Hikelite Samba Member
Joined: August 31, 2012 Posts: 557 Location: Colville, WA
Posted: Sun Apr 29, 2018 9:45 am Post subject: Re: What did you do for your Bay recently? |
I put this in.
_________________ ~Kevin
My 1968 Campmobile |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20282 Location: Sandpoint, ID
Posted: Sun Apr 29, 2018 10:06 am Post subject: Re: What did you do for your Bay recently? |
^^^ Did you replace the bushing? A tricky job with the engine in place, but it can be done, with patience. _________________ nothing |
Posted: Sun Apr 29, 2018 10:24 am Post subject: Re: What did you do for your Bay recently? |
cdennisg wrote: |
^^^ Did you replace the bushing? A tricky job with the engine in place, but it can be done, with patience. |
No. I struggled for a bit, then came in and looked it up. Then I talked to Adam. I decided I'll swap it out next time the motor comes out, probably next month to replace rusty parcel tray. _________________ ~Kevin
Posted: Sun Apr 29, 2018 11:02 am Post subject: Re: What did you do for your Bay recently? |
Hikelite wrote: |
cdennisg wrote: |
No. I struggled for a bit, then came in and looked it up. Then I talked to Adam. I decided I'll swap it out next time the motor comes out, probably next month to replace rusty parcel tray. |
If you have pending engine R&R plans, that is definitely the better time to do this job. It will take about two minutes, and that includes opening a beer. _________________ nothing |
wcfvw69 Samba Purist
Posted: Sun Apr 29, 2018 11:27 am Post subject: Re: What did you do for your Bay recently? |
Hikelite wrote: |
cdennisg wrote: |
Did ya put any grease on the shaft that slides on the bushing? Always a good idea. _________________ Contact me at [email protected]
The Samba member since 2004.
orangebug60guy Twin #1
Joined: June 28, 2003 Posts: 1516 Location: South Hadley Mass
Posted: Sun Apr 29, 2018 5:16 pm Post subject: Re: What did you do for your Bay recently? |
Replaced front pads and rotors. New rubber and metal lines.
Then put the engine seal in.
Adjusted the timing Best could but still need to sync the carbs.
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Sun Apr 29, 2018 5:24 pm Post subject: Re: What did you do for your Bay recently? |
You are a brave man for posting that pic. _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Sun Apr 29, 2018 6:35 pm Post subject: Re: What did you do for your Bay recently? |
Replaced the rear crankshaft seal (fan end). Lubed and adjusted the shifter, the old grease was officially soap. And I finally got around to installing and tuning my idle valve (my bus is powered by fuel and spark megasquirt). No more starting with low rpm and then having high rpm when it's hot, now it's the opposite. _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's) |
xyzzy Samba Member
Joined: March 24, 2014 Posts: 229 Location: Encinitas, CA
Posted: Sun Apr 29, 2018 6:41 pm Post subject: Re: What did you do for your Bay recently? |
Finally got a replacement NOS Escutcheon plastic spacer for the sliding door handle since the original one was cracked and constantly annoying me! Getting that handle out was a son-of-a...
_________________ -----
1973 VW Westfalia 2L hydraulic, dual Solex PDSIT
1987 VW Vanagon Westfalia |
Posted: Sun Apr 29, 2018 7:26 pm Post subject: Re: What did you do for your Bay recently? |
KentPS wrote: |
You are a brave man for posting that pic. |
That's called FREESTYLE! _________________ nothing |
Posted: Mon Apr 30, 2018 7:02 am Post subject: Re: What did you do for your Bay recently? |
cdennisg wrote: |
KentPS wrote: |
That's called FREESTYLE! |
I can't tell from the pic...
... Is that drivetrain blown? _________________ -Kent-
---williamM |
mike77777 Samba Member
Joined: May 13, 2009 Posts: 119 Location: portland or
Posted: Wed May 02, 2018 6:44 pm Post subject: Re: What did you do for your Bay recently? |
_________________ patience and putty |
BackwardsInHeels Samba Member
Joined: April 23, 2017 Posts: 3 Location: Portland, Oregon
Posted: Thu May 03, 2018 9:39 pm Post subject: Re: What did you do for your Bay recently? |
Replaced the sliding door seal yesterday (the 4th of the 4 doors) and got the passenger seat put back together and prepped for reupholstry today.
I'm looking forward to the NW Bug Run and hoping I get all of the projects done in time. _________________ Life is a journey, not a guided tour.
1974 Sportsmobile camper conversion |
Fozzy Samba Member
Joined: August 22, 2012 Posts: 209 Location: United States
Posted: Sat May 05, 2018 7:53 pm Post subject: Re: What did you do for your Bay recently? |
Today was the day I really got some work done.. Yesterday I bought some new OLD bus front seats and stripped them to the frames.. I took the driver's seat back to the salvage yard today and asked to exchange it for another. After pulling the upholstery off I found that it had rot in the tubes and at least two broken springs. Wandered around the place, found a few driver's seats in buses but they just would not budge/slide forward .. Then I found one with all of the front windows still intact and its seat came out great. I stripped it today and it was really nice and dry. I got to pull the horrid aftermarket/other car seats out and toss them in the driveway. The front of the bus has some rust issues.. but not horrible. I will replace the floor, but the rust in the seat pillars is just going to have to stay for now. Cleaned the pedestals out and off, sprayed all the rusty areas with some rust converter, it took most of the day. My buddy was under the bus removing the stupid plastic air horns and we ran the new vacuum line to the booster to the engine. It seemed to give me a lot of pedal, but I was driving it around the block with a 2 X 6 as a driver's seat. Looking forward to next weekend when I get to cuss like a sailor trying to reupholster the seats. TMI covers and seat foam is on the way. _________________ 65 Sedan..
Adopted 07/15/17
this is the bug I've been looking for..
71 Tin Top Westy
Adopted Dec or so 2017 |
xyzzy Samba Member
Posted: Mon May 14, 2018 5:00 pm Post subject: Re: What did you do for your Bay recently? |
Replaced my Antenna. Which, instead of a 10 minute job, was a huge pain in the ass having to remove the under-dash AC unit. Used the wolfsburg west one, seems like good quality. Radio works anyhow. _________________ -----
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
camit34 Samba Member
Joined: January 14, 2006 Posts: 1567 Location: Commerce City CO
Posted: Wed May 16, 2018 6:51 am Post subject: Re: What did you do for your Bay recently? |
Rolled the ODO over for the 2nd time...
I purchased the Bus from my aunt and uncle who bought it new and all indications are it has 162k on it when I bought it as my uncle had the engine rebuilt (I have the paperwork) in 1984 @ 126k miles and parked it 2 years later. So from the info I have this should be it's 2nd rollover.
_________________ In search of a Vanagon
1971 Westy (SOLD)
1971 Deluxe (SOLD)
1967 Freedom Camper (SOLD) |
Posted: Wed May 16, 2018 7:21 pm Post subject: Re: What did you do for your Bay recently? |
camit34 wrote: |
Awesome sauce! _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
Tcash Samba Member
Posted: Wed May 16, 2018 8:33 pm Post subject: Re: What did you do for your Bay recently? |
Time sell that rare 00000 mile bus.
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Thu May 17, 2018 1:40 pm Post subject: Re: What did you do for your Bay recently? |
Yesterday, I removed three windshields. They all need replacing, and I figured, why not get the glass guys to install 3 at once! It's a job I have done many times before, but I will be glad to have someone else do these 3.
These are for the 1972 Sportsmobile, 1973 9-seat Wild Westerner (both of which are already sold, so I am being a nice guy), and the 1975 single cab.
Last evening, I cleaned them up and treated them all with Ospho. Aside from two pin holes in the single cab, everything looked pretty good! I was definitely nervous about having them all out at the same time, but was pleasantly surprised.
This morning, I painted the window sills (3 different colors, of course).
Tomorrow, Speedy Glass comes to install new glass!
EDIT:
All windshields in, and they look great. The installer even put in the plastic silver deluxe trim on the Wild Westerner. Yay! _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
