dennis 356 Samba Member
Joined: January 09, 2009 Posts: 100 Location: Malmö, Sweden
Posted: Sat Jan 06, 2018 7:21 am Post subject: Crank gear puller recommendations? |
I´m planning to get this VW gear puller of off Ebay but am not sure if it´ll fit an A and B 356 crank as the seller states it´ll only fit VW T1 crank, not i.e. VW T3 and as I´ve no clue whether a VW T1 crank might in this respect be compatible to an A or B 356 crank, I´m in doubt. Seller didn´t know either.
I´m neither certain on whether it is so wise using standard two or three leg pullers without danger for cracking or otherwise damaging the inner gear, never done that before.
Can anyone confirm?
Dennis
https://www.ebay.com/itm/Crank-Gear-Puller-for-Air...XQHU1RqN71
alanhall Samba Member
Joined: February 18, 2006 Posts: 115 Location: Northern California
Posted: Mon Jan 08, 2018 9:13 am Post subject: Re: Crank gear puller recommendations? |
I believe that will work fine, but you can verify when you get it. 356 gears are the same as 36hp VW. You need a puller that will support the gear around most of it's circumference, so do NOT use a 2 or 3 leg type jaw puller. I have also used an adjustable bearing puller with a shop press. |
Posted: Mon Jan 08, 2018 9:18 am Post subject: Re: Crank gear puller recommendations? |
alanhall wrote: |
Hi Alan,
Thanks for the input but as I´m based in Europe and with the expensive transatlantic shipping fees, plus as expensive local duties, it´ll be too late to verify the puller doesn´t fit, that´s why I´m trying to find out before placing the order.
Dennis |
Starbucket Samba Member
Posted: Mon Jan 08, 2018 9:21 am Post subject: Re: Crank gear puller recommendations? |
Measure the OD of your gear and have the seller measure the area that needs to fit over the gear, if they are real close then it will work. |
Posted: Mon Jan 08, 2018 9:29 am Post subject: Re: Crank gear puller recommendations? |
Starbucket wrote: |
Great idea thanks, will do..... |
Posted: Mon Jan 08, 2018 1:24 pm Post subject: Re: Crank gear puller recommendations? |
If you buy it, have the seller use a "flat rate" box from USPS as its the cheapest way to ship international because the weight doesn't matter (up to the limit of each size box) around $30.00 with insurance and tracking. |
Posted: Mon Jan 08, 2018 3:13 pm Post subject: Re: Crank gear puller recommendations? |
Starbucket wrote: |
Thanks for the tip Starbucket.... |
Posted: Mon Jan 08, 2018 3:29 pm Post subject: Re: Crank gear puller recommendations? |
One more thing, why do you need a puller, just remove the lock ring before each gear and they should just tap off with a brass drift and small ball peen hammer. They might need a little heat from a propane torch but it's the woodruff key and lock ring that hold them in. |
Posted: Mon Jan 08, 2018 3:36 pm Post subject: Re: Crank gear puller recommendations? |
Starbucket wrote: |
Well, its my first job doing this and without knowing how things sit and work, I thought the best is doing it by the book, not messing things up. I guess i´ll have more use for that puller as I´ve two more motors/cranks to do. |
Posted: Tue Jan 23, 2018 4:10 am Post subject: Re: Crank gear puller recommendations? |
Guys,
I now received the VW gear puller in the pic above and for those who might be in doubt, it fits like a glove on the 356 crancshafts.
Dennis |
