha assholes
I have my saucy pointed 009 on deck IF my junk should fail _________________
t3kg wrote: |
1964 1500 S
wihr Samba Member
Joined: August 15, 2010 Posts: 344 Location: PORTLAND, OR
Posted: Sun May 14, 2017 11:45 am Post subject: Re: What did you do for your Bay recently? |
I have over 200,000 miles on my Allison (Crane) electronic ignition. The only time it ever failed me was when a outside wire broke. I fixed it quickly. The best improvement to the car I have ever made. Plugs last twice as long.
WW _________________ WIHR
1970 Campmobile "Van Ordinaire"
2009 Lincoln Town Car "Behemoth"
1969 Lambretta 150 DL "Nina"
1962 Matchless G 12 CS 650cc |
Posted: Sun May 14, 2017 12:14 pm Post subject: Re: What did you do for your Bay recently? |
Electronic ignition is excellent, for sure. I just noted that I have had two different aftermarket systems fail while on the road. Neither of which I bought and installed, they came with the vehicle/engine when I bought them.
I would consider the Crane or Mallory ignition systems in the future. But for now I'll keep using the points and condensers I have stashed away.
BTW, I had a condenser fail once many years ago. I have seen broken contact point springs, too. _________________ nothing |
Posted: Tue May 16, 2017 7:10 am Post subject: Re: What did you do for your Bay recently? |
Replaced the left rear drum. shoes and Cylinder. 15 minute video on YouTube - 5 hours for us!
BUT... now the right side will be easier! _________________ "Not all who wander are lost." JRR Tolkien
Passat Wagon "Wolf"
DeltaBravo Samba Member
Joined: February 29, 2016 Posts: 179 Location: Long Beach, CA
dillon70 Samba Member
Joined: October 20, 2008 Posts: 234 Location: Ventura, Ca.
Posted: Sun May 21, 2017 5:42 pm Post subject: Re: What did you do for your Bay recently? |
Got my middle seat back from being reupholstered to match the others. It's probably been 25+ years since this was installed in the bus. She's come along way:)
Before
After
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Sun May 21, 2017 6:06 pm Post subject: Re: What did you do for your Bay recently? |
Wow, that red looks great!!! Great transformation, and thanks for posting the pics. Are you using this as a daily driver? _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
Posted: Sun May 21, 2017 8:24 pm Post subject: Re: What did you do for your Bay recently? |
Thanks!!
She's a garage queen at least 5 days a week, but we get out for the weekend club meet/cruise or occasional car show. |
cbaucom1 Samba Member
Posted: Sun May 21, 2017 9:45 pm Post subject: Re: What did you do for your Bay recently? |
Globespotter wrote: |
Took off the Westfalia decal from the front that the PO had put on when he refurbed the bus.
I like the cleaner stock look for a Bay, since the Westfalia decal was only on the front on Vanagons.
Also:
Built dividers for my under seat storage. The best part is that now I can pull out my coleman stove from the front without raising the seat, and not have to pull out all the stuff that used to just be piled in there. Also keeps my tools accessible in a removable tray and helps organize everything! |
This is inspiring. Mine becomes a sloshed around, junk drawer of tools and random camping items. But, where do you put the tent poles? |
d-rick Samba Member
Joined: May 14, 2006 Posts: 889 Location: Columbia,MO
Posted: Tue May 23, 2017 5:00 pm Post subject: Re: What did you do for your Bay recently? |
I swapped out a rusty front beam for a good solid one today on the '77 westy I am working on...fun stuff.
No pic..B/C we all know what a rusty front beam looks like _________________ 1959 mango-trailerbus
1962 single cab *1/2
1966 13 window
1967 panel/camper
1968 cig-panel *1/2
1968 passenger bus *1/2
1969 beetle
1969 dormobile
1978 sage green Westy
1990 DoKa
2002 Golf TDI |
