MidWesty79 Samba Member
Joined: October 19, 2011 Posts: 503 Location: Milwaukee Wisconsin, US
Posted: Sun Aug 27, 2017 2:06 pm Post subject: Need alternator near Yellowstone (Bozeman, Helena?) *UPDATE |
Hey all,
So, I am currently in Jackson WY and it appears that the alternator in my 79 is dying. The belt is new and tight. I swapped in a spare regulator to check. When cold the alternator light is out, but once the engine is hot and driving the light comes on (sometimes has a fast paced pulse.)
Occasionally if I push in the clutch and rev it up to over 4K rpm, the light will go out for a moment, or sometimes even stay out for a minute or so, but then it comes back on.
I checked voltage at the battery when the light was on at idle and it was at 12.2 volts.
I am hoping to get to Glacier tomorrow, but NO ONE has an alternator in stock. Does anyone know of a place in-route that would definitely have one, or happen to have an extra working alternator laying around?
Thanks all!! _________________ 1979 Westfalia, 1975 BMW 2002, 1996 Mazda Miata, 1979 Jeep CJ5, 2006 325 XI Wagon, 2021 M240i (all manual transmission... as god intended.)
Posted: Sun Aug 27, 2017 4:10 pm Post subject: Re: Need alternator near Yellowstone (Bozeman, Jackson, Helena?) |
Read up on the necessary alterations to a new or rebuilt alternator. If you don't heed the offered knowledge you will end up at best with a burned up replacement and a burned up alternator or worse you could have a rig burned to the ground.
If you limit your power usage you can easily drive for a couple of hundred miles on a fully charged battery. |
Posted: Sun Aug 27, 2017 4:22 pm Post subject: Re: Need alternator near Yellowstone (Bozeman, Jackson, Helena?) |
Thank you for the tip! Anyone have a link to these "alterations?" My cell phone provider doesn't work hardly at all out here. It has been incredibly frustrating.
I found a parts store in Helena that can get me an aftermarket unit tomorrow, so I am on the 270 mile drive there hoping my alternator can keep me juiced til then. _________________ 1979 Westfalia, 1975 BMW 2002, 1996 Mazda Miata, 1979 Jeep CJ5, 2006 325 XI Wagon, 2021 M240i (all manual transmission... as god intended.) |
Xevin  Samba Member
Posted: Sun Aug 27, 2017 4:26 pm Post subject: Re: Need alternator near Yellowstone (Bozeman, Jackson, Helena?) |
Use at your own risk. But looks like solid info
https://youtu.be/W8_thFzpyxw _________________ Keep on Busin'
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
| Clatter wrote: |
Damn that Xevin...  |
| skills@eurocarsplus wrote: |
| SGKent wrote: |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42893 Location: at the beach
Posted: Sun Aug 27, 2017 4:29 pm Post subject: Re: Need alternator near Yellowstone (Bozeman, Jackson, Helena?) |
99% chance the brushes are worn out - classic way they fail. That said do check the belt for damage. Look in the yellow pages for an electrical shop that specializes in rebuilding alternators. I looked online and there is a shop in Billings MT. Call them (406) 252-7342 https://www.generatorstartershop.com/ to make sure they rebuilt alternators of your type.
Take the fan belt off now before you damage the core alternator if this is a T4 2L pancake engine. If it is an upright T1 engine do not take the belt off. You'll have to use a battery charger to charge the batteries between stops. You'll get about 100 - 150 miles on a charge daytime depending on how many electronics are on board. If it is a T4 motor you can remove the harness to it also if you are concerned their might be an internal short but I would probably leave it on myself. You can also remove the blue wire so the light doesn't burn out.
Richard Atwell on his website has a how to remove the alternator. _________________ George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
mtcamper Samba Member
Posted: Sun Aug 27, 2017 5:56 pm Post subject: Re: Need alternator near Yellowstone (Bozeman, Jackson, Helena?) |
| I got a 55amp Bosch alternator here in Missoula at http://www.autoelectricmissoula.com/ . If you need a place to work on it let me know. |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8586 Location: All Across The Country
Posted: Sun Aug 27, 2017 6:49 pm Post subject: Re: Need alternator near Yellowstone (Bozeman, Jackson, Helena?) |
| Amskeptic wrote: |
What, no more spare alternators under the camping tent poles under the bench in the garage?
Silty says hi.
Colin  |
Haha I thought of you when I saw this thread. I'm unfortunately currently out of Cobb webbed forgotten about silty alternators. |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12843 Location: San Jose, California, USA
Posted: Sun Aug 27, 2017 7:04 pm Post subject: Re: Need alternator near Yellowstone (Bozeman, Jackson, Helena?) |
| MidWesty79 wrote: |
| Anyone have a link to these "alterations?" |
Alternator Type IV (4)
Make sure the alt. cover is not touching anything that is hot on the alternator.
Good luck
Tcash |
Posted: Tue Sep 05, 2017 8:43 am Post subject: Re: Need alternator near Yellowstone (Bozeman, Jackson, Helena?) |
Just wanted to give an update. I was able to get an aftermarket unit in Helena MT at AutoZone, however, I didn't install it. I didn't want to deal with the alterations required/or the removal of the pulley while on the road. I continued up to Glacier NP, and then drove all the way back to WI running on solar with a fused jumper running from my deep cycles behind the driver seat (in the spare tire cabinet) back into the engine bay. Luckily I had clear skies for my entire drive home, as I never struggled with voltage driving during the day.
Now that I am home I can have the existing alternator rebuilt or at least find a higher quality replacement. Thanks to all of those who responded with assistance. _________________ 1979 Westfalia, 1975 BMW 2002, 1996 Mazda Miata, 1979 Jeep CJ5, 2006 325 XI Wagon, 2021 M240i (all manual transmission... as god intended.) |
