Type 4 timing scale
furgo
furgo is offline
PostPosted: Fri Dec 22, 2017 4:42 am    Post subject: Type 4 timing scale Reply with quote
I've got an aftermarket timing scale that works just fine. It's the aluminum type with printed (not etched) angle values. I've also seen black plastic ones.
But just out of curiosity, does anyone know what the original timing scales looked like? Metal? Plastic? Did they change throughout the years? Did they have markings for the correct static timing of the engine they were installed on?
'79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Decode your M-Plate
SGKent Premium Member
SGKent is offline
PostPosted: Fri Dec 22, 2017 8:22 am    Post subject: Re: Type 4 timing scale Reply with quote
plastic. They are still around.
George Carlin:
Skills@EuroCarsPlus:
1971 deluxe (sold)
1977 deluxe
russwiththebus
russwiththebus is offline
PostPosted: Fri Dec 22, 2017 8:37 am    Post subject: Re: Type 4 timing scale Reply with quote
I think the originals were painted metal, but the majority are plastic. I replaced mine with an aluminum etched one years ago. They should all have the same markings I think.
CIP1 sells both versions now: http://www2.cip1.com/SearchResults.asp?Search=021-119-249-E
View user's profile Send private message Send e-mail Visit poster's website Twitter Instagram Gallery Classifieds Feedback
Bleyseng
Bleyseng is offline
PostPosted: Fri Dec 22, 2017 9:21 am    Post subject: Re: Type 4 timing scale Reply with quote
Early type 4 bays had the painted metal ones (72-75) then the rest had the black plastic ones
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles
busman78
busman78 is offline
PostPosted: Fri Dec 22, 2017 9:31 am    Post subject: Re: Type 4 timing scale Reply with quote
Originals were metal painted white with painted/printed timing scale. As to what year VW switched to the black plastic I do not know, but the only two metal ones I found intact where on unmolested 1.7 engines.
airschooled
Air-Schooled
airschooled is offline
PostPosted: Fri Dec 22, 2017 10:29 am    Post subject: Re: Type 4 timing scale Reply with quote
It's hard for me to post and not start an "aftermarket parts bitch-fest" but I think ignition timing is important enough to bitch about. Cool
Here is Andrewtf's engine with three timing scales; the engine was not turned at all when switching scales. See any issues here?
Early dual carb bus scale:
Fuel injection scale from a later bus:
Piece of shit from a shiny catalog somewhere.
3-4 degrees off isn't a big deal for valve adjustments, but it can be the difference between a long-lasting engine and an engine that can't get out of it's own way…
Robbie
WTB: 215mm Type 4 flywheel. Cash in hand.
www.airschooled.com
Road trip reports and tech blog:
furgo
furgo is offline
PostPosted: Fri Dec 22, 2017 10:47 am    Post subject: Re: Type 4 timing scale Reply with quote
Thanks everyone, I think this pretty much summarizes it, then.
That's also made me realize that my scale looks worryingly similar to the POS one Robbie posted. Right up to the "HPO" marking.
Back when I got it, the plastic one and the metal one (printed, not etched in my case) costed about the same. I bought the metal one thinking it would be longer-lasting. But now that I think of it (and see the 3-4 degrees off), it could also be easily bent during installation.
Is the aftermarket plastic one a better choice, then?
Decode your M-Plate
Wildthings
Wildthings is offline
PostPosted: Fri Dec 22, 2017 11:20 am    Post subject: Re: Type 4 timing scale Reply with quote
I have certainly considered just installing a pointer on the fan shroud for TDC and eliminating the timing scale. An additional "v" notch on the pulley at 28° BTDC would then be all you need to time your engine.
SGKent is offline
PostPosted: Fri Dec 22, 2017 11:33 am    Post subject: Re: Type 4 timing scale Reply with quote
and some folks thought I was anal for setting my timing scale TDC to real TDC. After seeing Robbie's comments now you know why...
https://www.thesamba.com/vw/forum/viewtopic.php?t=409853&highlight=tdc+timing
George Carlin:
1971 deluxe (sold)
1977 deluxe
aeromech
aeromech is offline
PostPosted: Fri Dec 22, 2017 11:52 am    Post subject: Re: Type 4 timing scale Reply with quote
Something tells me that the Chinaman making those scales cares less about accuracy and more about making a buck. Too bad he can't do both at once because it looks to me like making one that's accurate would be about the same amount of work.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
SGKent is offline
PostPosted: Fri Dec 22, 2017 12:04 pm    Post subject: Re: Type 4 timing scale Reply with quote
shroud has some play in it too. Easier to find TDC on the flywheel, mark it and bend the scale to show zero at zero. Took about 5 - 8 minutes to do it. More to write the how to than do it. Been verifying TDC on every engine I built since the 70's.
George Carlin:
1971 deluxe (sold)
1977 deluxe
aeromech
aeromech is offline
PostPosted: Fri Dec 22, 2017 12:45 pm    Post subject: Re: Type 4 timing scale Reply with quote
Might have been easy for you but the one I'm thinking of was so far off that there wasn't enough bending I could possible do to make it right.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
SGKent is offline
PostPosted: Fri Dec 22, 2017 1:25 pm    Post subject: Re: Type 4 timing scale Reply with quote
that's only because y'all in San Diego county have too many parties and tequila skews the vision the next day. Smile I can't tell you how many people told me when I lived down there so many years, "Well, I've had my fun and partied hard, time to go back to the mid-west and get to work.... ."
George Carlin:
1971 deluxe (sold)
1977 deluxe
aeromech
aeromech is offline
PostPosted: Fri Dec 22, 2017 2:08 pm    Post subject: Re: Type 4 timing scale Reply with quote
The time I'm thinking of the fan housing had the 12 o'clock timing hole with the plastic plug. So I could set up TDC using the case split line. Then when I installed the aluminum scale I could see it was off by 3-4 degrees. As I recall there was no possible way to bend it to make it work. I guess I could have welded up the mounting holes and redrilled them but I didn't do that.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
furgo
furgo is offline
PostPosted: Fri Dec 22, 2017 2:27 pm    Post subject: Re: Type 4 timing scale Reply with quote
Thanks for sharing this. It seems a simple question has opened a can of worms. Which is a good thing, as it hadn't crossed my mind before that the scale might not be accurate. I just trusted it blindly.
So that shows two instances of aluminum scales (two diferent makers by the looks of it) that were off by 4 degrees.
I can't drop the engine to double-check the TDC on the scale, but I can get a plastic scale to compare.
I'm also wondering if there is an easy (read: engine in place) way to tell if a scale is offset or not. I had read in the forums that the fan shroud fin had to be aligned with the 32° mark, but I did not know if it was an accurate piece of information.
Now looking at Robbie's pictures, it would seem that the OG painted metal scale and the (aftermarket or OG?) plastic one do align with the shroud fin at 32°, whereas the aluminum aftermarket one doesn't.
Then again, it might also be the angle at which the pictures were taken.
Decode your M-Plate
Wildthings
PostPosted: Fri Dec 22, 2017 3:57 pm    Post subject: Re: Type 4 timing scale Reply with quote
I think the V mark is there on the inside of all the fan shrouds (could be wrong here) and it would not be that hard to accurately make a TDC mark on the fan to align it with. You could then just drill a hole in the top center of the fan shroud to check the timing scale accuracy. The hole would need to be plugged somehow when you were done. A piece of sheet metal and a couple of screws would do, though there are many possible solutions.
Busstom
Busstom is offline
PostPosted: Fri Dec 22, 2017 4:17 pm    Post subject: Re: Type 4 timing scale Reply with quote
Here's a winner for ya, from Bus Depot. And I bought it because the kid on the other end of the line said "Uhhh, yeah, it's engraved." Yeah, it's not.
6mm screws don't fit through the holes, the left end isn't fully bent to a 90, but 45 instead. The spacing between the graduations is inconsistent, it actually has a smaller radius (the curvature) than the OE scale, and most annoying of all, I was told that the characters were engraved. Yep, straight outta China. It looks like one above is the exact same one, except both ears were bent 90 degrees.
Easy fixes, yes. No, I didn't complain to them...it's not worth my time.
furgo
furgo is offline
PostPosted: Fri Dec 22, 2017 4:56 pm    Post subject: Re: Type 4 timing scale Reply with quote
Wow, well spotted!
Here's mine, bought on the other side of the pond but coming from exactly the same place. I do remember having to fiddle with it to fit, but it was a long time ago and I didn't document it back then (which you did a great job at, btw).
That inconsistent spacing between 24° and 26° is also there on mine. At least 1 degree if not more:
For one thing, I'll be happy if this thread at least shows folks which scale not to get.
Decode your M-Plate
Busstom
Busstom is offline
PostPosted: Fri Dec 22, 2017 5:27 pm    Post subject: Re: Type 4 timing scale Reply with quote
Thanks...and I agree with ^this^ statement.
aeromech
aeromech is offline
PostPosted: Fri Dec 22, 2017 6:23 pm    Post subject: Re: Type 4 timing scale Reply with quote
Yep, same here. Now guys, how freaking hard is it to make the holes fit a 6M bolt?
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
