Tcash Samba Member
Joined: July 20, 2011 Posts: 12843 Location: San Jose, California, USA
Posted: Tue Mar 17, 2015 12:21 pm Post subject: Air non return,Flap,Flaps,Fan Shroud,Heater,021119263A,264A |
To link to this post copy and paste
| Code: |
| [url=https://www.thesamba.com/vw/forum/viewtopic.php?t=621995&start=0&postdays=0&postorder=asc&highlight=]Air non return,Flap,Flaps,Fan Shroud,Heater,021119263A,264A[/url] |
72-79 Air Non Return Flaps:
021 119 263 A Left
021 119 264 A Right
Thanks to Karl (rip)
Small=Right side Big=Left side
Thanks to jerseylooker
#41 & #42
Thanks to Mayor Ratwell
2. Control Flaps (blue):
72-79 Bus Heating System
German Supply 021 119 263 A Left Flap
German Supply 021 119 264 A Right Flap
Bleyseng Samba Member
Posted: Tue Mar 17, 2015 6:54 pm Post subject: |
Yes, they had a little bit of foam around the edge too when new. For the pins I use a finish nail cut to the right length to slide in and hold the flaps. The cover holds the pins in. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Tcash Samba Member
Tcash Samba Member
Tcash Samba Member
Tcash Samba Member
Posted: Fri Nov 27, 2015 12:07 pm Post subject: Non-Return Air Flap (L) 021119263A (R) 021119264A Pins 02111 |
mountain bug wrote:
NOS Non-Return Air Flaps. Dealer purchased in the 80s, on the shelf since.
L Air Flap 021 119 263 A
R Air Flap 021 119 264 A
Flap Pins 021 119 270
VW Parts Book adds: "Shorten to 56mm for left flap".
They had small foam seals glued onto them. Over the 30 or so years on the shelf, they have dissolved and disintegrated so all that's left is the glue. See Photos. The Foam kept them from rattling more than for sealing.
Edited for content.
Tcash |
surfbus23 Samba Member
Posted: Sun Oct 08, 2017 10:29 pm Post subject: Re: Air non return,Flap,Flaps,Fan Shroud,Heater,021119263A,264A |
I'm installing a pair of these non-return flaps and am going to glue a small foam and wondering what temperature range these pieces should expect?
Thanks! |
Posted: Sun Oct 08, 2017 11:20 pm Post subject: Re: Air non return,Flap,Flaps,Fan Shroud,Heater,021119263A,264A |
| surfbus23 wrote: |
Thanks! |
The fan shroud will be hottest after shutdown, so maybe 250+°F on a not day. I just use copper silicone to seal the heat exchangers to the fan shroud and to seal the little covers, applying a bead to the sealing surface and then letting it skin over well, but not completely cure before assembling the parts. This makes for a custom fit which adapts for the parts being bend out of shape over the years. The flaps themselves don't need to seal very well as they will be open whenever the engine is running. |
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Sat Feb 03, 2018 3:19 pm Post subject: Re: Air non return,Flap,Flaps,Fan Shroud,Heater,021119263A,264A |
Any suggestions on source for suitable foam? What are people using? Thanks in advance! _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
rastomas Samba Member
Joined: April 05, 2007 Posts: 258 Location: rosendale, ny
Posted: Sat Feb 03, 2018 3:35 pm Post subject: Re: Air non return,Flap,Flaps,Fan Shroud,Heater,021119263A,264A |
As Tcash said, they're really for anti-rattle. Cork, rubber, etc will work, but foam ain't gonna last. _________________ "It's not 'You are what you eat', it's 'You are what you don't SHIT". Wavy Gravy.
'74 Westy |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23338 Location: Oklahoma City
Posted: Sat Feb 03, 2018 4:00 pm Post subject: Re: Air non return,Flap,Flaps,Fan Shroud,Heater,021119263A,264A |
| BUSBOSS wrote: |
| Any suggestions on source for suitable foam? What are people using? Thanks in advance! |
I would not use foam again. As Wildthings noted .....use a thin even layer of high temp RTV. It really is only for anti-rattle and abrasion. Its what I have been using for decades.
The problem with foam is,that it needs to be super soft, thin and light. The foam they used from memory...and its been 30 years since I have seen any.....appeared to be that light crispy ,polyethylene foam.
The closest and softest that has reasonable temp rating is EDPM foam. Great for water.....super soft.....good to 200°....but not great for oil.
The original foam was good with water and oil...but bad with heat. Turned to dust pretty quick.
You only need maybe 1/32" flat bead of RTV. Ray |
lawryrg Samba Member
Joined: October 17, 2020 Posts: 115 Location: Pensacola FL
Posted: Tue Nov 15, 2022 12:30 pm Post subject: Re: Air non return,Flap,Flaps,Fan Shroud,Heater,021119263A,264A |
Greetings,
I am working to determined what happened too overheat my type 4 and it appears that these flaps may be a root cause.
IF these air non-return flaps get stuck closed, it results in cooling air being blocked from the heat exchanger and thus overheating exhaust manifold.
Thoughts? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53117 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Nov 15, 2022 12:47 pm Post subject: Re: Air non return,Flap,Flaps,Fan Shroud,Heater,021119263A,264A |
It's possible, but it would have to seal up real good, how did it get stuck?
But a cooked heat exchanger isn't going to do much of anything towards making the engine hot, it's downstream of all the cooling air. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Nov 15, 2022 1:41 pm Post subject: Re: Air non return,Flap,Flaps,Fan Shroud,Heater,021119263A,264A |
| They will certain break off and cut down on the air flow through the heaters lessening the heat to the cab. |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42882 Location: at the beach
Posted: Tue Nov 15, 2022 2:10 pm Post subject: Re: Air non return,Flap,Flaps,Fan Shroud,Heater,021119263A,264A |
the flaps prevent the overhead fan from pushing air backwards. When I assemble an engine, I use a small video camera ($16, link below) and a hair dryer to verify that both flaps are operational. They can bind.
https://www.amazon.com/gp/product/B07PBF6DX5/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 _________________ George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
NASkeet Samba Member
Joined: April 29, 2006 Posts: 3235 Location: South Benfleet, Essex, UK
Posted: Wed Nov 16, 2022 12:51 pm Post subject: Re: Air non return,Flap,Flaps,Fan Shroud,Heater,021119263A,264A |
All of the VW Type 4 style engines that I worked on for myself and a few acquaintances, were missing all of the flaps & covers, as well as the left-hand exhaust heat-exchanger & silencer (i.e. muffler in USA parlance!) support bracket, which reputedly fastens onto the engine cooling-fan shroud.
I managed to acquire a set of flaps & covers, but I have yet to see an exhaust support bracket in the "flesh". If I had a paper pattern, I could make one of these brackets out of stainless-steel.  _________________ Regards.
Nigel A. Skeet
https://vwt2oc.co.uk |
SGKent  Samba Member
Posted: Wed Nov 16, 2022 12:55 pm Post subject: Re: Air non return,Flap,Flaps,Fan Shroud,Heater,021119263A,264A |
This is 1975-1978. There are different ones for different heat exchanger configurations 021 256 303 B is the 1975-78 part number. It may also work on the earlier heat exchangers, I don't know. You can google the part number. I think Scott may have made some reproductions at one time. Ken Madsen at TheBusco may have a used one.
You wrote in 2007
| NASkeet wrote: |
| phip wrote: |
I know about 021 256 303B, for the left side. Is there a support on the right side? Is it the same part or a different one? Does anyone have the part number?
Since German Supply is out of stock, does anyone know of another source for this part(s)? I'll post a classified before too long, but if anyone has some, do PM me! |
I have yet to come across any VW Type 4 style engine, with the aforementioned left-hand side bracket (VW part No. 021 256 303B) fitted! |
Posted: Wed Nov 16, 2022 1:19 pm Post subject: Re: Air non return,Flap,Flaps,Fan Shroud,Heater,021119263A,264A |
If you rev the engine even the tiniest bit at idle you can feel the air flow through the heaters pick up, so even at idle the pressures are about the same on both sides of the flaps, and by the time you rev the engine to around 1500 rpms the cooling fan is putting out more pressure than the booster fan and the flaps at the booster are forced shut. My personally experience is that if you weld patches over the holes in the top of the heat exchanger where the vertical pipes from the booster hook up, by eliminating the many potential leaks you will have about the same airflow through the heat exchangers at idle as you have with the booster working 100% correctly, and above idle even more air flow. |
dodger tom  Samba Member
Joined: March 25, 2013 Posts: 2046 Location: Central Coast, CA, but we're all still Ukrainian and Californian
Posted: Wed Nov 16, 2022 1:55 pm Post subject: Re: Air non return,Flap,Flaps,Fan Shroud,Heater,021119263A,264A |
| SGKent wrote: |
years ago my first vw mechanics (john and peter at overdrive in northridge) told me to wrap a coupla large hose clamps around the muffler and j pipe to more fully support the muffler and tail-pipe assembly. so, today there are three stainless steel clamps doing just that.
ever since my first engine r&r the support bracket has been missing (thanks, joe's buggy haus). both avery's and busco had them (thanks, steve), so my engine will also upon the next r&r. _________________ 1978 Champaign Edition 2 Westfalia
Would never find the time to keep up another classic air-cooled. |
Posted: Wed Nov 16, 2022 2:13 pm Post subject: Re: Air non return,Flap,Flaps,Fan Shroud,Heater,021119263A,264A |
In Great Britain, the 1972~78 VW 17/18/2000 Type 2 exhaust heat-exchangers & silencers are all the same.
In Great Britain, the 1979 VW 2000 Type 2 exhaust heat-exchangers, which have the same exhaust-port connections as the 1980~83 VW 2000 Transporter T3 (i.e. Vanagon in USA parlance!), looks very similar. _________________ Regards.
Nigel A. Skeet
