67ctbug Samba Member
Posted: Tue Mar 06, 2018 1:30 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
[quote="turbotype1"]
67ctbug wrote: |
EA812 wrote: |
Hopefully it will be at Terryville, at least. |
Sorry for the thread hi-jack, but is Terryville back on this year? |
Yeah, on Fathers Day.
https://www.thesamba.com/vw/forum/viewtopic.php?t=688677
https://www.thesamba.com/vw/forum/viewtopic.php?t=694931 _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Posted: Thu Mar 08, 2018 9:50 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
Alright, it's done for now until I get more welding gas. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Mon Mar 12, 2018 10:55 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
Alright... so I was googling around and I found a '67 bug body for sale. It's okay, has some parts I need, maybe even more solid than my car. I was thinking to put it on a pan and drive it. Then I thought no because that sounds a bit illegal, but anyway, if I can get this thing cheap, do you guys think I should get it and use it for parts? I feel bad chopping up a bug but.... _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Joined: August 31, 2013 Posts: 12865 Location: North Carolina
Posted: Tue Mar 13, 2018 3:48 am Post subject: Re: Restoring My New (to me) 1967 Bug |
Get it. In most states, the VIN on the pan is the one that’s accepted. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
EA812 Samba Member
Joined: December 07, 2008 Posts: 1223 Location: North central, CT
Posted: Tue Mar 13, 2018 6:19 am Post subject: Re: Restoring My New (to me) 1967 Bug |
67ctbug wrote: |
Alright... so I was googling around and I found a '67 bug body for sale. It's okay, has some parts I need, maybe even more solid than my car. I was thinking to put it on a pan and drive it. Then I thought no because that sounds a bit illegal, but anyway, if I can get this thing cheap, do you guys think I should get it and use it for parts? I feel bad chopping up a bug but.... |
The vin on the body is just held on with pop rivits. People re body these all the Time. _________________ Project 66 Daily Driver http://www.thesamba.com/vw/forum/viewtopic.php?t=538786&highlight=
Herbie build
http://www.thesamba.com/vw/forum/viewtopic.php?t=336044 |
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
Posted: Tue Mar 13, 2018 6:25 am Post subject: Re: Restoring My New (to me) 1967 Bug |
Get that 67 body if it's in good shape and cheap and stick it on the pan from a 70s bug with a good title. the IRS, dual circuit brakes, 1600 DP, etc will make for a good daily driver with the good looks of an early car. You'd register it as if it were a 73 or whatever. Just make sure the donor chassis isn't a Superbeetle. _________________ 1973 Superbeetle: 1st car, owned since age 12. Update thread --> https://www.thesamba.com/vw/forum/viewtopic.php?p=9919140#9919140
1966 Beetle: My new project. (SOLD) Build thread--> https://www.thesamba.com/vw/forum/viewtopic.php?t=678040 |
Posted: Tue Mar 13, 2018 12:07 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
Okay, I’ll look into it. No title here in CT though. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Mon Mar 19, 2018 3:23 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
Almost halfway done removing it...
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Wed Mar 28, 2018 4:41 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
What’s the deal? I’m working on the other rear quarter and I took measurements. I go to fit the panel now cut and it is completely wrong.... why? _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Fri Mar 30, 2018 2:51 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
Here’s my predicament with the cross braces-
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Fri Mar 30, 2018 6:38 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
That’s why I leave them in place & cut the old pan off of them & remove the crappy aftermarket ones from the new pans.
Have you installed any of the other bolts joining the body to the pan?
If not, you might be in for a fight all the way around. You might be able to loosen any bolts that you have secured & get some buddies to lift & jostle the body while you try to align the holes a bit closer. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Fri Mar 30, 2018 6:40 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
Yeah my pans didn't have them. My original ones were messed up bad so I replaced them. I haven't bolted anything yet as I have to replace the channels too. All of the other bolts seem to line up except for these. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Sat Mar 31, 2018 2:22 am Post subject: Re: Restoring My New (to me) 1967 Bug |
Just use a dremmel or a die-grinder with a carbide burr to open up the holes. You might need to make your own washers & then use a socket head bolt (typically Allen or Torx) so you don’t have clearance issues with the tool while installing. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sat Mar 31, 2018 6:09 am Post subject: Re: Restoring My New (to me) 1967 Bug |
TDCTDI wrote: |
Just use a dremmel or a die-grinder with a carbide burr to open up the holes. You might need to make your own washers & then use a socket head bolt (typically Allen or Torx) so you don’t have clearance issues with the tool while installing. |
Alright will do. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Sat Mar 31, 2018 6:45 am Post subject: Re: Restoring My New (to me) 1967 Bug |
Just know that a carbide burr throws metal splinters everywhere & youll drive them through your skin & calloused mitts just by trying to brush the shards off your arm, keep a few magnets around the hole to catch as many as you can. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sat Mar 31, 2018 11:20 am Post subject: Re: Restoring My New (to me) 1967 Bug |
TDCTDI wrote: |
Just know that a carbide burr throws metal splinters everywhere & youll drive them through your skin & calloused mitts just by trying to brush the shards off your arm, keep a few magnets around the hole to catch as many as you can. |
Thanks, I didn't know that... I probably would have hurt myself _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Sat Mar 31, 2018 2:02 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
I’m starting to hate this car again...
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
REDKAFER Samba Member
Posted: Thu Apr 05, 2018 7:41 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
Don't let the frustration get to you. you're doing great. Heater channels are a massively big deal but once you have them fitted tight and welded in, you - and also the car - will feel like a million bucks. after that, it keeps getting better, and by the time you put paint/undercoating on it you'll have a hard time believing you were ever upset because it will look fantastic.
And when you feel the difference new heater channels and fresh heater hoses make in the "cool weather driving comfort" department... man, youll be absolutely floored. (i mean, you live it CT... theres plenty of opportunities for us north-east people to drive in the cold...) |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1293 Location: South West (Pa.)
Posted: Fri Apr 06, 2018 3:18 am Post subject: Re: Restoring My New (to me) 1967 Bug |
Have you tried to fit it without the come along (winch) attached ?
67ctbug wrote: |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22680 Location: NYC/Upstate/ROW
Posted: Fri Apr 06, 2018 3:47 am Post subject: Re: Restoring My New (to me) 1967 Bug |
67ctbug wrote: |
TDCTDI wrote: |
Thanks, I didn't know that... I probably would have hurt myself |
Eye and FACE protection please. _________________ .ssS! |
