Burlyhammer Samba Member
Joined: March 07, 2002 Posts: 1693 Location: Great north woods Maine
Posted: Thu Mar 01, 2018 7:21 am Post subject: Re: First aircooled 65 single cab |
I guess this means that you’re not going to replace that whole window frame section. Good deal. I didn’t think it looked that bad. Looking good! |
ryans65 Samba Member
Joined: February 16, 2016 Posts: 1264 Location: Yulee FL
Posted: Thu Mar 01, 2018 7:28 am Post subject: Re: First aircooled 65 single cab |
lol yes. maybe. depends on what mood I'm in when I get to the shop this weekend
Burlyhammer wrote: |
Posted: Thu Mar 01, 2018 7:36 am Post subject: Re: First aircooled 65 single cab |
just a tip here also for anyone doing the nose/ lower frame:
The Klassic fab nose panel wiper holes DO NOT line up with the factory windshield frame. If you line up the wiper holes the panel is off left to right and it sits way too low leaving a (relatively) large gap at the lap joint. There is a 90 degree bend at the top of the nose panel that is supposed to interface with the frame but I found that when I pushed the nose panel up to where both 90 degree angles meet the holes are way off. I suppose pretty much everyone uses the lower frame when doing a nose but if you plan on saving your frames and tucking the nose panel there are some differences between the two. Kurts video also points these differences out as well as the very ends of the lower frame where you hammer the flange. The KF frame seems to come up short there even with the KF nose. I think there are just too many angles at play there for it to fit right out of the box. |
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Thu Mar 01, 2018 7:53 am Post subject: Re: First aircooled 65 single cab |
Ryan getting down! _________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
Posted: Thu Mar 01, 2018 9:05 am Post subject: Re: First aircooled 65 single cab |
Killing myself doing it too!
Here's my schedule yesterday:
Wake at 4:30am
Drive 1 hour to work
Work 7-5:30
Drive 1 hour to house to feed/ let out dog
Load dog in car
Drive 1 hour to shop
Work on bus 8-10:30
Drive 1 hour home
Unload dog
Go to sleep at midnight
Lol
Skim wrote: |
Ryan getting down! |
Posted: Thu Mar 01, 2018 9:07 am Post subject: Re: First aircooled 65 single cab |
ryans65 wrote: |
Wake at 4:30am
Work 7-5:30
Load dog in car
Work on bus 8-10:30
Drive 1 hour home
Unload dog
Lol
Skim wrote: |
You can rest later. Haha
It is definitely hard to make time for everything. Do what you can do. |
Posted: Thu Mar 01, 2018 9:17 am Post subject: Re: First aircooled 65 single cab |
Haha, exactly! I spent too much time resting the first six months of the project that's for sure. Had to get off my ass and make some progress.
Posted: Thu Mar 01, 2018 9:21 am Post subject: Re: First aircooled 65 single cab |
ryans65 wrote: |
I just wish I could go “Skim speed!” |
Posted: Thu Mar 01, 2018 10:54 am Post subject: Re: First aircooled 65 single cab |
No doubt! I'm convinced there is a time machine somewhere down in TX.
ryans65 wrote: |
Posted: Sat Mar 03, 2018 6:51 pm Post subject: Re: First aircooled 65 single cab |
Picked up two push button doors, the drivers door should give me a nice section to repair the lower hinge on my original door.
Posted: Fri Mar 16, 2018 5:51 am Post subject: Re: First aircooled 65 single cab |
Three or four projects all going on simultaneously
Had some time to work on the long rocker last night, I had a small "upheaval" after welding. Frustrated, I grabbed my metal hammer and set about making small taps right on the ridge area and to my surprise it actually smoothed the area out considerably. I think it's at a point now where I am satisfied and I can stop thinking about cutting the entire side out and replacing it
Posted: Fri Mar 16, 2018 8:13 am Post subject: Re: First aircooled 65 single cab |
ryans65 wrote: |
I’m glad to hear the hammering worked. I may have to try that as well. That panel looks good! |
Posted: Fri Mar 16, 2018 8:45 am Post subject: Re: First aircooled 65 single cab |
It actually surprised me! There is some filler work that will need to be done but that long side was such a mess to begin with I can't ask for much more. I have not plug welded the braces behind the panel so maybe since it had some "bounce" to it when I was hitting it it was able to absorb the blows and not dent inwards.
ryans65 wrote: |
Posted: Sat Mar 17, 2018 6:06 pm Post subject: Re: First aircooled 65 single cab |
Hammered my lower nose lip today and finished welding it
Posted: Sun Mar 18, 2018 11:25 am Post subject: Re: First aircooled 65 single cab |
Birthday loot
Posted: Sat Mar 31, 2018 7:17 pm Post subject: Re: First aircooled 65 single cab |
Had to cut out the lower hinge and replace with a donor hinge section. No pics of that as it was tedious and horrible. Door fit is decent now. Passenger needs hardly any work so doors will be done soon. Looks strange with a door on!
Posted: Sun Apr 01, 2018 6:32 am Post subject: Re: First aircooled 65 single cab |
Wow. Everything is lining up nicely. The door hinge repair is not fun. I put mine off for a long time. Looks like you nailed it! |
Posted: Sun Apr 01, 2018 5:21 pm Post subject: Re: First aircooled 65 single cab |
It was such a pain hanging the door about 30 times by myself but in at a point where I am satisfied now. Shuts with a "click"!
Touch Nicks Thing Samba Member
Joined: May 21, 2003 Posts: 2030 Location: Alexandria, VA
Posted: Mon Apr 02, 2018 3:44 pm Post subject: Re: First aircooled 65 single cab |
You running a new wiring harness or is the original pretty nice? |
Posted: Mon Apr 02, 2018 6:32 pm Post subject: Re: First aircooled 65 single cab |
I ran a brand new one last summer before I really just went all in on this thing. I got a little ahead of myself installing that lol
Touch Nicks Thing wrote: |
