1.8T conversion details?
Page: Previous  1, 2, 3 ... 11, 12, 13
danfromsyr
danfromsyr is offline
PostPosted: Tue May 01, 2018 10:46 am    Post subject: Re: 1.8T conversion details? Reply with quote
hey Robbie, nice going..
one thing to note and you may already be there. but you will WANT a metal heat shield to interrupt the glowing infra red heat from shining on the engine lid..
that turbo and header WILL glow a nice bright red on the hills and interstate runs..
robbiecanter wrote:
Keep it german.. the 1.8ts are great. I just finished my swap in a week and a half and only cost my $1500 including the motor. And, it fits under the engine lid.
Abscate wrote:
robbiecanter
robbiecanter is offline
PostPosted: Tue May 01, 2018 10:56 am    Post subject: Re: 1.8T conversion details? Reply with quote
Good idea! I just got it running 2 weeks ago, but now I'm redoing all the brakes,CVS, hoses etc! So no real miles on it yet but that's a good tip! I don't need any fires!
52' Split
59' lowlight ghia
64' Bug-turbo
68' Notch
84' westfalia 1.8t
91' 2.9 vr6 coupe
Zeitgeist 13
Zeitgeist 13 is offline
Nice! Another 15 degree install under the lid
Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE.
robbiecanter
PostPosted: Tue May 01, 2018 11:03 am    Post subject: Re: 1.8T conversion details? Reply with quote
Thanks man! Here's a few more photos the way I did things. I used a a4 intercooler. I'm still going to either add a scoop to direct air, or bolt on 4 6" fans. Once I get some more miles on it and log IT temps, I'll make my decision.
52' Split
59' lowlight ghia
64' Bug-turbo
68' Notch
84' westfalia 1.8t
91' 2.9 vr6 coupe
robbiecanter
PostPosted: Tue May 01, 2018 11:18 am    Post subject: Re: 1.8T conversion details? Reply with quote
Got it! I can cook and drive!
52' Split
59' lowlight ghia
64' Bug-turbo
68' Notch
84' westfalia 1.8t
91' 2.9 vr6 coupe
danfromsyr
PostPosted: Tue May 01, 2018 11:24 am    Post subject: Re: 1.8T conversion details? Reply with quote
love seeing another AEB DIY 1.8T out there.. it's an underdog in the swap game..
yer also going to want to get that tailpipe to exit out from under the van.. that'll heat up (and fume) the compartment in traffic..
also log your IATs and I don't think (IMHO) that you're going to be happy with an air/air intercooler there.. but that's all personal and subjective what makes one person happy and another not..
but I run an Air/water exchanger. sure more complicated but keeps my IATs very stable and never more than 30* over ambient.
had a friend with air/air and fans would heat soak on longer hills and occasionally go into a limp mode.
Abscate wrote:
robbiecanter
PostPosted: Tue May 01, 2018 11:34 am    Post subject: Re: 1.8T conversion details? Reply with quote
Ya it's really in r&d mode right now. I might end up switching to a PWR water to air like I have in my bug, but time will tell! And, this one was free sooo... haha
52' Split
59' lowlight ghia
64' Bug-turbo
68' Notch
84' westfalia 1.8t
91' 2.9 vr6 coupe
Zeitgeist 13
PostPosted: Tue May 01, 2018 12:22 pm    Post subject: Re: 1.8T conversion details? Reply with quote
Yeah, I hear ya. When I drove the van to a recent gtg, I told everyone it was in Beta-mode. That helps explain away all the dangling wires and instrument pod that's just resting in place
Casey--
'89 Bluestar ALH
NEAT, no ICE.
robbiecanter
PostPosted: Tue May 01, 2018 12:41 pm    Post subject: Re: 1.8T conversion details? Reply with quote
Hahaha exactly. I literally had to replace everything that could/did wear out on this westy. Brakes, brake hoses, coolant/heater hose, slave cylinder, front heater fan, CVS, etc so it's been a long month... but I took your advice and just extended the exhaust tip another foot with some SS I had laying around.
52' Split
59' lowlight ghia
64' Bug-turbo
68' Notch
84' westfalia 1.8t
91' 2.9 vr6 coupe
pechaaa
pechaaa is offline
PostPosted: Tue Sep 01, 2020 10:31 pm    Post subject: Re: 1.8T conversion details? Reply with quote
//You make a good point Mark. That would be a heavy load to run the Coil Packs off the ignition switch, which could shorten the switches life. Here is a diagram showing how I have decided to eventually modify mine by adding one more relay to isolate the Fuel Pump. An alternate method would be to replace the power steering relay with a higher amperage one, and group the three loads on it (MAF, Coils, Injectors). But these 30A relays are only around $6.00 each, so I'll just add one.//
What's the final wiring diagram then?
pechaaa
pechaaa is offline
PostPosted: Tue Sep 08, 2020 10:43 pm    Post subject: Re: 1.8T conversion details? Reply with quote
Boys?
pechaaa
pechaaa is offline
PostPosted: Sun Jan 03, 2021 1:45 am    Post subject: Re: 1.8T conversion details? Reply with quote
Getting there.
Page 13 of 13
