AirDirect Samba Member
Joined: November 03, 2010 Posts: 431 Location: Powderly TX
Posted: Wed Sep 03, 2014 7:31 pm Post subject: Noah's 1972 Standard Beetle Restoration |
We have had a lot of forum members asking about the DPD A/C system and in particular most people suggest using a newer style compressor to reduce the load on the engine. We have made a video showing the compressor cycling while the engine is at idle. We installed a vacuum valve and electrical relay to remove the 5 degree retard (DVDA only) when the compressor is on. This gives the engine a power boost when at idle with A/C on. At this point we are very happy with the performance of the DPD system.
https://www.youtube.com/watch?v=XkwocM5sO7Q |
Posted: Thu Sep 18, 2014 8:41 am Post subject: Noah's 1972 Standard Beetle Restoration |
Filling up with 93 octane at CEFCO Paris TX.
Fastlife1K Samba Member
Joined: January 19, 2015 Posts: 6 Location: Houston, TX
Posted: Tue Jan 20, 2015 4:26 pm Post subject: |
| Great build! |
vamram  Samba Member
Posted: Tue Jan 20, 2015 4:28 pm Post subject: |
What a beauty...!!  _________________ "Men are qualified for civil liberty in exact proportion to their disposition
'75 Super Le Grande...we hardly knew ye. Sold 2025 for peanuts.
Click to view image
Save the Supers!! |
Posted: Fri Nov 20, 2015 12:47 am Post subject: Re: Noah's 1972 VW Type 1 Sedan Restoration |
Washing my car before heading to the Texas DPS for my driving examination!
Great day! Passed my driving exam with flying colors (Kasan Red).
Her first question was "would the seat go back any more". I told her the car was bigger when I first got it (age 11). |
CB75 Samba Member
Joined: August 16, 2012 Posts: 88 Location: Ontario Canada
Posted: Fri Nov 20, 2015 1:11 pm Post subject: Re: Noah's 1972 VW Type 1 Sedan Restoration |
| Hey congrats on the license. Great thread hope my kids are into building a car when they get older. You should be very proud |
Posted: Fri Nov 20, 2015 7:01 pm Post subject: Noah's 1972 VW Type 1 Sedan Restoration |
In the process of getting the car ready for a road trip to see my older brother and sister. While adjusting the points and setting the ignition timing, I discovered the engine had 3/16 of an inch of crankshaft end play. Watching the V belt pulley with engine idling the crankshaft was cycling in and out, amazed it was still running. Also noticed that when I push in the clutch pedal the engine RPM increased (now I understand it was the timing being advanced as the crankshaft moved in relation to the distributor gear). This was the second time I have had to address end play since overhaul. I re-shimmed it about 7,000 miles earlier. Was only able to get it to .006. I am sure the number 1 main bearing has machined its way into the bearing saddle. With my Dad's help, we developed a fix to allow me to continue to run the engine a few more miles so I can have a chance to get another crankcase ready to swap. The fix is a bracket mounted under the generator bracket, fuel pump, and case half bolts. This bracket supports an adjustable roller bearing that rides against the A/C pulley face.
Works really slick and can be removed for belt change with just one bolt.
Wonder the German engineers did not think of this! |
Posted: Fri Nov 20, 2015 7:06 pm Post subject: Noah's 1972 VW Type 1 Sedan Restoration |
Now that the crankshaft end play has been addressed, we are off on a road trip with my younger brother Micah!
Posted: Sat Jan 02, 2016 7:02 am Post subject: Noah's 1972 VW Type 1 Sedan Restoration |
We removed the engine and started teardown. Will post pictures of old engine once the cylinders are removed. We plan to use the cylinders and pistons on the new build. Here is a picture of the car being backed into the shop for engine removal.
Getting started on the engine removal
Engine removed, note we did not have to discharge the A/C system. |
Posted: Sun Jan 10, 2016 11:09 pm Post subject: Noah's 1972 VW Type 1 Sedan Restoration |
Here is an update. The replacement engine is finished, installed and tested for about 400 miles. It runs very good. We installed hydraulic lifters and a new camshaft. The difference is awesome. Engine is very quiet and smooth. This initial setup on Crankshaft End Play was .003.
Replacement engine teardown.
Engine rebuilt and ready for installation.
Finished, car is ready for the road.
sixfootdan Samba Smartass
Joined: February 13, 2002 Posts: 4852 Location: \Lo*ca"tion\, n. 1. The act or process of locating.
Posted: Mon Jan 11, 2016 6:19 am Post subject: Re: Noah's 1972 VW Type 1 Sedan Restoration |
Looks like mine before the steroid treatment lol
_________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
Posted: Sun Mar 06, 2016 3:18 pm Post subject: Noah's 1972 VW Type 1 Sedan Restoration |
Beautiful view on a warm Sunday afternoon. Thank you Lord for the wonderful weather today.
Beetlebaum Samba Member
Joined: December 04, 2008 Posts: 2181 Location: Virginia Beach, VA
Posted: Mon Feb 27, 2017 11:13 pm Post subject: Re: Noah's 1972 VW Type 1 Sedan Restoration |
Added VW mud flaps!
Posted: Sun Apr 23, 2017 6:57 am Post subject: Re: Noah's 1972 VW Type 1 Sedan Restoration |
VW Spring Fest at Bob Beck's VW in McKinney, Texas. Car is still running perfect. It was cold and looked like rain, but the rain held off and we had a good time.
Keeponbuggin64 Samba Member
Joined: January 01, 2017 Posts: 42 Location: Burlington
Posted: Sun May 21, 2017 10:54 am Post subject: Re: Noah's 1972 VW Type 1 Sedan Restoration |
| beautiful job😊 |
63Ragtop NZ Samba Member
Joined: December 04, 2007 Posts: 895 Location: West Auckland
Posted: Sun May 21, 2017 3:21 pm Post subject: Re: Noah's 1972 VW Type 1 Sedan Restoration |
ah kids, they grown up so fast.
 _________________ If you can't join them, beat them! |
Posted: Thu Nov 30, 2017 1:32 pm Post subject: Noah's 1972 VW Type 1 Sedan Restoration |
Headed to town for oil change. Car is running great!
67ctbug Samba Member
Posted: Thu Nov 30, 2017 1:41 pm Post subject: Re: Noah's 1972 VW Type 1 Sedan Restoration |
I don't know if it's Noah posting these, but the car looks beautiful! I dream of mine to look as nice! _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
| KentPS wrote: |
...or the PO envied the terrorists' bus in "Back to the Future".  |
| mukluk wrote: |
| He's fine, just waiting for the dragon in winklepickers to move out of his lane. |
Posted: Tue Dec 05, 2017 8:04 am Post subject: Noah's 1972 VW Type 1 Sedan Restoration |
| Thanks! |
