FreewheelinWesty Samba Member
Joined: October 12, 2015 Posts: 72 Location: Norfolk, VA
Posted: Sat Sep 23, 2017 3:02 pm Post subject: Motor install help!!! |
hey y’all! i’ve had quite the busy day installing a motor, and i have some questions;
it’s a 2.1 (well 2.3) going into an ‘84, and im having some issue making the coolant pipes come together without any kinks, any suggestions?
the wiring harness that i have has a loose wire and i don’t know where it goes?
also there is a hose coming off of a coolant pipe that i have no idea where it might go?
i took as good of pictures as i could.
thanks! _________________ 1984 Vanagon Westfalia Wolfsburg Edition
Click to view image |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10484 Location: Orbiting San Diego
Posted: Sat Sep 23, 2017 3:37 pm Post subject: Re: Motor install help!!! |
You've got various troubles. That is a 2.1 out of a Syncro. Different cooling hose/pipe setup. Plus you are missing some needed cooling parts. You really would be better off with a 2wd 2.1 cooling hose setup. Maybe you have a friend with a 2wd 2.1 van who can bring it by for you to look closely at?
Good luck!
Mark |
Posted: Sat Sep 23, 2017 4:03 pm Post subject: Re: Motor install help!!! |
| crazyvwvanman wrote: |
Good luck!
Mark |
what needed parts am i missing? _________________ 1984 Vanagon Westfalia Wolfsburg Edition
