Subaru Frankenmotor
Page: 1, 2, 3  Next
jakelee
jakelee is offline
PostPosted: Wed Oct 25, 2017 11:39 am    Post subject: Subaru Frankenmotor Reply with quote
Hi all:
I'm in California. I have a 2.2L and would like to do the Frankenmotor conversion. So I found a 2.5L motor with 50k miles on it.
Will I need a new small car engine mount for the 2.5L? Just want to confirm before I order it. Thanks all.
DLJ
DLJ is offline
PostPosted: Wed Oct 25, 2017 11:43 am    Post subject: Re: Subaru Frankenmotor Reply with quote
Its plug and play. Use the motor mount you have. I would just go with the 2.5
jakelee
jakelee is offline
PostPosted: Wed Oct 25, 2017 11:48 am    Post subject: Re: Subaru Frankenmotor Reply with quote
Cool. Thanks!
Would love to go with the full 2.5, but it's illegal in California.
[email protected]
ahmed.aboudan@gmail.com is offline
PostPosted: Wed Oct 25, 2017 12:19 pm    Post subject: Re: Subaru Frankenmotor Reply with quote
Following. Let us know how it goes. I think there are specific year combinations that you are looking for. You might want to update yours heads to non hydraulic for example.
jakelee
jakelee is offline
PostPosted: Wed Oct 25, 2017 12:38 pm    Post subject: Re: Subaru Frankenmotor Reply with quote
Non-hydraulic heads??? Ok, I'll check it out.
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Wed Oct 25, 2017 12:53 pm    Post subject: Re: Subaru Frankenmotor Reply with quote
From what I've read, the '99 25D has the phase 2 case (the crank journals are bigger) and squared dish piston tops. There are specific Cometic head gaskets that will dial your compression in to optimum for what you are looking at. Using stock 2.2 heads, the previously Dual-Overhead cam to your newly built engine that is again non-interference!!! Its my ambition too. Just waiting for my chance Smile
http://www.ultimatesubaru.org/forum/topic/141903-cometic-frankenmotor-gasket/
tristessa
tristessa is offline
PostPosted: Wed Oct 25, 2017 1:11 pm    Post subject: Re: Subaru Frankenmotor Reply with quote
I don't understand why people make such a huge deal out of the non-interference aspect.
Maintain your shit and use genuine Subaru timing components and it'll never be an issue.
PostPosted: Wed Oct 25, 2017 1:26 pm    Post subject: Re: Subaru Frankenmotor Reply with quote
I think that question is easily explained by the following:
Shit Happens
You don't know if the belt you bought new is actually going to go as far as the test batch indicated at the manufacturer's lab. You might have confidence, but do you have an easily replaced belt if it breaks on a non-interference engine, or do you have a minimum of two head jobs and however many new valves to replace the bent/broken ones? Maybe a good hole in a piston would do for you, too then?
Just wondering why anyone thought up an interference design, seems more like a ploy to get more sales. You don't really know what you are getting, anyway. I'd like to interject that where these things are designed, it really doesn't matter, since nobody keeps a car anywhere near 80K miles. Costs too much to keep old cars there. Mind-set in clear view on this issue. Car manufacturers do the following: make cars to sell. Hint hint.
[email protected]
PostPosted: Wed Oct 25, 2017 2:10 pm    Post subject: Re: Subaru Frankenmotor Reply with quote
Yes I think after 97 they went to manual adjustment for the valves. Better efficiency.
tristessa
PostPosted: Wed Oct 25, 2017 2:49 pm    Post subject: Re: Subaru Frankenmotor Reply with quote
Shit Happens
Sensors, coils and distributors can fail too. Should we get rid of those and go back to crank-driven magnetos just in case shit happens?
Shit can always happen, but if you maintain your shit and don't cheap out when maintaining your shit, the odds of shit happening decrease dramatically. Don't use the knockoff Chinesium timing belt kit from Fleabay or try to get another 5000 miles out of the one that should have already been replaced 10000 miles ago...
lucianosanchez
lucianosanchez is offline
PostPosted: Wed Oct 25, 2017 3:19 pm    Post subject: Re: Subaru Frankenmotor Reply with quote
2.5L is legal in California? I thought only 2.2 was?
1983.5 Aussan Brown Westfalia | 2016 to 2020
1983.5 Beige Westfalia | 2019 to Current
rubbachicken
rubbachicken is offline
PostPosted: Wed Oct 25, 2017 3:56 pm    Post subject: Re: Subaru Frankenmotor Reply with quote
AFAIK only 2.2 in legal here, although there are area's in cali that don't require smog, if you are lucky enough to live in one, then you could stick an audi v8 in the back
lucy our westy
lucy's BIG adventure
meet 'burni'
tristessa
PostPosted: Wed Oct 25, 2017 7:40 pm    Post subject: Re: Subaru Frankenmotor Reply with quote
2.5 isn't legal, but people have had good luck sneaking them under the radar with 2.2 heads & induction/injection setups.
PostPosted: Wed Oct 25, 2017 8:38 pm    Post subject: Re: Subaru Frankenmotor Reply with quote
Well, to break this thought down a bit, take a look at what is most reliable. Magnetos? Sure, how about 2? Seems like the aircraft industry requiring dual magnetos should tell other folks who are ACTUALLY interested in reliability something? Coil, dizzy? sure, I agree, shit happens. but a coil doesn't poke a hole in the piston. I would certainly rather have to replace a coil (not that the Subi has these), but oh well, I'd replace them.
I also agree on your point here, quality parts dramatically reduce the number of failures. On the other hand, try telling that to the person who bought the best stuff they could find and still had that belt fail? Its only statistics after all, and the person who has a failure that is one in a million is just as hurt as the guy who was the one in a thousand person. I believe that odds being better is different than eliminating the chances.
Wildthings
Wildthings is offline
PostPosted: Wed Oct 25, 2017 10:25 pm    Post subject: Re: Subaru Frankenmotor Reply with quote
Wonder what the difference in transmission life is as you go from a 2.2 Subi to a 2.5?
I have owned VW's for more than 40 years and have had plenty enough transmission failures from broken parts and failing bearings with stock or nearly stock engines. I can't imagine upping the torque by 50% and expecting the box to stay together anywhere near as long.
bajaleo Premium Member
bajaleo is offline
PostPosted: Thu Oct 26, 2017 5:43 am    Post subject: Re: Subaru Frankenmotor Reply with quote
This^^^
Living in California, I'm also planning to upgrade to a frankenmotor at some point in the near future.
My 8 year old rebuilt trans is already making some noises, and all I can think of is that my EJ22 has more power/torque than the trans was designed for.
That's why I'm also planning to go the SubaruGears route and install a Subaru 5 speed before the frankenmotor goes in.
Leo in San Juan Capistrano
1984 Wolfie Westy, Subaru EJ22 powered.
Jake de Villiers
Jake de Villiers is offline
PostPosted: Thu Oct 26, 2017 8:41 am    Post subject: Re: Subaru Frankenmotor Reply with quote
tristessa wrote:
Shit Happens
Exactly. I'm not going back to a side valve engine anytime soon - or carburetors, either!!
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
chompy
chompy is offline
PostPosted: Thu Nov 02, 2017 4:34 pm    Post subject: Re: Subaru Frankenmotor Reply with quote
I read this a while ago and meant to write something but forgot... all of this is correct except for the part about the engine being non interference. The pistons on 2.5s actually stick out past the deck, so you will definitely have interference if the timing is off or the belt breaks.
'81 Westfalia Subaru EJ22
Manual Transmission
PostPosted: Fri Nov 03, 2017 6:52 am    Post subject: Re: Subaru Frankenmotor Reply with quote
Oy Vey, really?!?!? My hopes and dreams dashed!
On the other hand, I guess I better chat up Cometic on the phone. Seems as if the more I found out on those head gaskets, the more I felt they had a handle on what each bit they sell does. From what I had been investigating, the super thick ones made to mate the 2.2 heads to the specific EJ25D '99 block gives two things: proper compression and clearance of the valves.
Now, there is probably another reason you are correct in saying that this would not be non-interference:
Just because the pistons don't touch the valves does not necessarily mean it is non-interference. I am still trying to wrap my head around that notion tho.
bbaythav
bbaythav is offline
PostPosted: Thu Dec 14, 2017 1:10 pm    Post subject: Re: Subaru Frankenmotor Reply with quote
Frankenmotor experts,
I found a 2015 2.5L suby with 20k miles on it. I have a 1997 2.2L suby now. Will this 2015 2.5L block work for this Frankenmotor setup or will I need an older 2.5 block?
Thanks!
Page: 1, 2, 3  Next
