fccperdiem Samba Member
Joined: August 16, 2005 Posts: 107 Location: Ellsworth, Maine
Posted: Mon Mar 05, 2018 5:07 pm Post subject: Thing Hood Rack Ideas... |
I knocked this rough draft together as a concept for a customer. I've fixed the bar alignment (after taking these pics), so everything is now symmetrical. What do you guys think?
_________________ Eric
Beard Fire Metalworks
Ellsworth, ME
207-242-0016
www.beardfiremetalworks.com |
Joe 20 Samba Member
Posted: Mon Mar 05, 2018 8:42 pm Post subject: Re: Thing Hood Rack Ideas... |
It looks nice. My concern though is anything stored/carried on it would block your view...sort of like the people who mount a tire on the hood. Our hoods don't slope enough to emulate the Type 82. I did see one of the Domeck bros. had a hood with a tire that fit down in it. Along those lines, could you drop the front and rear support bars lower so the slats came nearer to the hood? Just a thought. |
HMVWNAB Samba Member
Joined: September 23, 2006 Posts: 1190 Location: Sunshine State
Posted: Tue Mar 06, 2018 7:13 am Post subject: Re: Thing Hood Rack Ideas... |
Love the look, wonder about the functionality.
Leery of cargo heading towards windshield as well as the vision issue mentioned earlier.
Bet it would be loud in the wind. |
Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2519 Location: . . . in denial.
Posted: Tue Mar 06, 2018 2:07 pm Post subject: Re: Thing Hood Rack Ideas... |
First off, the Thing Shop offers this:
Looking to your design, I like the idea that it is an actual rack that holds luggage off the sheet metal. I would make the standoffs shorter though, so that the rack sat just a 1/4 to 3/8 inch above the sheet metal, to keep everything as low as possible. I would add a rail along the front and sides to keep things from wanting to slide off the front. I would also tighten up the radius of the front corners of the rack if possible. In the event that you might actually want to put a suitcase there, which will likely be rectangular, it will be a more efficient use of the space. |
Posted: Tue Mar 06, 2018 4:57 pm Post subject: Re: Thing Hood Rack Ideas... |
The uprights are 2' on the Beta. I may try to take it down to 1' but it would endanger the paint when installing bungee cords/tie-down implements. I had envisioned a 'spider-bungee net'' covering the load surface with small eyelets for hooks.
I used all steel for this mock-up, but the actual rack will have 2 1/2' oak slats that are recessed into the frame so that the wood surface will be ever so slightly higher than the frame. It will look really clean! I plan to make a run of matching rear racks with wood slats, too. Nothing beats a matching set!
Captain Spalding may be right. I'll reconsider the additional rail.
I had The Thing Shop's hood bar for years, but it was essentially a huge hood ornament. I'm not knocking it... I simply think we can do better. _________________ Eric
Ellsworth, ME
207-242-0016
Posted: Tue Mar 06, 2018 6:31 pm Post subject: Re: Thing Hood Rack Ideas... |
Keep up the good work Eric, i was looking at my rack the other day and considering wood slats going perpendicular. Cliff Waugaman in Pa. |
sharkskinman Lateral Lunatic
Joined: April 26, 2006 Posts: 4045 Location: Deep In My Own Psyche
Posted: Sun Mar 18, 2018 8:09 am Post subject: Re: Thing Hood Rack Ideas... |
I'm going to do one like the last picture but in K Copper Pipe
I have thought about having a bottom to it sitting Just above the hood
And all my feet are going to be using mushroom corks and Probably just Strap it down _________________ 74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
Me of Course wrote: |
Extremity is relative to how far your willing to jump |
Ward Cleaver wrote: |
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards |
PS4 "NKOGNEATO" |
