Questy Samba Member
Joined: February 28, 2015 Posts: 36 Location: Port Townsend, WA
Posted: Mon Jun 26, 2017 9:10 am Post subject: Radiator Fan Questions ~ SOLVED |
TLDR:
1985 1.9 Westy Factory A/C.
Van overheated this weekend -boiling coolant! -- radiator fan didn't come on when it should have.
I Tested at the sensor plug at radiator ala Ken Wilford (https://www.vanagain.com/troubleshoot-your-radiator-fan/). NO Power, NO fan!
Here's the wierdness: Van has factory AC and FAN COMES ON WHEN I TURN ON THE AC so clearly the fan and circuit work!
Details:
So we drove up a very big hill this weekend (Sea Level to 5K Feet over 17 miles). Hottest day of the year, biggest climb ever tried to highest altitude...super steep road--coolant boiled over and the fan never came on...but comes on when I turn on the A/C.
I'd love some ideas on where to start trouble shooting this....thanks in advance
SOLUTION: it was suggested by Ken Wilford I check the #7 fuse--which was fine. This lead me to checking the wiring on the backside of the panel, where the #7 post was disconnected. Once I reconnected it: Shazam!!! All good.
Required eye candy of van in a cool place:
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Mon Jun 26, 2017 9:51 am Post subject: Re: Radiator Fan Questions |
The AC bipasses the fan switch in the radiator, so that points to a bad switch most likely or an obstruction, possibly crud in the radiator or less likely partially stuck closed thermostat.
But you tested the fan directly by putting a piece of jumper wire into the plug like in that vanagain post? Maybe explain better what you did and what you saw, or just pull that plug and try the jumper thing again. If you can get the fan to come on both speeds with the jumper, then you either have an obstruction in the radiator that is preventing the switch from seeing hot coolant, or the switch is bad. |
shagginwagon83 Samba Member
Posted: Mon Jun 26, 2017 9:56 am Post subject: Re: Radiator Fan Questions |
http://www.gowesty.com/product-details.php?v=&id=3651
Radiator Fan Temp Switch. I'd look at this bad boy. This is what was wrong with my system. I have the 83.5 with factory AC. I think I need to replace my radiator also because it sometimes takes it awhile to kick on. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6933 Location: Fort Lauderdale, Fl.
Posted: Mon Jun 26, 2017 9:58 am Post subject: Re: Radiator Fan Questions |
disconnect the radiator fan switch and jumper the connections.
If the radiator turns on it is the switch.
Like this:
_________________ This free advice is worth exactly what you paid for it.
Questy Samba Member
Posted: Mon Jun 26, 2017 11:44 am Post subject: Re: Radiator Fan Questions |
Thanks for the replies.
So I've tried jumping the plug...no fan. So I put a multimeter on it, no Volts. But 0/53/35 Ohms resistance.
Because of the overheat-boiling lost coolant, I topped/bled the cooling system. |
Questy Samba Member
Posted: Tue Jun 27, 2017 9:44 am Post subject: Re: Radiator Fan Questions SOLVED |
| SOLUTION: it was suggested by Ken Wilford I check the #7 fuse--which was fine. This lead me to checking the wiring on the backside of the panel, where the #7 post was disconnected. Once I reconnected it: Shazam!!! All good. |
Posted: Tue Jun 27, 2017 10:06 am Post subject: Re: Radiator Fan Questions |
| shagginwagon83 wrote: |
What thermostat are you running. If you have a 80°C thermostat and that fan switch the fan will be slow to come on. |
Posted: Tue Jun 27, 2017 10:08 am Post subject: Re: Radiator Fan Questions |
| Steve M. wrote: |
Like this:
Keeping a short jumper like that in the glove box is a good idea. |
