Volswagon Samba Member
Joined: December 29, 2009 Posts: 303 Location: Knoxville, TN
Posted: Tue Apr 03, 2018 9:41 pm Post subject: Dressed crank-NOW 1.8L BUILD THREAD |
I'll have to ask the pro's - what should I soak this crank assembly in. The pilot bearing is installed too, with red grease, it's ok.
The crank solid bearings won't budge. They are soaking with oil now. The rod journals are gunked up.
It's been wrapped up ~4 years until today. What will soften dried lithium? _________________ I know the pieces fit, cos I watched them fall away.
Wanna hear God laugh? Just talk about your plans.
'75 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=697183&highlight=
Posted: Tue Apr 03, 2018 10:34 pm Post subject: Re: Dressed crank has dried lithium grease from sitting |
Since like dissolves like, and I have a tub of lithium that's still like new even after 20 years, would dobbing some fresh on it do any good? _________________ I know the pieces fit, cos I watched them fall away.
'75 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=697183&highlight= |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2875 Location: Little Britain
Vanillagurilla Samba Member
Joined: November 21, 2017 Posts: 1061 Location: California
Posted: Wed Apr 04, 2018 1:19 am Post subject: Re: Dressed crank has dried lithium grease from sitting |
| Brake cleaner or you can soak with auto transmission fluid mixed with a little gas to thin it out, old junk yard trick for stuck bolts. |
Posted: Wed Apr 04, 2018 2:14 am Post subject: Re: Dressed crank has dried lithium grease from sitting |
Brake cleaner it is. Thanks gur. I concur.
I left the front wheel off the S10 to finish routing new plugs and wires and catch the outer front brake pads. 182K on a factory plug #1 under the AC compressor, and 3 oddballs, with #4 loose. Throttle body intake boot cracked. First time I've had it apart, 82K of that is mine since the bus died. Got it from my brother with chunky soup for oil.
I miss my Bus - she completes me! _________________ I know the pieces fit, cos I watched them fall away.
Cusser Samba Member
Joined: October 02, 2006 Posts: 33577 Location: Hot Arizona
Posted: Wed Apr 04, 2018 8:32 am Post subject: Re: Dressed crank has dried lithium grease from sitting |
| Vanillagurilla wrote: |
I also think brake cleaner. Guys wash off grease from wheel bearings all the time. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20911 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed Apr 04, 2018 8:45 am Post subject: Re: Dressed crank has dried lithium grease from sitting |
AT fluid and Acetone...
Dale _________________ “Fear The Government That Wants To Take Your Guns"
Posted: Wed Apr 04, 2018 8:47 am Post subject: Re: Dressed crank has dried lithium grease from sitting |
| Cusser wrote: |
I also think brake cleaner. Guys wash off grease from wheel bearings all the time. |
Brake clean, petroleum spirits (paint thinner) and PB Blaster, my three main tools...
Posted: Wed Apr 04, 2018 9:28 am Post subject: Re: Dressed crank has dried lithium grease from sitting |
I'll prolly end up taking the crank apart to clean up the bearings. Breakfree is what I've used in the past just because it was on hand, great gun oil.
Thanks for the responses. _________________ I know the pieces fit, cos I watched them fall away.
Posted: Wed Apr 04, 2018 11:39 am Post subject: Re: Dressed crank has dried lithium grease from sitting |
Breakfree is good too...
Posted: Wed Apr 04, 2018 1:37 pm Post subject: Re: Dressed crank has dried lithium grease from sitting |
Plug wires on S10 4-cyl. are a bitch, even the pro's agree.
I have bearings 1 and 2 turning, 4 is still stuck like glue, still soaking.
But every time I sit on these new seat covers, I know she'll be worth the trouble.
Posted: Wed Apr 18, 2018 5:20 am Post subject: Re: Dressed crank has dried lithium grease from sitting |
I got her turning by hand with case torqued down. Raby 9550 cam kit, bought in '09, included dual thrust bearing and solid spacer rocker arm upgrade.
Len Hoffman 0825 1.8L heads, after he cut the steps in 2010. They have around 15,000 mi. on them and have been waiting on me.
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Wed Apr 18, 2018 8:17 am Post subject: Re: Dressed crank has dried lithium grease from sitting |
Spray oil. Why turn it into a big project. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Posted: Wed Apr 18, 2018 9:41 am Post subject: Re: Dressed crank has dried lithium grease from sitting |
I've turned it into a build thread. Just got the rusty 210mm flywheel shined up at the shop.
It's a minor miracle I still have all this stuff after the last 8 years.
I'm doing this in the basement with "stone knives and bear skins." _________________ I know the pieces fit, cos I watched them fall away.
timvw7476 Samba Member
Posted: Wed Apr 18, 2018 4:58 pm Post subject: Re: Dressed crank-NOW 1.8L BUILD THREAD |
When you own & operate a 43 y/o bus,
you stash your bits & pieces where you can.(like a squirrel with nuts)
Not that I would know, my bus is only 42. |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4368 Location: Los Angeles, CA 90016
Posted: Wed Apr 18, 2018 9:26 pm Post subject: Re: Dressed crank-NOW 1.8L BUILD THREAD |
| What is the 9550 cam? Is that the Camper Special cam? |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23593 Location: Oklahoma City
Posted: Wed Apr 18, 2018 10:21 pm Post subject: Re: Dressed crank-NOW 1.8L BUILD THREAD |
| bugguy1967 wrote: |
No....well it "may" be used as a camper special cam.....I have no idea....I do not work on camper engines .....but its a Raby version of the Web #73 with a couple of extra degrees of exhaust overlap for better head cooling. I have a 9550 kit I bought in ahout 2009 to 2010 right before Jake got out of the store. Its going into my 1.7L 412 engine.
It was superseded by the 9590....which is tuned to work a little better with fuel that has alcohol.....so I was told.
The 9550 is a great cam for certain applications just a bit hotter than stock. Ray |
Posted: Fri Apr 20, 2018 6:11 am Post subject: Re: Dressed crank-NOW 1.8L BUILD THREAD |
Good info Ray, thanks!
I have a broken oil ring on these CIMA pistons. Widths are 2mm top, 1.5mm middle and 3.5mm oils. Am I looking for new pistons? I have a few cracked fins and was apprehensive about that already
I'm checking with Bus Depot, but I'm having land-line issues today and no cell.
Oh, and there's a K6 solar storm today, 4/20, medicate accordingly! _________________ I know the pieces fit, cos I watched them fall away.
Posted: Fri Apr 20, 2018 7:31 am Post subject: Re: Dressed crank-NOW 1.8L BUILD THREAD |
| Volswagon wrote: |
Oh, and there's a K6 solar storm today, 4/20, medicate accordingly! |
Post pictures of where the cracked fins are.
Also....measure the skirts of the pistons. If they are not collapsed and not scored.....and the ring was not broken by a bent or dented ring land......and the ring lands are clean....just get new rings. Ray |
Posted: Fri Apr 20, 2018 8:27 am Post subject: Re: Dressed crank-NOW 1.8L BUILD THREAD |
G'day mate. Fins are next to head. One piece oil ring, broke cable, which scored piston (#2) on the flywheel side. My buddy Ron's Import shows no listing for pistons.
I'd like to score some 90's like yours, thicker walls, but a set of rings will do for now. I doubt Bus Depot has anything but stock size (2, 2, 4) rings. Saw the same dilly with CIMA Bug pistons back in the day Gonna go medicate, Cheers! _________________ I know the pieces fit, cos I watched them fall away.
