Cleaning an electric AAR
KTPhil Premium Member
KTPhil is offline
PostPosted: Thu Aug 10, 2017 1:49 pm    Post subject: Re: Cleaning an electric AAR Reply with quote
All I can think of is maybe the fuel is boiling in the line somewhere and increasing your pressure from heat soak. Never heard of that, though.
Tram
Samba Socialist
Tram is offline
PostPosted: Thu Aug 10, 2017 2:41 pm    Post subject: Re: Cleaning an electric AAR Reply with quote
A pressure sensitive kink in a rubber return line or a rubber line losing its inner liner.
Bryan67 wrote:
Those who can- do.
Those who can't? Subaru.
raygreenwood
raygreenwood is offline
PostPosted: Thu Aug 10, 2017 3:17 pm    Post subject: Re: Cleaning an electric AAR Reply with quote
Possible on any of those counts......or a defective gauge in some maner. If during that period of time waiting...you are leaving the gauge in the engine compartment and it is getting hot....it is likely the gauge.
The issue I keep posting about......without regard to gauges and people putting them in the engine compartment.....is that unless you SPECIFICALLY order a gauge made for heated fluids....and about 100% of Lowes and Home Depot water gauges are NOT hot fluid gauges......the gauge will be inaccurate and/or permanently damaged.
All gauges that are NOT designed for hot fluid use....typically max out in the 150° to 165° range. You typically also....according to gauge manufacturers....get an average 1% shift in accuracy per 50° rise in gauge temperature.....above 75°F ambient.
Gauges with brass bourdon tubes are specifically NOT designed for use over 120°F
What happens is the bourdon tube inside expands and changes length....moving the needle. Better quality utility gauges have phosphor bronze bourdon tubes....and hot conditions gauges have stainless steel bourdon tubes.....and....they have a detached or floating linkage pinion to the needle so that heat expansion does not change the needle accuracy.
Ray.
blues90
blues90 is offline
PostPosted: Thu Aug 10, 2017 5:07 pm    Post subject: Re: Cleaning an electric AAR Reply with quote
I checked the pressure after 3 1/2 hours sitting and it was 18 PSI . I didn't have the gauge in the engine compartment I had the lid off and the gauge was just above the opening yet it's still pretty hot in my garage and with the engine running it's at least 120 or more with the lid off . It's hot in there even without the engine running.
I don't recall how hot it was last time I checked the pressure. All I know is with the same gauge. I have no idea what's inside the gauge most likely it works like most water pressure gauges work. The only diff is you can adjust it to zero if it's off which it was not. There is no stop pin for the needle at zero.
Other than that I'll see what happens , if the pressure is down to nothing in the morning I'll just block clamp the pressure line where it enters on the left on the engine and see if it holds then the return before the regulator.
One opinion is if the pressure holds then it's hot fuel vapors yet I never ran across this all these decades even if one or two or more FI components which I'm sure have aged and are out of the acceptable range , it could be that since 2006 I have not put more than 350 miles per year on this car and either parts aged or gunked up by sitting impossible to say. I do know in 2006 it ran perfectly well at all speeds and idled smooth without missing a beat. It was after 2009 when i replaced the fuel lines and plugs and fuel filter and put back on the heat exchangers and changed the vacuum lines and adjusted the valves then it started to have this erratic idle which is not one cylinder all that corrects it is unplugging the IAD temp sensor yet when I do the hot idle is different in park every time I drive it yet it always drops back to 900 or normal in drive and I don't feel it trying to creep when I let my foot off the gas. With that sensor plugged in the idle can be set and it drops only 100 RPM when placed into drive. Also back in 2009 I replaced all the injector seals with the same VW original ones that were new an available at that time didn't change a thing. The very first thing that developed after said repairs was it began to hunt and I checked every thing all over again and sometimes when I drove it a mile to a store and start it it would stall then start up and over come this if I just placed it in drive and gave it a bit more gas and then it kept running and all of a sudden both issues vanished like a potent fart in the wind now I'm left with this . It's not bad , you don't feel it driving the car at any speed all I notice is the RPM is not real steady if I focus on the tach but put it in park and try to give it gas and it will go to say 1300 RPM then best I can explain it is struggle to get to 200 RPM it gets there yet in not smooth instant responce with the IAD temp sensor unplugged it just responds smooth. Most of my questions were in 2009 or at least what happened at that time and I even checked every single wire from each FI component to the ECU plug for opens ,, short to ground , high/ low resistance and voltage drops nothing. later in 2015 I changed the plug wire and cap and rotor checked the dist advance for any sticking stall acted the same. The parts were old so I felt they were due. was it a fluke or some hose I changed that has some magical vacuum leak / I went through it all again in 2011 and 12 and just lived with it as I do today. Could be the TPS yet I cannot find a thing wrong with it by testing can't test it running other than to hear the 20 clicks engine off of course. I also tightened every single FI terminal connectors out of their lofty nylon plugs and not one change. Went over the valve adjustment three times since then with no change. Who knows it could be any vibration that some wire or connection is not right yet I'm not about to change the entire wire harness and replace every FI one at a time as in tossing parts at it . I certainly triple checked all my work first time around in 2009 and did not handle any plug or connector rough. Thing is a vacuum leak will make it run richer which is what unplugging that temp sensor does not in quite the same manner . It's most likely one simple little thing that changed when I did the basic maintaining one should do other than the heat exchangers in place of the J pipes . I didn't even have to fill the tank so it changed with the same gasoline.
raygreenwood
PostPosted: Fri Aug 11, 2017 7:15 am    Post subject: Re: Cleaning an electric AAR Reply with quote
Ok....good stuff.
A couple of items.
1. One BIG problem with these cars any car.....is not driving them. 350 miles in 11 years.....you will easily have lots of little vacuum leaks that open and close with temperature and vibration.
Hands down the most difficult troubleshooting sessions I have ever had....with not only D-jet....but L-jet, digifant and CIS injected cars.....is from otherwise perfectly running cars that were stored for long periods and not DRIVEN.....not just occasionally warmed up.....or driven sparsely.
Gaskets seperate, seals shrink etc. In these type of vehicle.....I have learned not to play around. I replace every hose, every filter, every gasket and seal that might come on contact with vacuum before I do anything with cars that get stored and not driven
You can see this carnival of insanity every spring over in the Bay bus forum. Laughing .....many owners tune out their rides and park them rust free in the garage for the winter....and do nothing with them for 6 months.
Then we get weeks of posts of "parked for the winter pristine.....now wont idle or does not run right".
These little idle issues you described above.....sound just like tiny intake gasket to head leaks, runner boot leaks, plenum back plate leaks.....and yes.....injector seal leaks......all tiny leaks. Some you will have at cold start up. Those disappear in minutes as things heat up. Other different tiny leaks will open up with heat expansion and vibration.
2. From the sound of it.....your regulator and pump are pretty good. Normal enough.
3. The problem you described after changing injector seals is PRECISELY why I quit using the factory seals over 20 years ago.
The material on factory seals is just fine. Its Viton. The problem is that factory supplied seals are just slices.....precise slices....but just slices of tube. The ID is too large and at times the OD is slightly too small. They have variation.
The best factory style/shaped seals I have found are the Echlin brand seal kit found at NAPA. They are molded and have a bulge at each end. They are longer by a handful of thousandths.....and most important....the grommet that fits in the hasp/ring and holds the injector.....is slightly oversized.....so it forces the injector inward tighter.....to compress the tip seal so it seals tighter.
The problem even with the Echlin brand seal is that the ID is still too large so the injector cab rattle around a little with vibration.....and cause leaks at the tip seals.
The best combination I have found is to use the Echlin brand hold down grommets cor D-jet and tip seals from CIS injectors. Those fit very tight to the injector tip....and since they are not shaped for the step bore in the end of the runner.....they get compacted hard....conform to the bore....keep the injector vibration free and perfectly centered and sealed.
4. From what you have described.....your AAR is functioning. If it flows air when cold...and closes up vacuum tight after 8 minutes plus or minus......it has nothing to do with what is wrong with your car.
5. Every symptom you describe is also right in line with what you get out of an old harness. That fact that you tightened up terminals years or months ago ....means nothing because then you drove it hardly at all.
Ray
blues90
blues90 is offline
PostPosted: Fri Aug 11, 2017 10:17 am    Post subject: Re: Cleaning an electric AAR Reply with quote
Ray that's all true except I said I drive it 350 miles per year not in 11 years . Although most of the driving is twice a week to 3 times a week and at most 4 miles each time. I did drive it much more in 2006 every day on the freeways then by early 2007 I was down to 300 to 400 miles per year.
Yet it still ran fine until I did all the work in 2009 it was after that the odd idle issues arose. Another thing was the MPS which was new on a spare 72 I got in 85 for spare parts the one on my car which was screwed together was the proper VW part number for an E system ( which I only found out in 2009 when I joined this forum looking for info and Russ had a chart . Since the one on the 72 looked new and was riveted I put that one on my car and it's number was not the same VW # yet it looked identical and not knowing I just put it on and it ran fine with it then I was offered the proper VW and Bosch number an unused one which I put on in early 2015 or 16 can't recall . Back when I swapped out the MPS it was 1991 and i had no info and didn't have a PC until 2000. Point is all three look the same and have the black cap and the one adjustment screw. All have the ground tab on the housing and my car has that ground wire. Yet the car ran very well and still did even with the wrong MPS by number until 2009 when I had just changed all the fuel and vacuum lines and everything else I described. Right after that is when it began running with the funky idle. In 2009 I joined this forum it started out as a heat exchanger debate whether or not I needed them so I was convince I did and put them back on then went on to do all the other lines and hoses , at that time is when it developed this erratic miss and the last thing I did was replace the injector seals which fit well and compressed I was waiting for them to arrive hoping that they would fix this since they were to only item I didn't replace. I haven't replaced the runner short hoses since 97 when I rebuilt the engine or the intake thick FI gaskets . I didn't disturb those in 2009 and in the past when I replaced them never found them cracked and the paper gaskets were still in tact. It's quite possible through heat cycles and expansion and contraction they now have small leaks . I can find the runner hoses and all I see for intakes are the ones later FI air cooled bugs used which whatever supplier it was said they fit and work. Some here just use the old thick spacer and fit new thin paper gaskets.
It does seem like I have some sort of small vacuum leak. Finding it will be the difficult part.
Mike Fisher
Mike Fisher is offline
PostPosted: Fri Aug 11, 2017 10:27 am    Post subject: Re: Cleaning an electric AAR Reply with quote
I've always had to prime my fuel pump when it's cold. Starts good warmed up down town/highway etc. I broke my $15? primer button from Jim Adney. I'm gonna splurge on his newer 3 position switch this time to go with my 3rd new ignition switch! Mad
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
raygreenwood
PostPosted: Fri Aug 11, 2017 12:00 pm    Post subject: Re: Cleaning an electric AAR Reply with quote
Ok ...350 miles per year...same problem. That is virtually no miles. It either never fully warms up or does so and then sits for ages in between. Thats like .9 miles per day....or 6.7 miles per week.
Gaskets and hoses separate and get squirrel.
Not saying you are doing anything wrong....just that at that low of a driving rate...anything done back in 2009 is largely irrelevant now...gasket and seal wise.
See....and trust me this is NOT making fun of you or poking at you. These issues are JUST like the add header you see on many cars for sale...."ran perfect when I parked it 10 years ago" Laughing Wink
You can replace every gasket and seal on the engine with NOS or new...then park it...and it will leak when you try to start in 4-5 years. Take a brand new "0" miles car and put it up on jacks in a storage unit for 10 years...and take it out and many plastic and rubber parts including tires, shocks, some seals and master cylinders...will no longer function. Its age.
You have too many "rings" of un-resolved diagnosis and replacement going on and to many assumptions that certain items "should" be fine because you replaced them years ago and have driven hardly any miles...so they are kind of new...right? Uh..no. Those parts are 8 years old now. Especially rubber parts.
1. did you ever get it running perfect after you replaced the MPS with the right one?
2. Injector seals with low miles but are 8 years old...are 8 years old. They fare almost as bad when they do not run much....and by design...they leak either with age or heat cycles.
3. Runner boots commonly leak just from shrinkage ...but also...and I do this too....when you are tooling around on the engine on other items...its common to push against and/or lean on runners...causing shifting of the boots. It causes the elastic sealing action of the boots to come loose in spots.
These are the kinds of leaks that I described above. Some leak when cold....seal up when hot...and alternate ones open up when hot.
Runner boots 1997? Those are 20 years old. Replace them.
As I noted...if your AAR functions the way I described...and....you have no known ignition issues....everything you described as a symptom sounds either like a vacuum leak or a harness gremlin from an old harness.
Ray
blues90
blues90 is offline
PostPosted: Fri Aug 11, 2017 1:05 pm    Post subject: Re: Cleaning an electric AAR Reply with quote
Ray it ran better with the newer proper MPS yet not perfect it still has that erratic no load miss fire idle that clears only when the iAD temp sensor is unplugged. More than anything else it seems to be a vacuum related issue.
It runs fine while driving hot or cold no miss fire or hesitation. Just in drive the idle fluctuates just a tiny bit.
I'll need to check things over. Yet as I said all this began in 2009 when all the hoses and vacuum lines were replaced as well as the injector seals. Yes the runner hoses are suspect I did seal the IAD cover back in 97. The wiring and connectors might affect something yet they are not loose and the wires look fine not brittle or broken insulation can't say what there are like under the covered area. they are not flexible like new wire yet not rock hard and the connectors them selves are not brass they are a plated silver color and clean.
I don't hold myself up on the intake runners or push on them just hang over the engine by my back.
raygreenwood
PostPosted: Fri Aug 11, 2017 2:03 pm    Post subject: Re: Cleaning an electric AAR Reply with quote
Or....you can clamp the runner boots you have.
So the wiring PLUGS are tight....or are the connectors inside of them tight? This is the most common issue....wiring wise....that can cause the odd idle aymptoms you have. Too many people do this.....wiggle the plug.....feels tight....must be fine.
The fit of the plug in the components is no indicator of the fit of the terminals inside.
I think I said this a while back.....the issues that appear or disappear....when you do things like unplug that IAD temp sensor.....are telling you that your fuel mixture is off.
If the fuel pressure is correct and stable, no vacuum leaks, ignition is correct, sensors 1 and 2 have correct resistance.....and you have the correct MPS....engine is in good shape with good compression......and you have good grounds and connectors in the harness............and unplugging the IAD temp sensor changes the running for the better.....you need to adjust the MPS....period. Ray
blues90
blues90 is offline
PostPosted: Fri Aug 11, 2017 2:22 pm    Post subject: Re: Cleaning an electric AAR Reply with quote
I removed each connector from each plastic plug and got them to fit tight then put them back in the plug , did one connector at a time so as not to get them in the wrong place. not on connector had cracks on the rolled edges.
I clamped the short hoses at the IAD and runners.
I'm still going to replace some of the vacuum lines the ones to the trans and to the AAR from the IAD.
By the way this morning the fuel pressure was zero I suspect the pump all in one check valve not the regulator .
raygreenwood
PostPosted: Sat Aug 12, 2017 2:31 pm    Post subject: Re: Cleaning an electric AAR Reply with quote
Applause Applause ...way ro go! I cannot stress this type of terminal testing enough.
It could be either the pump or the regulator. At this age of vehcile.....all the pumps are suspect. At the pow miles you drive.....the regulator is also suspect.
If you have not done it.....test the pump volume while at pressure by wiring the pump direct and putting the return line into a graduated jar. Clamp off the end ro the tank.....it should maintain a steady 28 psi while delivering about 1 liter per minute. Ray
blues90
blues90 is offline
PostPosted: Sun Aug 13, 2017 11:01 am    Post subject: Re: Cleaning an electric AAR Reply with quote
I suspect the pump is putting out enough volume beside screwing around with the fuel lines and checking pressure and volume at this point even though it is a valid test even brought up in the Bentley will only tell me parts I know I will need because their old . the Regulator is nowhere close to how old the pump is. Just an Airtek or similar pump and a new regulator will cost at least $200 that I don't have. Certainly I wonder while driving what if the pump just quits yet I keep in out of my mind .
AS far as driving more when one is retired and close to 69 and stuck in this non stop 24/7 traffic state there is really no place I care to drive to , was different not that many years ago when I worked and we drove to the beach or just drove to see places . If I said how much we have each month to spend which I won't most would wonder how we even make it .
That's all beside the point of finding out what's wrong with the running of this car.
Yesterday I added a primer switch . From what Jim Adney described he does it different . I had a 6 amp mini momentary toggle switch already mounted in the plastic cover under the steering column the one that has 3 small screws and it's on the left side right where the windshield washer hose comes to the TS switch . I used to use it to power the cold start valve years ago. My pump uses fuse #7 I already removed the key buzzer warning long ago and use fuse 9 which only fed the buzzer. I use it to power my radio and through a relay the 3 VDO gauges and a tach . I used a relay because fuse 9 is hot all the time and the relay coil is powered by a key on fuse #12 the radio can be on/off using the radio then it's memory is hot all the time.
I already had fused power to the switch so I removed the pump red lead off the pump relay and ran the other switch wire combined with the red pump + on #87 relay to an 1/4" 3 end spade adapter basically splicing one lead of the switch the red+ pump to #87 on the relay . Don't need to turn on the key just use the switch till I hear the pump prime release it then turn the key and it starts. This at least saves me keying on/off and each time you do this the fuel gauge and the warning lights as well as the tach and 3 added gauges all go on and off . Seems like Jim has to turn on the key once and leave it on then use the switch so you get one 1 1/2 sec pump relay his way then the pump relay opens after the 1 1/2 sec .
One point I want to add on this primer switch if you have an auto trans or an electric AAR it's tied to #87 same as the pump + so as you hold the primer on which is short the AAR is powered on mine it is not a double connector on the pump relay as earlier models it goes through two other connectors further down . I can't recall if the relay had 4 or 5 connections I think 5 2 at the bottom with a plastic plug for the coil from the ECU 2 at the top B+ pump and #30/51 fuse #7 hot all the time since #87 in the Bentley shows it is internally connected to the feed for the AAR the 5th terminal is another #87 I'll need to look. Since #87 on mine has these 2 connectors one is a 1 to 2 wire one goes to the EGR valve which I removed long ago so someday if I'm still around and motivated I'll remove all the extra wire that end up to the EGR relay connector removed the relay and from the EGR valve and relay one goes to the ECU and two go to the TPS #17 & # 14 , #14 then goes to the ECU . It's just a lot of extra wire I don't need just to tell the ECU when to open the EGR through it's relay and throttle position, in my opinion even though I haven't found an FI electrical issue it could present one . The EGR valve was on the right side of the engine and the EGR relay was on the bracket the Pressure sensor bolts to. I just have that connector zip tied out of the way. The EGR valve leads 1 double wire and one single come out of the FI harness covering . Perhaps I can use those for something else like I used the test connector for an easy path for my tach and oil pressure and oil temp gauges since I don't have a vw testor why not use them , they make a nice way from the engine to under the rear seat without running extra wires I just accessed them under the rear seat and ran leads from the dash along the right side of the tunnel to those out to the engine. Since the EGR relay plug is right by the pressure sensor the TPS wires #14 & #17 have a long path to the ECU and I don't need #14 . Like I said someday .
raygreenwood
PostPosted: Sun Aug 13, 2017 1:50 pm    Post subject: Re: Cleaning an electric AAR Reply with quote
The problem with regulators.....especially now days with alcohol in the fuel....is that if you do not drive it much or often....a brand new regulator can be dead from rust pits on the metering plate in 6 months. Been there..done that.
Personally I would at least replace the regulator now. They are typically $50-70 new at various places on line. Ray
blues90
blues90 is offline
PostPosted: Sun Aug 13, 2017 2:40 pm    Post subject: Re: Cleaning an electric AAR Reply with quote
Since there is ethanol in the fuel and I at least drive it 2 to three times a week and need to prime it each time there is still ethanol in the fuel even if I drove it every day and it will be in the regulator as well as the tank are you saying that just the fact that the fuel circulates more as I drive more this prevents the rust ? Or slows it down? Why would I get a new regulator if it will rust in 6 months since I won't be driving any more than I do now. There has been ethanol in the fuel here for a very long time at least 8 to10 years I know of . the chart below is all I could find on the year and amount of this crap in the gas.
Year Est. Fuel Ethanol Use
(Gallons) Default Ethanol %
in Gasoline
2003 588,742,569 5.7
2004 899,426,256 5.7
2005 953,699,151 6
2006 949,272,222 6
2007 939,616,852 6
2008 970,226,026 6.5
2009 964,152,694 6.5
2010 1,488,270,163 10
2011 1,464,238,509 10
2012 1,453,286,619 10
2013 1,460,360,124 10
2014 1,478,132,568 10
2015 1,519,421,248 10
raygreenwood
PostPosted: Sun Aug 13, 2017 4:26 pm    Post subject: Re: Cleaning an electric AAR Reply with quote
in Gasoline
2005 953,699,151 6
2006 949,272,222 6
2007 939,616,852 6
Simple....fuel with ethanol....that is not run out or refilled often....absorbs lots of water. Typically more than it can entrain and neutralize.
Its not the ethanol that rusts the regulator....its the water in the fuel.
If you drive it more.....preferably getting down close to empty and refilling.....you keep the actual amount of water in the system to a minimum.
If you are driving very little....and rarely fill up.....its common with ethanol fuels that you can have rust pits starting in as little as 6 months. Also its not JUST the water beating on the regulator.
As I noted some pages back and in my link to the regulator dissection....the metering plate inside is nickel plated to prevent rust.....but the harmonic issues from pump, injectors and regulator open/close......regularly wear the metering plate.
If you drive a lot or often and keep water in the system to a minimum....the regulator can drives for years with this normal wear with no real rust issues.....because keeping fresh fuel on the metering plate....means that there is hopefully little water there ....which contains oxygen and promotes rust.
But once normal wear starts peckimg away at the nickel plate....it will rust quick.
Why replace it?.....how old is it?....how long in the ethanol fuel era....have you been sparsely driving it?
If you are having fuel pressure modulation issues.....and its eithher pump or regulator....and usually a bit of both.....you can spend 1/4 of that $200 you dont want to spend and probably fix half the problem now.
Then just change your driving habits a bit. Ray
blues90
blues90 is offline
PostPosted: Sun Aug 13, 2017 7:08 pm    Post subject: Re: Cleaning an electric AAR Reply with quote
in Gasoline
2005 953,699,151 6
2006 949,272,222 6
2007 939,616,852 6
I really don't know what to say. I went to a few you tube vids on this and oddly each one has a product to sell you . I also looked at just sites telling you with words how it all ends up. Basically time wise with a sealed fuel system you might get 180 days before you need to dump all the gas in the street sewer drain or perhaps place a valve at the bottom of the tank drive off and let it leak out and evaporate.
Like I said what to say. I guess I'm pretty much screwed provided what I've read and one buys into anything the internet spouts out after all there is a product for every thing and everyone.
All I can say near the end of 2009 when I changed all the fuel lines and filter and the short injector hoses I made it a point to really look inside each of the metal pipes the injectors on both sides connect to , why , because I have a spare set that came off a 72 that had not fuel in the tank and no gas cap for years and they were filled with rust. Looking at mine and three year before this work I drove every single day filling the tank at least once a day because I was driving for a messenger service using my car and ethanol at about 6% three years later when I changed the lines and looked ethanol was 6.5% and the very next year 10%.
No saying ethanol is a treat or does not ruin anything . I recall days far gone by when it was just gas and leaded and later lead free no ethanol and a few times at the pump I got water , enough to cause the fuel filter to ice up in cold Indiana engine quit like it ran out of fuel and they had some stuff you put into the tank that somehow mixed the water or cause it to evaporate because then no car had a closed fuel system who knows it did work unless you got a bad batch of fuel from a pump that was filled with rust and water that came from the truck that filled their tanks.
Now after all this time that my car has been driven about 350 miles per year I would at least think my engine would run real bad because of rust and water in almost everything mainly injectors plugged up at best the fuel filter would be plugged been on there since 2009 and I'd have no fuel delivery at all or it would be so restricted that it would have now power. Maybe it would slug just water and no fuel since the water + rust and just quit which it's never done.
I doubt my closed system is up to pare even though it's still all there . I looked inside every single metal line in 2009 and found no rust what came out of the tank when I pulled the line to the filter because I needed to change that line to the tank was fuel and the tanks brass sock has never been changed since I had this car. I would need to drive say 350 miles each say 180 day cut in half = three months course this depends on fuel MPG sitting in traffic at idle just wasting fuel . What I do for years now is let the tank use 7 gallons of the 10.6 then fill not topped off yet close very close to every three months . I guess the car is border line screwed .
Anyone else care to chime in on this and what they experience because I'm pretty sure not everyone drives their FI T-3 or whatever all year long say in the winter where it gets cold and salt on the roads eating up their new paint job.
Not saying Ray is wrong my car could suddenly just quit running sooner than later and not agreeing with any of the ad's selling products that some how make the water vanish .
raygreenwood
PostPosted: Sun Aug 13, 2017 7:25 pm    Post subject: Re: Cleaning an electric AAR Reply with quote
Rolling Eyes ...sigh..... Laughing
Here is the deal. Ethanol along with the water it bears...along with wear can rust things quickly...or slowly. It MAY do the former.....it WILL do the latter.
You started a thread suspecting your AAR of small annoying issues with idle. From your responses that it does open and close all the way.....thats the last part i would suspe t causes any of your symptoms.
However.....the fuel pump check valve possibly leaking down.....and regulator leaking down.....and injector leaks can and will cause those minor but annoying and chronic symptoms.
Add to this....your car is the perfect candidate for those age and moisture related issues. Its rarely driven and not far and sits for periods....and has ethanol in the fuel.
You can keep driving it probably for years more without doing a thing or spending a dime.
But if I am right.....and there is no way to really know without testing the parts as I have suggested..........if I am right....it will just slowly get worse over time.
Back in the days of real gasoline you could drive a car once a month....fill up four times a year....and never bat an eye. Not anymore.
Also....fuel system aside.....the worst thing on suspension parts like shocks and bushings, and under the hood....hoses and manifold seals.....and for sure brake parts and hydraulics.....is inactivity.
Ray
dooker
dooker is offline
PostPosted: Wed May 06, 2020 9:56 pm    Post subject: Re: Cleaning an electric AAR Reply with quote
Old topic but as I was pointed to this, used the tips and got my AAR to work I thought I share my 2 cents - I used smaller pipe pliers on both opening and closing. Initial post suggested to hammer the lips back but imo pliers do better job and will create less noise/mess
The existance of flamethrowers says that someone, somewhere, at sometime said "I need to set that thing on fire, but it's too far away."
eastsidecustoms.com
tmitoraj
tmitoraj is offline
PostPosted: Mon May 23, 2022 4:14 pm    Post subject: Re: Cleaning an electric AAR Reply with quote
Is there any type of filter that could be put in line with the hose that runs from the air cleaner to the AAR that would filter any oil or fuel vapor that might cause the AAR problems down the road.
Page 3 of 4
