otiswesty Samba Member
Joined: November 21, 2006 Posts: 1768 Location: Portland
Posted: Wed Jun 06, 2018 9:36 pm Post subject: Re: installing Recaro seats |
Just picked up a set like Little Hobbit Bastard for my 89 camper. These are the powered version from a similar year GTI. I plan to use the Gowesty brackets to get them mounted and eventually add T3 arm rests and recover with rear bench fabric and OG style grey vinyl.
I will probably reduce the size of the bottom seat bolsters a bit too. They seem a little high to climb in and over constantly.
_________________ 1978 Sage Green P22 Westfalia
1988 T3 Syncro Single cab
Just a regular guy |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4252 Location: Redwood City, California
Posted: Wed Jun 06, 2018 10:21 pm Post subject: Re: installing Recaro seats |
What a great idea to cover them in OE bed material fabric and add factory armrests.
I wish I had thought of that !
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
jimf909 Samba Member
Posted: Wed Jun 06, 2018 10:22 pm Post subject: Re: installing Recaro seats |
GTI seats were graciously sent from the gods to comfort our underserving backsides. Enjoy! _________________ - Jim
Butcher wrote: |
This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Wed Jun 06, 2018 11:37 pm Post subject: Re: installing Recaro seats |
otiswesty wrote: |
I will probably reduce the size of the bottom seat bolsters a bit too. They seem a little high to climb in and over constantly. |
Nice! They look clean.
You can probably sell the power bases and covers and get a bit of money back.
The bolsters aren't really that high. I read about this, but it's pretty much a non issue. I'd run em as-is and see how they work for you.
Armrests will take some work though... From what I've read you'll need to remove the armrest mounts from stock vanagon seats (you'll need the metal standoffs that are welded to the backrest AND the shaft brackets that are bolted on). Those standoffs need to be bolted / welded onto the new LS recaro backrests.
Or you might be able to do something like this:
https://www.youtube.com/watch?v=HBg7_iKyoRM
I've been in the middle of this project for a while now and pretty much hit a wall when it came to fitting armrests. The upper bolsters on the LS recaros are a lot thicker than the stock seats but the armrests might just barely work. I've never actually seen LS recaros with armrests and think it's a tight fit for the doors to still close when mounted in a vanagon.
These look like LX recaros with vanagon adjustable armrests. Not LS recaros from the GTI/GLI, but same idea. (not my pic)
Good luck! Has me looking at lumbar and heating elements so I can pick this project back up. |
Posted: Thu Jun 07, 2018 10:27 pm Post subject: Re: installing Recaro seats |
Hey Erste,
Those head rest inserts are kind of funny, are they stock? _________________ 1978 Sage Green P22 Westfalia
Posted: Thu Jun 07, 2018 10:43 pm Post subject: Re: installing Recaro seats |
16CVs wrote: |
Stacy |
If only some one who has done this would post up some pictures and advice... _________________ 1978 Sage Green P22 Westfalia
16CVs Samba Member
Posted: Fri Jun 15, 2018 7:37 pm Post subject: Re: installing Recaro seats |
Eric
Those are the factory Vanagon headrests with the Acc VW pillows on my recovered Recaros in Multivan.
RoryGirl Samba Member
Joined: October 14, 2016 Posts: 1000 Location: WestWorld Nanaimo BC
Posted: Fri Jun 15, 2018 8:19 pm Post subject: Re: installing Recaro seats |
16CVs wrote: |
Eric
Stacy |
Are the headrests a direct swap? _________________ 1991 Twin Slider VR6
1985 Audi 4k |
pdxleaf Samba Member
Joined: January 14, 2014 Posts: 43 Location: Portland, Oregon
Posted: Sat Mar 16, 2019 9:18 am Post subject: Re: installing Recaro seats |
removed my aging SE Recaro seats and replaced them with Passat seats from Picknpull ($25 each on sale.) I reused the Recaro brackets, similar to the T3 pictures. Looks like the Gowesty brackets would work.
A LOT of trial and error, including cutting and making a flat bracket for attaching the Recaro style sliders. Started with a 17x 18 3/16 flat steel and shaped it to fit the outline of the seat. Had to cut off a lot of the seat hardware from the bottom to get the angle right because the seat bottom is not flat. Put seat in the DOKA, fit it, take it out, trim, back in, trim, etc. Finally welded the flat stock to the seat and installed. This is not really a how-to but intended to illustrate that it can be done if interested. Not a quick install but worth trying if you find some cheap seats.
Seat bottom is about 1 1/2 to 2 inches taller than the Recaros. I am 6.4 and have head clearance. Feels a little weird to be sitting higher but comfortable. My legs form a nice 90 degrees, which is ideal sitting height. I need to dip my head if I am the first vehicle at a stop light but other than that, clearance is good, including the steering wheel.
Just need to condition the leather now and call it good. Then start on the rear bench.
blockhead squarewheels Samba Member
Posted: Sun May 19, 2019 7:15 pm Post subject: Re: installing Recaro seats |
Got my seats in, no modifications to the seat or rails at all, just made adapter brackets. Seat height is perfect, very comfortable and they look great.
The front of the rails capture an m6 nut perfectly and the rear fits an m8
connorsvw2 Samba Member
Joined: August 16, 2008 Posts: 360 Location: Denver, CO
Posted: Mon Apr 06, 2020 8:12 am Post subject: Re: installing Recaro seats |
Just installed these this weekend after much delay (needed new bolster foam and extensive rehab of drivers side seatback fabric). Used Go Westy adapters modified for these Mk2 GTI/GLI seats. The VW recaros use M8 bolts (Go Westy kit has all M6 hardware) to secure the tracks to the seat base, so I needed new 12.9 M8x30 mm bolts, washers and for the drivers side, combo steel sleeves from hardware store (1/8 and 1/2 inch by 5/16 ID) to lift up drivers seat to stock height per Go Westys instructions). Also needed to open up mounting holes in the upper track to fit the M8 bolts. Pass seat needed no lift on the swivel base I also installed.
So far very pleased with position and flexibility, as seats have infinite vernier tilt adjustment and tilt forward with a tug on the lever. I'm not sure how I'll like no armrests but hope the comfort will more than make up for this.
_________________ '85 Westy Wolfsburg camper/2002 2.5 Subaru since 2003.
'85 GTI 1.8L 1-owner 8v-gave up on 9A 2.0L 16v transplant. Keeping her stock!
'99 Passat 1.8T Variant-AKA "The Money Pit". Still limping along...
'09 Subaru Outback XT 5-speed, 245 hp rocket (wife's car) |
erste Samba Member
Posted: Mon Apr 06, 2020 12:27 pm Post subject: Re: installing Recaro seats |
connorsvw2 wrote: |
Just installed these this weekend after much delay |
Nice!
The swivel on the passenger's seat with the full recline of the recaros is nice. You can lean way back and prop your feet up on the open door and it's pretty comfy. |
windovvsill Samba Member
Posted: Wed May 19, 2021 11:49 am Post subject: Re: installing Recaro seats |
These look great! I think I have an opportunity to buy the same seats as you:
From reading here and on GW it seems like I should be able to use their Recaro <> Vanagon seat brackets to install these in my 81 Vanagon.
This is what I would expect the underside of the recaros to look like (from GW's instruction video):
https://i.imgur.com/qElxZka.png
But this is what they actually look like underneath:
As far as I can tell, there's nowhere to attach the bracket.
Does anyone know if these will work with the GW brackets? |
erste Samba Member
Posted: Wed May 19, 2021 6:45 pm Post subject: Re: installing Recaro seats |
No, they won't work with the GW brackets without a lot of modification. Those are manual recaros. The base is different than the electric ones (electric tilt for the seat base).
There's no easy way to adapt those, and if you did, it would probably be impossible to keep the tilt. If you found electric LS bases, you could bolt those seat backs to them though.
Bummer, but those are still great seats for someone with a mk2. edit - good you didn't buy them yet.
You can tell they're manual by the way the center cushion sticks out past the side bolsters on the base, and more obviously by the handle on the front corner of the seat. Center handle is for sliding them back and forth and will be there on the electric base mk2 recaros too. |
