The '71 Deluxe
dumptuck
dumptuck is offline
PostPosted: Wed Aug 16, 2017 9:28 pm    Post subject: The '71 Deluxe Reply with quote
So this journey actually began 3 years ago with a different bus, a 1974 orange & white transporter. While picking it up, we also saw the seller's 2 other buses, one of which was a red camper with a rusty frame, and another (which wasn't for sale), a beautiful rust-free '71 Deluxe, white on sky blue. Well the '74 ended up being a much bigger project than anticipated, and we ended up selling it about a year or so later. Fast forward to yesterday, I was browsing craigslist when I came across an ad for that very same '71. Unfortunately, it was (while still reasonably priced) way out of my budget. I set it aside and went to sleep for the night. Upon checking my phone the next morning, I couldn't believe my eyes when i saw that the price had dropped significantly, making it a great deal (no idea why, this was never explained). I immediately called the seller, left him a deposit, and this morning I hopped on a ferry to go grab my newest find. It ended up being better than expected, with new suspension, drive axles, starter, glass pack muffler, and nearly no rust on the entire vehicle. I then learned that it had been brought up from Lake Tahoe about 9 years ago, making it one of those california gems. I happily handed over the cash, grabbed plates & a fire extinguisher, and began the drive home. Unfortunately, while the bus was running great, we ran into some electrical issues. Here is where I need your help; the bus would die after driving about half a kilometer and wouldn't even turn over afterwards. We remedied this by hotwiring past the janky ignition (which would sound the horn continually upon removing the key Rolling Eyes ) and managed to start it again. Shortly after, without much progress, the bus died again, and we lost power to the dash completely. No amount of fiddling with wiring would bring any power to the wire that (we think) came from the starter, a heavy guage red wire that we used to start it earlier. We know the battery has charge, as the radio was working fine the entire time and we tried a circuit tester on the terminal. Any ideas what may be going wrong? The bus is currently parked on the side of the road, a ferry ride away from our home back on the mainland. I hope to rent a U-Haul and pick it up this saturday. I'll include some pictures in a follow up post. Thanks in advance everyone!! Very Happy
dumptuck
dumptuck is offline
PostPosted: Wed Aug 16, 2017 10:25 pm    Post subject: Re: The '71 Deluxe Reply with quote
Here is the bus in the background when we picked up the '74 a few years ago
Here was the bus today
The interior, early westy seat & late westy full width bed, neither of which are original to the bus
The 1600 engine, which is in fantastic shape as far as we can tell (no oil leaks anywhere, runs nicely)
Broken down in the middle of the road Embarassed
The kind seller coming to help us in his vanagon
Pushed it to the side of the road
It's current resting place until this weekend
That's all for now folks...
Spike0180
Spike0180 is offline
PostPosted: Thu Aug 17, 2017 6:53 am    Post subject: Re: The '71 Deluxe Reply with quote
1971 Wiring diagram. If you haven't ordered the Bentley yet, do so. It's a life saver.
https://www.thesamba.com/vw/archives/info/wiring/bus_8_70_usa.jpg
Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic"
danfromsyr
danfromsyr is offline
PostPosted: Thu Aug 17, 2017 8:54 am    Post subject: Re: The '71 Deluxe Reply with quote
these old cars are very easy to 'hotwire' and make a quick makeshift emergency 'harness'
you need a wire from the Battery +pos to the coil (+15 terminal)
this can be accomplished with a vinyl wrapped coat hanger or dog lead if needed.. provide power to the coil. you'll need to remove the wire to turn off the engine.. you can put a simple switch in the middle of said wire.. even a household light switch would work as a switch to interrupt the path.
all that the stock switch does to run the engine is connect the battery +12v to the Coil +15 terminal. you probably want to disconnect the old wire that came/goes to the coil so you don't back feed the faulty system.
then you can run a wire from the starter terminal and touch it to the +Pos on the battery.. this will energize the solenoid that will get the starter cranking..
it can be loose. it only gets power if/when you touch the batter post..
use the key to unlock the steering.. but it's not necessary to run and drive..
protect all bare wiring ends and connections from shorting out.. that'd be bad okay.
as for tail lights and such, have a car follow you. and/or buy these magnetic emergency lights from your flaps. and put them on the back, few people will question an old VW with flashing stick on lights..
https://www.google.com/search?q=magnetic+emergency...mp;bih=896
Abscate wrote:
dumptuck
dumptuck is offline
PostPosted: Sun Aug 20, 2017 9:54 am    Post subject: Re: The '71 Deluxe Reply with quote
Yesterday we returned to pick up the bus...
On the ferry
Unloading...
Made it!
Decided to clean up the interior
Oddly enough, the power to the dash has mysteriously returned, although we believe the ignition is bunk and needs replacement, as it doesn't spring back the key upon being pushed to the "start position". I was also poking around my engine, and I saw that there was about half a quart of oil in my airfilter, I've heard this is common but how can I fix it? Also, I do already happen to have a muir book and bentley from my last bus. Thanks again everyone!!
aeromech
aeromech is offline
PostPosted: Sun Aug 20, 2017 10:01 am    Post subject: Re: The '71 Deluxe Reply with quote
I believe you have a stock "oil bath air cleaner" in your bus. It's supposed to have oil in it
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
dumptuck
dumptuck is offline
PostPosted: Sun Aug 20, 2017 10:28 am    Post subject: Re: The '71 Deluxe Reply with quote
Ah okay, thanks for clarifying. I thought it was a bit weird.
Tcash
Tcash is offline
PostPosted: Sun Aug 20, 2017 11:08 am    Post subject: Re: The '71 Deluxe Reply with quote
Congratulations
IIRC the Air cleaner service is in the owners manual and in the Bentley.
Owners manuals
Air Cleaner ID T2
Good luck
Tcash
dumptuck
dumptuck is offline
PostPosted: Fri Jan 05, 2018 4:05 pm    Post subject: Re: The '71 Deluxe Reply with quote
Took the time to sandblast the front emblem and grille (both were painted with a brush at some point), will spray paint with Rustoleum heritage white when the weather warms up a bit.
Also ordered a bunch of new parts (ignition switch, retracting seatbelts, gates fuel hoses, ebrake handle, etc). Currently putting together a new fuse panel to replace the faulty melted one in the bus, also on the search for some new tires (so expensive!!)
dumptuck
dumptuck is offline
PostPosted: Sat Jan 06, 2018 6:12 pm    Post subject: Re: The '71 Deluxe Reply with quote
Here are some photos of the fuse panel we put together, seems like it should work pretty well. It will be mounted to this panel that we pulled out of our Mazda truck, directly behind the steering column:
Currently just waiting for the paint to dry Very Happy
dumptuck
dumptuck is offline
PostPosted: Sat Jan 06, 2018 10:34 pm    Post subject: Re: The '71 Deluxe Reply with quote
Anyone know what might cause a sloppy shifter? Mine feels like I’m moving a chopstick around in a a square-ish bowl full of milk and mushy cereal. Really kinda hard to find gears Laughing
aeromech
aeromech is offline
PostPosted: Sat Jan 06, 2018 11:25 pm    Post subject: Re: The '71 Deluxe Reply with quote
Sure do. Start with the easy stuff before doing the hard stuff.
1) check the condition of the shift coupled
2) Check the condition of the forward shift rod bushing
3) remove the tear shifter. Clean, inspect, and lubricate. Then adjust.
4) Check the condition of the nose cone bushing and hockey stick
5) consider dropping the tranny and going inside the nose cone to inspect the ball and the bracket for damage.
6) pull out the complete shift rod and rebuild it using new birdies. Clean and lube.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
dumptuck
dumptuck is offline
PostPosted: Sun Jan 07, 2018 4:29 pm    Post subject: Re: The '71 Deluxe Reply with quote
Sounds good, thanks. I’ll look into that once we get it driving I suppose Smile
GeraldineTheGreenMachine
GeraldineTheGreenMachine is offline
PostPosted: Mon Jan 08, 2018 7:14 pm    Post subject: Re: The '71 Deluxe Reply with quote
Is there a better way to adjust the alignment? First and second are centered instead of being to the left and third and fourth are in their normal-ish spot.
dumptuck
dumptuck is offline
PostPosted: Fri Feb 23, 2018 6:12 pm    Post subject: Re: The '71 Deluxe Reply with quote
Have been getting quite a bit of snow lately...
dumptuck
dumptuck is offline
PostPosted: Sun Feb 25, 2018 6:05 pm    Post subject: Re: The '71 Deluxe Reply with quote
Began refreshing the curtain situation today...
Here's the old curtains, not so bad huh?
Nevermind Shocked
Here's the new yellow plaid fabric, will post a pictures when they are finished in the next few days!
dumptuck
dumptuck is offline
PostPosted: Mon Mar 19, 2018 6:52 pm    Post subject: Re: The '71 Deluxe Reply with quote
Crossed the border the other day to pick up some cheap jalousies in nice shape! I know their disadvantages and how many people don’t like them, but I just can’t help but love their classic look, especially on an early bay Very Happy All they need is some new rivets and a good shine.
Also painted the grille & emblem Rustoleum Heritage White, unfortunately it’s just a touch more beige but it’s not too noticeable in real life. I’ll probably paint the grille niagra blue again in the future if I can find a good match, however it will do just fine for now.
Got the bus running again on the weekend too, runs like a dream everything works perfectly (except the lowbeams Think ) Just need to figure out how to mount the flashers under the dash and install my new Gates fuel lines, and I should be ready to go campin’ Very Happy Very Happy Very Happy
dumptuck
dumptuck is offline
PostPosted: Tue Mar 27, 2018 10:57 am    Post subject: Re: The '71 Deluxe Reply with quote
Here is the roofrack I’ve been working on recently, just finished the welding & put on a primer coat! Very sturdy Smile Smile
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Tue Mar 27, 2018 11:01 am    Post subject: Re: The '71 Deluxe Reply with quote
Looks good man! I have to assume that's not your home shop, that's a ton of metal on the rack on the wall!! Laughing
Robert in Memphis
Engine rebuild thread
dumptuck
dumptuck is offline
PostPosted: Tue Mar 27, 2018 11:05 am    Post subject: Re: The '71 Deluxe Reply with quote
Hahah I wish, I’m actually volonteering at a fabrication/welding shop for a highschool program and this is what I’ve been building in my free time Very Happy
Page 1 of 8
