Howard 111 Samba Member
Posted: Thu Jun 29, 2017 12:29 pm Post subject: Re: Hose Clamps on Fuel Lines |
Besides proper clamps, there is a proper hose to be used with fuel injection. I run a CB FI/Turbo system, and at idle produces 45-50 lbs fuel pressure. When you buy fuel hose, they should ask you NA or FI along with the size and length. _________________ 1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270 |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4061 Location: San Diego
Anybody tried to put some sort of bubble flare on the end of a straight metal line to give the hose a little more resistance to removal? Seems as though the newer ethanol approved hoses (r7 or r9) have a smoother inside such that they can be removed or twisted by hand on the metal line, even when tightened with the FI style clamps. This is with the correct size hose/metal line |
joemama Samba Member
Joined: February 09, 2006 Posts: 1665 Location: La Crescenta, California
Posted: Thu Jun 29, 2017 12:53 pm Post subject: Re: Hose Clamps on Fuel Lines |
I use the band style/fuel injection clamps. If you get the right size for your hose, they will not be over tightened. I also use fuel injection hose, way more expensive, but holds up great. |
slalombuggy Samba Member
Posted: Thu Jun 29, 2017 2:25 pm Post subject: Re: Hose Clamps on Fuel Lines |
chrisflstf wrote: |
Yes, IF I'm not doing hard lines, which I almost always do no that I have a lot of tooling for it I put the tube in the flare tool about a 1/16" proud and flare that little bit, makes a huge difference. Make sure the edges are smooth though or you'll gouge up the hose getting it on.
brad |
wcfvw69 Samba Purist
Posted: Thu Jun 29, 2017 5:17 pm Post subject: Re: Hose Clamps on Fuel Lines |
What's NOT mentioned is how to REMOVE the German braided fuel line of the carb or pump. Too many people YANK it off the inlet/outlet pipes on the carbs and fuel pumps. All the clamps in the world won't help when the pipe comes out or falls out of the pump or carb from that. Also, bonus points for hanging a heavy fuel filter between the pump and carb.
Yes, some folks will wire the fuel line clamp to a screw on the carb or pump to help insure the pipes don't fall off. However, simply using a razor blade to cut the fuel hose length wise when removing it will help tremendously as well.  _________________ Contact me at [email protected]
The Samba member since 2004.
ach60  Samba Member
Joined: May 14, 2001 Posts: 4137 Location: Santa Maria
Posted: Thu Jun 29, 2017 6:36 pm Post subject: Re: Hose Clamps on Fuel Lines |
wcfvw69 wrote: |
Yes, some folks will wire the fuel line clamp to a screw on the carb or pump to help insure the pipes don't fall off. However, simply using a razor blade to cut the fuel hose length wise when removing it will help tremendously as well.  |
The thing is you don't know what the P.O. did to remove the hose, that's why you safety wire them? _________________ Good Luck
Al |
