Fuel Injection Diagrams Collection FAQ
Page: Previous  1, 2
Tcash
Tcash is offline
PostPosted: Fri Apr 17, 2015 4:57 pm    Post subject: 1975 Fuel Injection Diagrams Reply with quote
1975 Kombi
http://www.thesamba.com/vw/forum/album_page.php?pic_id=572082
Tcash
Tcash is offline
PostPosted: Fri Apr 17, 2015 5:01 pm    Post subject: Reply with quote
1975
patayres
http://www.thesamba.com/vw/forum/album_page.php?pic_id=571985
Tcash
Tcash is offline
PostPosted: Tue Jun 13, 2017 3:02 pm    Post subject: Re: Fuel Injection Diagram Collection Reply with quote
Does anyone have a 1979 vacuum hose diagram?
Vacuum hoses 76 1/2 to 78: is the latest I can find
Thank you
Tcash
Randy in Maine
Randy in Maine is offline
PostPosted: Wed Jun 14, 2017 3:35 am    Post subject: Re: Fuel Injection Diagram Collection Reply with quote
1979 Federal is the same as the other SVDAs.
1979CA is a little different as it is a DVDA and the retard side of the distributor only has vacuum at idle.
furgo
furgo is offline
PostPosted: Wed Jun 14, 2017 3:58 am    Post subject: Re: Fuel Injection Diagram Collection Reply with quote
Incidentally, I've been looking at vacuum lines recently, and I modified the original vacuum hose routing diagram with DVDA distributor for my '79 Federal bus, which has a SVDA distributor. It now shows both configurations and I thought I'd share it here.
While at it, I corrected the connections to the filter box and added the small connector hoses and T-pieces for clarity:
As I said, this is based on a '79 FI Federal, but it might apply to more model years.
'79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Decode your M-Plate
mccann1984
mccann1984 is offline
PostPosted: Sat Jun 30, 2018 9:29 am    Post subject: Re: Fuel Injection Diagrams Collection FAQ Reply with quote
Hey All,
I am not a mechanic and pretty confused - I am trying to hook up the vacuum and vapour lines for my van and there are so many different diagrams that i don't know which ones to use. I have a 1978 van - it is fuel injected and has an automatic transmission. I don't understand what things like DVDA, SVDA or Federal means - can someone point me in the right direction as to what diagram to follow? Thanks!
Andy
Tcash
Tcash is offline
PostPosted: Sat Jun 30, 2018 7:15 pm    Post subject: Re: Fuel Injection Diagrams Collection FAQ Reply with quote
I have a 1978 van Bus-
it is fuel injected
Fuel Injection Vacuum and Vapor Hoses
http://www.ratwell.com/technical/VacuumHoses.html
1976 1/2 to 1978
SVDA single vacuum fitting, dual advance. Has one nipple on the distributor, vacuum canister.
DVDA duel vacuum fittings, dual advance. Has two vacuum fittings on the dist. vacuum canister.
Fuel hoses
http://www.ratwell.com/technical/FuelHoses.html
Pictures would help.
Posting pictures
https://www.thesamba.com/vw/forum/faq.php?mode=gallery
Good luck
Tcash
tonytoney
tonytoney is offline
PostPosted: Sun May 28, 2023 6:37 pm    Post subject: Re: Fuel Injection Diagrams Collection FAQ Reply with quote
Quick question. I know this is an old thread and there is a ton of information here that is a great help. I had to redo the entire vacuum system on my '78 bus and the vapor line hoses as well. On the fuel vapor hose chart, where it comes off of the T with the letter W connection to V then to Y' (not Y), I cannot figure out where that fuel vapor hose is supposed to go? I have looked everywhere and cannot figure it out. I have a cap on it but I would like for it to be exactly like it's supposed to be as my bus is having a hard time idling and if everything is correct then it helps to narrow down the issue which I do believe is in the AFM.
busdaddy
busdaddy is offline
PostPosted: Sun May 28, 2023 7:10 pm    Post subject: Re: Fuel Injection Diagrams Collection FAQ Reply with quote
Welcome!
Tank fumes come from both sides (Y' and X), then through that Tee (W) to Y which leads to the charcoal canister beside the RH tail light, if yours are capped off the tank can't vent and may be part of your problem.
Слава Україні!
tonytoney
PostPosted: Mon May 29, 2023 5:31 am    Post subject: Re: Fuel Injection Diagrams Collection FAQ Reply with quote
busdaddy wrote:
Welcome!
Actually, I am connected to the canister correctly and all connections are made correctly except the Y' coming off of the W tee. I don't know where the Y' connects to from there (what point on the engine, etc.?) so the Y' is what is capped.
busdaddy
busdaddy is offline
PostPosted: Mon May 29, 2023 8:03 am    Post subject: Re: Fuel Injection Diagrams Collection FAQ Reply with quote
tonytoney wrote:
busdaddy wrote:
Welcome!
Y' should lead across the roof of the compartment to the left side metal vent pipe coming from the air scoop area.
Слава Україні!
Page: Previous  1, 2
Page 2 of 2
