i_luv_my_bus76 Samba Member
Joined: May 18, 2012 Posts: 371 Location: High Desert
Posted: Thu Sep 21, 2017 11:47 am Post subject: Coil readings |
I am suspecting a bad coil is the reason my 69 bug will not stay running...
I disconnected the coil...from the + post to the - post I have a resistance reading of 3.6 ohms, which I understand is within spec and normal
From the center port/secondary post (where the ignition wire that goes to the distributor is located) to the positive I'm reading 7100 ohms which seems pretty low to me... I believe the spec is 9500 to 11000 ohms
Should I junk the coil and try a new one or is this not the source of my problem |
ROCKOROD71 Samba Member
Joined: January 18, 2012 Posts: 2770 Location: Boston, MA
Posted: Thu Sep 21, 2017 12:41 pm Post subject: Re: Coil readings |
Do you have another coil you can try or know someone with one you can try? Would suck to buy one for that not to be the problem. FLAPS like Auto Zone stock a cheap Chinese oil filled coil for under $30. If it ends up being the issue you can get a good one, Bosch Blue coil made in Spain is the best available. I still see some on Rock Auto, look under your 76 bus for them. _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
| 79SuperVert wrote: |
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it. |
| asiab3 wrote: |
Careful guys, a petulant child can grow up to be president these days. |
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy** |
David_nc_72std Samba Member
Joined: August 22, 2015 Posts: 839 Location: Winston-Salem, NC
Posted: Thu Sep 21, 2017 1:14 pm Post subject: Re: Coil readings |
| i_luv_my_bus76 wrote: |
Would you car to describe what you mean by "will not stay running"?
Does it start but then die within seconds, dies after running for a length of time, run at high RPM but dies at idle, etc.
If the car starts and runs for a short time, and does that consistently, I'd doubt there is anything major wrong with the ignition system. |
Posted: Thu Sep 21, 2017 1:18 pm Post subject: Re: Coil readings |
| ROCKOROD71 wrote: |
| Do you have another coil you can try or know someone with one you can try? Would suck to buy one for that not to be the problem. FLAPS like Auto Zone stock a cheap Chinese oil filled coil for under $30. If it ends up being the issue you can get a good one, Bosch Blue coil made in Spain is the best available. I still see some on Rock Auto, look under your 76 bus for them. |
I have a bosch blue on my bus...i was thinking of pulling it off and connecting it... |
Posted: Thu Sep 21, 2017 1:23 pm Post subject: Re: Coil readings |
| David_nc_72std wrote: |
I can get the motor started but after about 15 to 30 seconds it starts backfiring and then shuts off, no matter how fast the idle is... timing is correct...the coil gets hot but not sure if it is after the first attempt or many attempts |
sleeper bird Samba Member
Joined: August 27, 2017 Posts: 121 Location: Louisiana
Posted: Thu Sep 21, 2017 5:54 pm Post subject: Re: Coil readings |
| My 79 was doing the same thing ignition switch was bad,check and make sure your getting voltage to the positive side of coil.I was getting different voltages on mine sometimes 12v sometimes 9v. |
Posted: Thu Sep 21, 2017 5:56 pm Post subject: Re: Coil readings |
| sleeper bird wrote: |
Thank you very much I will definitely check for that...my problem is I don't have anyone to crank the motor while I check for voltage  |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Posted: Thu Sep 21, 2017 11:22 pm Post subject: Re: Coil readings |
Did this problem start suddenly or is it something that's gotten progressively worse over time? If suddenly, did you do any work to it right about the time it started giving you trouble? When's the last time you performed a full tune up, including first adjusting your valve lash? Can you keep the engine running by working the throttle? _________________ 1960 Ragtop w/Semaphores "Inga" |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13626 Location: West Coast, USA
Posted: Fri Sep 22, 2017 12:38 am Post subject: Re: Coil readings |
Consider the condenser suspect as well, since they are very susceptible to heat, and they build up heat while performing their day job.
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
Road trip reports and tech blog:
https://www.patreon.com/airschooled |
Posted: Fri Sep 22, 2017 4:42 am Post subject: Re: Coil readings |
yea i had to round up my neighbor for that,i did notice that when it did run if you hit or jarred the steering column it would kill when i first got it and got progressively worst ,the switch was sort of hard to troubleshoot due to different voltages i was getting from the coil and the wiring to the ignition switch,every time i checked anything it was different so i said what the hell and ordered a German replacement.Now it cranks first hit every time.And stays running,it was like the switch was not staying in the run position. |
Posted: Sat Sep 23, 2017 6:50 am Post subject: Re: Coil readings |
I changed the coil and put a bosch blue on...i installed a petronix flame thrower distributor...the coil doesn't get burning hit, but the positive and negative battery cables do
Bad starter???? |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11455 Location: Huntington Beach, CA
Posted: Sat Sep 23, 2017 8:36 am Post subject: Re: Coil readings |
The cables are hot, during cranking, after cranking or after running awhile?
How long were you cranking for? More than 10 seconds? A well tuned, good running condition engine does not take very much time to start. Long cranck times can cause a kinds of issues. Premature starter failure, premature battery failure, premature alternator/generator failure, fired wiring, burned grounds, compromised ignition switch, on and on. Those were the most common.
Or, are the cables getting hot just sitting or running? If so, have the battery checked out. Sounds like it may be working too hard to keep its charge alive. In which case, an acid bath of your floorpan area is imminent! _________________ Jimbo
| TDCTDI wrote: |
| Basically, a whole bunch of fuckery to achieve a look. |
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
Posted: Sat Sep 23, 2017 9:08 am Post subject: Re: Coil readings |
| VW_Jimbo wrote: |
Or, are the cables getting hot just sitting or running? If so, have the battery checked out. Sounds like it may be working too hard to keep its charge alive. In which case, an acid bath of your floorpan area is imminent! |
Hey Jumbo,
After cranking a few times for a few seconds the battery cables are hot...i haven't got it to run for more than 45 seconds and it takes 2 or 3 attempts to get it to run...last night I pulled the top of my card and replaced the needle and seat thinking maybe my engine was flooding due to a stuck needle |
Posted: Sat Sep 23, 2017 9:20 am Post subject: Re: Coil readings |
I always start at the basics. Valve adjustment, compression check.
If it will crank and start, can you keep it running by squirting carb cleaner into the carb? Then you should check quality, quantity and volume of fuel out of the fuel pump. Next is the fuel cut off solenoid, then the carb.
Ignore all that, if you already did that. Waiting for the results of your needle valve r&r. _________________ Jimbo
| TDCTDI wrote: |
Posted: Sat Sep 23, 2017 11:32 am Post subject: Re: Coil readings |
| I am currently at work I'm going to see if the needle and seat replacement helped when I get off... Compression check is great, rebuilt the carb a week or 2 ago just got lazy with the needle and seat...valve lash is perfect...new spark plugs and wires...im hoping the needle and seat is the ticket |
Posted: Sat Sep 23, 2017 3:30 pm Post subject: Re: Coil readings |
| VW_Jimbo wrote: |
Ignore all that, if you already did that. Waiting for the results of your needle valve r&r. |
Jimbo,
Your gonna laugh...i know i did...or you might be mortified
So the night I adjusted the valves I had worked 14 hours and decided to adjust the valves on my bug and bus...well I just rechecked the valves on the bug number 1 lock nut had backed itself almost all the way off knocking the valve lash out of wack... I must have not tight ed it all the way... what a bonehead move right...i could have really caused a catastrophe |
