Yellow & Tan '56 Subhatch Westy - 20-147419
Page: Previous  1, 2, 3 ... , 10, 11, 12  Next
campingbox Premium Member
campingbox is offline
PostPosted: Wed Mar 14, 2018 5:06 pm    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
Time to finish off the reduction boxes.
I had collected a full set of NOS reduction box bearings - FAG - all marked "Germany" on the bearings themselves - not sure it matters in the big picture but whatever.
Bearing puller tool.
Backing plates & axle seals.
I decided to leave the shocks factory paint. These are NOS rears dated 3/62.
I also torqued down the reduction box bolts and the rear cradle bolts.
PostPosted: Wed Mar 14, 2018 5:13 pm    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
On to the brakes - I picked up these "oversized" shoes from the VW parts museum in Germany 2003 and figured it would be nice to use them on this project.
I have never riveted brake shoes on before so if someone notices an issue they think might be unsafe feel free to post it up. The process seems pretty straight forward - the shoes came with the rivets. The rivets are steel but they are easy to install. I modified an old arbor press and a punch die. Seemed to work fine.
They seem to fit the drums well, which were also turned.
I probably should put on a mask and chamfer the ends before I install them.
BarryL Premium Member
BarryL is offline
PostPosted: Wed Mar 14, 2018 6:56 pm    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
Looks totally factory to me even like you arced the shoes to match.
PostPosted: Wed Mar 14, 2018 7:16 pm    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
The workshop manual says to use oversized shoes when you turn it to the first cut. It seems like they line up pretty nicely with the drums.
New German wheel cylinders:
I knocked them apart and cleaned them out and regreased them.
They went back together a little easier than I'm used to, but I've never used that grease before. Hopefully they seal up nice and last a long time.
One side is done.
29 part # lug bolts.
mandraks
mandraks is offline
PostPosted: Wed Mar 14, 2018 7:28 pm    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
If this is what i think it is, ATE blue brake paste, then they should be just fine. The VW guys i trusted 30 years ago swore by it.
regards
Uli
obus Premium Member
obus is offline
PostPosted: Wed Mar 14, 2018 7:44 pm    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
those are like museum pieces! You must be happy that you found a perfect project for them
oakman
oakman is offline
PostPosted: Wed Mar 14, 2018 8:31 pm    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
What a sweet Westy!!! Love the curtain fabric and everything else too! Killer work as always!
Brandon
[email protected]
jmp@ncounty.net is offline
PostPosted: Wed Mar 14, 2018 9:19 pm    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
nice
npbusguy
npbusguy is offline
PostPosted: Thu Mar 15, 2018 12:32 am    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
Looking good Greg, glad to see some progress on this beautiful bus.
perello
perello is offline
PostPosted: Thu Mar 15, 2018 1:23 am    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
As usual in Greg you are doing a fantastic resto!
Just as a side note, the brake pads you are using do have asbestos. In my bus I also wanted to use rivets and was strongly discouraged to do so as highly unsafe.
Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200
Okie Adam
Okie Adam is offline
PostPosted: Thu Mar 15, 2018 6:19 am    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
Are these split case specific lug bolts?
Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia
derRHDmeister
derRHDmeister is offline
PostPosted: Thu Mar 15, 2018 6:21 am    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
#29 signifies barndooor/wolfsburg production line (pre 55)
Ask not what your bus can do for you, but ask what you can do for your bus.
unclespanky wrote:
Piercy could dip those wheel cylinders between his cheek and gums and spit them out rebuilt.
Check us out on Instagram:
@DeafVolks
@BarndoorBuggy
Okie Adam
PostPosted: Thu Mar 15, 2018 6:25 am    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
As soon as I read your response it made perfect sense. I knew I'd heard of 29 part numbers before!
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia
PostPosted: Thu Mar 15, 2018 6:39 am    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
Thanks!
Why did your guy feel riveted brake shoes were unsafe?
I would trust 10 mechanical fasteners over any type of glue any day.
I think the advantage of bonded shoes over riveted shoes is that they are faster to install and you can make use of the entire pad thickness before you experience any metal on metal contact.
I've heard that riveted shoes dissipate heat better, wonder if it's true?
I can't count the number of times I've seen where a bonded shoe has failed when I've needed to pull the drum on a bus which has sat out in the woods for a number of years.
I wonder if the old asbestos linings will stop better than the low carb version you can buy today from various parts suppliers?
PostPosted: Thu Mar 15, 2018 6:46 am    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
I'm not sure how late those lug bolts went. I think they might have been fazed out around the end of '55. I don't think they made it to the end of the Wolfsburg run.
There was a very low km (8000 km's?) neon green singlecab found in Canada a few years back which was dated 1/56 and had a full set of 29 lug bolts. Our 1/56 bus had 10 of them on the front too. I've seen a number of similar date buses with the flat lug bolts with only a vw logo on it. Easy item to change, but an 8000 km singlecab painted lime green with matching lime green lug bolts was enough to convince me.
Okie Adam
PostPosted: Thu Mar 15, 2018 6:57 am    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
I'm going to have to look at the lugs I have stashed for my 55 now. I remember them being flat top but I'm not sure if they have the part number on them.
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia
Clara Premium Member
Clara is offline
PostPosted: Thu Mar 15, 2018 7:59 am    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
The 29 part numbers were used through 1953. I think VW started using the 9 digit part numbers for 1954. There are plenty of bd parts that came new with the 9 digit part numbers, a Jan 55 bus would have the later part numbers on almost everything. But everything (original to the bus) on my June 53 has the early 29 style p/n on it.
The 29 p/n lug nuts were installed on new buses somewhat into 1956. Why for over a year later? Had they ordered a huge pile of lug nuts before changing the system?
Did the lug nut manufacturer just not get the memo?
Who knows, that's how it was. Anyhow, in the spirit of David Mayes, early p/n lugs correct for this bus was used.
IIRC, the Feb '56 high roof Acme panel from Alaska also had 29 part number lug nuts. https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
then I think they later in 1956 went to the 211 ... ... p/n ,
then the flat w/o number,
then the dimpled
Okie Adam
PostPosted: Thu Mar 15, 2018 8:23 am    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
Another great mystery of the VW world and one I will obsess about even though hardly anyone will ever see my lugs! Laughing
I just went and looked at my 55 and it has a mismatch collection of lugs on it now. Everything from 29 lugs, VW stamp only lugs, and dimpled HWE lugs. I can't wait to get home and inspect the set I have set aside.
Sorry for the hijack! Now back to the regularly scheduled yellow and tan beauty!
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia
velvetgreen
velvetgreen is offline
PostPosted: Thu Mar 15, 2018 10:45 am    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
I have a set of those Jurid (cough cough Smile asbestos brakes but have no stell rivets. If you have any spares could you please post up what they look like or some measurements?
Many thanks!
crofty
Judas of the North
crofty is offline
PostPosted: Thu Mar 15, 2018 11:00 am    Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 Reply with quote
I would have used some sweet chrome backing plates but otherwise it looks great, Greg! Wink
Page 11 of 12
