Jeremy Samba Member
Joined: August 01, 2002 Posts: 300 Location: gilbert, az- not anymore- now in co
Posted: Tue Jul 18, 2017 3:53 pm Post subject: Can air pressure affect overall paint color? |
Anyone ever have a issue with this? Im trying to do some touchup work on my motorcycle. Ive been using an airbrush with paint matched to the panel. It seems like the paint comes out a different color once its cleared over. Once you color sand its a completely different color as well. Im getting a little frustrated with this. Anyone have some ideas? |
Zappafan428 Samba Member
Joined: May 14, 2017 Posts: 12 Location: British Columbia
Posted: Wed Jul 19, 2017 12:00 am Post subject: Re: Can air pressure affect overall paint color? |
I've bought paint that was colour matched and it wasn't even close once it was sprayed on. When I did my motorcycle tank I just resprayed the whole thing. It didn't work as a patch, but when completely redone it wasn't as noticeable. |
scubaseas Samba Member
Joined: May 24, 2013 Posts: 442 Location: ME & Texas, in a Bus or on a boat somewhere
Posted: Wed Jul 19, 2017 2:37 am Post subject: Re: Can air pressure affect overall paint color? |
Solid or metallic paint?
Yes pressure will effect color. Lower air pressure = darker in most cases.
Thinning ratio will effect color.
Primer color can also effect finish coat.
Optical scanning of color is the best way to match it. Tinting is possible if you have a lot of practice and an eye for it.
Clear coat tends to darken colors. You will probably have to tint the paint or simply paint the whole piece and blend into adjacent panels.
Mixed paint rarely matches. Just my experience over the years. Factory mix is usually a lot closer to reality. _________________ Al
08/1970 T2a Westphalia owned since 1980
ASE Master certification. 50 years pushing a wrench
Retired |
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Fri Jul 21, 2017 5:36 pm Post subject: Re: Can air pressure affect overall paint color? |
For sure, almost everything can affect the color. Most of the time a color match isn't right on, that's why they blend it into the existing paint. The blend tricks the eye. On a motorcycle I would just paint the whole tin. |
