Frankenstien Bus - ID Vents...
Cebu
Cebu is offline
PostPosted: Sat Apr 28, 2018 11:01 pm    Post subject: Frankenstien Bus - ID Vents... Reply with quote
Every since I got my panel bus I've tried to figure out what year the rear vents are. The rear end parts have been swapped out during its lifetime.
I can't figure out the 10 Outward vents. My 67' MicroBus has 10 Inward vents but I've never seen 10 out. Is this a transplant part(s) from Brazil or other manufacturing location?
I checked David Eccles "Specification Guide" and Laurence Meredith "Original VW Bus". I looked at every split bus at the recent Kelly Park VW event at San Jose, CA. and didn't see any that had the same 10 vent outward configuration.
The bus has bit and pieces of a 67' which it is registered as. The gas door is has a church key, front blinkers have been shaved. This is not an original bus. LOL!
Any insight would be appreciated.
1967 Microbus, 1967 Panel Bus.
"All I need are big dreams and open highways"
View user's profile Send private message Send e-mail Visit poster's website AIM Address Instagram Classifieds Feedback
EeVeeWee
EeVeeWee is offline
PostPosted: Sun Apr 29, 2018 12:39 am    Post subject: Re: Frankenstien Bus - ID Vents... Reply with quote
Maybe this one is just welded inside out?
Cebu
Cebu is offline
PostPosted: Sun Apr 29, 2018 1:38 am    Post subject: Re: Frankenstien Bus - ID Vents... Reply with quote
YOU'RE RIGHT!!
After reading your response I had to get up from bed and go check. Both vents in place have been welded in. I would have never thought of that!
Based on what you can see of the exterior, what year does my bus closest resemble? The tail lights have the correct hole for the lens. The front blinkers have been shaved, I can see the metal plate that was put in place from the inside.
I was thinking 61'sh. The engine door latch does not match with the receiver. In fact, I bought a tin thinking it was a 67' and it about fell through the open section.
Thank you again for figuring out the vents, I really appreciate it!
ronjonlasvegas
ronjonlasvegas is offline
PostPosted: Sun Apr 29, 2018 6:14 am    Post subject: Re: Frankenstien Bus - ID Vents... Reply with quote
It looks like a 1963 to me as it has the narrow rear hatch + thin lipped dog legs + lipped rear wheel wells. We would need to see more photos of the interior showing the dash and the inside showing the back of the headlight buckets and the front seat and mounts. Does it have an M code plate still on the bulkhead?
chgrec
chgrec is offline
PostPosted: Mon Apr 30, 2018 7:16 am    Post subject: Re: Frankenstien Bus - ID Vents... Reply with quote
My 63 panel has outward vents and they appear to be original and not welded in...
Life's to short to drive a boring car!
Follow my latest project: https://www.thesamba.com/vw/forum/viewtopic.php?t=668542&highlight=
My previous project: http://www.mgexp.com/journal/chgrec/
mandraks
mandraks is offline
PostPosted: Mon Apr 30, 2018 4:46 pm    Post subject: Re: Frankenstien Bus - ID Vents... Reply with quote
how many?
regards
Uli
type2rescuemaine
type2rescuemaine is offline
PostPosted: Mon Apr 30, 2018 5:20 pm    Post subject: Re: Frankenstien Bus - ID Vents... Reply with quote
Correct me if I'm mistaken, but didn't early '63 buses come with outie vents before they converted to the later innie vents?
chgrec
chgrec is offline
PostPosted: Mon Apr 30, 2018 6:08 pm    Post subject: Re: Frankenstien Bus - ID Vents... Reply with quote
mandraks wrote:
how many?
9....
[quote="type2rescuemaine"]
I have no idea....i am pretty new to buses. i just figured I'd add mine since i know its a 63 and has original vents
chris
campingbox Premium Member
campingbox is offline
PostPosted: Mon Apr 30, 2018 7:16 pm    Post subject: Re: Frankenstien Bus - ID Vents... Reply with quote
the vents went from innies to outies partway through the 63 model year, at ~ VIN 1 080 xxx
They went from 9 outies to 10 outies.
EmpiGT
EmpiGT is offline
PostPosted: Mon Apr 30, 2018 8:01 pm    Post subject: Re: Frankenstien Bus - ID Vents... Reply with quote
They went from 9 outies to 10 innies .
fixed it for you.
BarryL Premium Member
BarryL is offline
PostPosted: Tue May 01, 2018 10:20 am    Post subject: Re: Frankenstien Bus - ID Vents... Reply with quote
fixed it for you.
But didn't the fender lip go outie when the vents went innie?
Clara Premium Member
Clara is offline
PostPosted: Tue May 01, 2018 12:12 pm    Post subject: Re: Frankenstien Bus - ID Vents... Reply with quote
BarryL wrote:
fixed it for you.
No.
Those changes were at different times.
The fender lip changed at ~ VIN 971 xxx IIRC. ~90,000 German buses were buildt with those wheel arch lips before the vents changed.
Thanks for the edit, EmpiGT. I made that brainfart when the computer was signed in under Greg's username.
Cebu
Cebu is offline
PostPosted: Tue May 01, 2018 11:00 pm    Post subject: Re: Frankenstien Bus - ID Vents... Reply with quote
Sorry for the delay...
I've included a few photos. I have both plates and the M-Code indicates May 30, 1967 as the build date.
The ignition keyhole has been relocated to the left side dash. There is a toggle switch where it normally goes that I've yet had a chance to trace the wiring. The front seats are from a newer year. It looks to be early 70, like a 71'. The rear view mirror is mounted center on the stem, no offset.
Check out the rear hatch and where it meets the receiver is below. They do not match up. My 67' MicroBus has an L-bracket for latching. The is a totally different configuration, earlier year than 1967. The T handle doesn't looks closes to a 61' and below.
The rear tail light holes are round, my 67' MicroBus tail light cut out is more elongated. I checked if the holes were plated over and then cut out for the round tail lights and they are stock.
I included photos of my 67' MicroBus engine bay for reference.
In general, it looks to me closer to a 61'. I'll take more photos of the requested areas when I get an opportunity.
Thanks again for all the help fellas. Much appreciated!
Clara is offline
PostPosted: Wed May 02, 2018 6:59 am    Post subject: Re: Frankenstien Bus - ID Vents... Reply with quote
Small hatch - up through 63 through VIN 1 144 xxx
flared wheel arch and thin doglegs... model year 63 and later, from VIN 971 xxx
It's a 63, from that pic ^^^^
But.....the dash looks like a 67 with the bigger radio hole.
The speedo pod is rounded... that is 62 and later
The front doors are the push button handle kind with door props. Square holes at top of doors are mid 66 through 67
i think I can see the heater grills under the dash... 4/64-67
I'd say it was part 67 (up front) with the backside of an earlier bus.
Look for where the welding was done.
Taillight holes can be altered, engine lid and apron bolted on.
What is the VIN to the right of the apron?
Cebu
Cebu is offline
PostPosted: Wed May 02, 2018 7:02 pm    Post subject: Re: Frankenstien Bus - ID Vents... Reply with quote
Hi Clara, based on your assessment I officially declare I have 63/67' panel bus! Smile
Thank you for pointing out those details. I've tried reading everything I can find and came up short. I tried reading the VIN before near the battery tray and it's so old, rusty and wrinkled I can't even see any parts of it. I'm good with my Frankenstein bus, I dig it.
If I order a 1963 engine apron do you think my hatch would mate up and latch? I'd be happy with that, I'm not trying to restore to original configuration.
Again, thank you again Clara. I'm learning a lot here.
Clara is offline
PostPosted: Thu May 03, 2018 6:58 am    Post subject: Re: Frankenstien Bus - ID Vents... Reply with quote
It looks like a 65 and earlier decklid, with a crankhole apron that has the latch bit broken off. Getting a 60-65 apron would sort it out.
Someone with an earlier bus would probably want your existing apron and fix it, FWIW. Find a pic of an apron, to see what I mean.
You are also missing some engine tin.
Cebu
Cebu is offline
PostPosted: Thu May 03, 2018 11:04 pm    Post subject: Re: Frankenstien Bus - ID Vents... Reply with quote
Clara, I had to google "FWIW" Smile
It seems all I need to do is weld a new latch piece in and straighten out the bent apron areas. The crank hole threw me off. Until you pointed it out I thought it was part of the mounting mechanism that was not used.
I ordered the missing tin piece then realized I was missing the seal too. That's part is being sent. I'll read the service manual for tin/seal installation.
Thank you again!
